My Litespeed Classic
Old 06-27-20, 12:29 PM
Litespeedlouie
Bikes: Litespeed, O'Brien, Specialized, Fuji
Quoted: 18 Post(s)
Liked 15 Times in 9 Posts
I'm keeping the '97 LS Classic, upgraded through the years with threadless steerer, 9 speed Ultegra. It's retro, like me. Works fine, no worries about paint scratches. Yeah, it weighs a bit more than the latest carbon wonderbike. But I don't worry about asplosions! (got steel in the stable, too)
Litespeedlouie is offline
Old 06-27-20, 07:37 PM
Roadies_Rok
Roadies_Rok's Avatar
Bikes: Litespeed Arenberg Road Bike; Specialized Crossroads XC Pro
Quoted: 55 Post(s)
Liked 12 Times in 8 Posts
Originally Posted by SSRI
these older frames are definitely worth a rebuild to modern components despite the 1" front end. I was surprise it had enough clearance for 28mm tires.
94' Ultimate - the polish Ti threadless Stem took me a while to find.
SSRI, you're running 28mm tires on your Ultimate?? I am impressed. The Litespeed Arenberg I just bought came with 23mm tires and I want to go with 28mm but I am concerned about clearance where the chainstays meet the bottom bracket. I haven't measured it yet and I need to but by eyeballing it the clearance on the current 23mm tires looks to be approx 4mm per side. The brakes front and rear definitely have enough clearance and the fork certainly just has clearance but that chainstay/bottom bracket junction has me concerned. Any thoughts?
Roadies_Rok is offline
Old 06-28-20, 11:25 AM
scuzzo
Bikes: cannondale 2.0,caad3,schwinn Peleton,Felt F35,2007 litespeed Vortex
Quoted: 64 Post(s)
Liked 32 Times in 17 Posts
Originally Posted by Litespud
what happened to your bike that it required welding? If you don’t mind me asking..
hmm. dont really know how it happened. one day it just did.. my ride buddies said i could turn it into a planter or a lamp after the crack appeared on the down tube... but i had it welded by a TI specialist welder / instructor/ dude worked on mil spec stuff... its been rolling fine... but every thing can fail... but she is a fine bike still,, just with a beauty mark now...
scuzzo is offline
Old 06-28-20, 01:29 PM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
the thing about 6/4 Ti is that it can’t be drawn into tubing like 3/2.5 can. They have to roll sheets and weld them into tubes - which they (LS) do very well (I have looked, but I have never found a trace of a welding seam in any of my Vortex’s tubes). But just the presence of a weld, however well-finished, leaves open to possibility of a failure or crack. Rare, but I’ve heard of it. Scars or repair marks are evidence of a bike well used 👍
Litespud is offline
Likes For Litespud:
Old 06-28-20, 02:02 PM
SSRI
Quoted: 114 Post(s)
Liked 29 Times in 20 Posts
you're running 28mm tires on your Ultimate?? I am impressed. The Litespeed Arenberg I just bought came with 23mm tires and I want to go with 28mm but I am concerned about clearance where the chainstays meet the bottom bracket. I haven't measured it yet and I need to but by eyeballing it the clearance on the current 23mm tires looks to be approx 4mm per side. The brakes front and rear definitely have enough clearance and the fork certainly just has clearance but that chainstay/bottom bracket junction has me concerned. Any thoughts?[/QUOTE]
It would be safer with 25mm tires if your tolerance is too tight.
I tried mounting a rear wheel with 28mm tires on a newer LS, they do have enough clearance but depending on the frame it is a little too close for my comfort.
this is a shimano c24 wheel with a Conti 4k 28mm tire at 90 psi on my 2007 Ghisallo.
left me about 2mm on each side. The tire does not touch but in real road condition it just might with a hard bump.
Same wheel mounted on a 2006 Firenze about 3mm clearance on each side.
SSRI is offline
Old 06-30-20, 07:09 AM
merlinextraligh
pan y agua
merlinextraligh's Avatar
Quoted: 1447 Post(s)
Liked 724 Times in 371 Posts
Originally Posted by ridethecliche
Old ti bikes with quills deserve an innicycle headset adapter and new groupsets if they feel dated. It'll bring the life right back.
The new R7000 stuff is nothing short of fantastic.
One of these older ti frames and/or an older lemond with 753/853 is on my shortlist... someday.
I put on an all carbon fork, with threadless headset. It saved about a pound, and stiffened the front end a bit compared to the quill stem setup. I was a bit concerned with a 1” CF steerer tube, but years later still no problems.
You could get lost and die.
You could hit a tree and die.
merlinextraligh is offline
Likes For merlinextraligh:
Old 06-30-20, 10:24 PM
jleeg
Bikes: Moseman with Campy NR circa 1979, Merlin Titanium from1993 with newly installed Campy Chorus 12, Raleigh Tamland II gravel grinder, Tommassini XFire with Campy Record
Quoted: 30 Post(s)
Liked 104 Times in 38 Posts
Ok, it’s a Merlin, but wasn’t it acquired by LS and held by it for a while? Bought in ‘93 with Campy Chorus and some Record, 8 speed, replaced with Campy 12 about 5 weeks ago. Perfectly happy with it and comfortable on it.
jleeg is offline
Old 06-30-20, 10:26 PM
ridethecliche
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times in 160 Posts
I thought about going that route with my trek and may end up doing so in end.
The innicycle headset is great in that it allows me to use current era bars without a quill adapter. I mean... it has elements of a quill stem but it feels so much more substantial.
I felt bad splitting up my frameset, but I'm hoping to get this bike under 20 lbs and I honestly think it's going to be more like 22 the way its being built up now unfortunately.
ridethecliche is offline
Old 07-01-20, 01:21 PM
CyclingFool95
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times in 73 Posts
Great thread. Here's my 1995 Litespeed Classic w/ Kestrel fork in 2015, prior to rebuilding it with 11-speed Chorus and Zondas. I built it up in late 95 with Chorus and the Syncros Ti Post and Aluminum Stem and King headset that it still uses.
CyclingFool95 is offline
Likes For CyclingFool95:
Old 07-01-20, 02:41 PM
MidTNBrad
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 159 Post(s)
Liked 138 Times in 79 Posts
Where'd you get the bar tape? I need that to match the yellow labels on my Tuscany.
MidTNBrad is offline
Old 07-01-20, 02:58 PM
CyclingFool95
Quoted: 148 Post(s)
That's leftover Profile for Speed tape that I bought back in the '90s.
I've bought tape similar to this that's on my Paris. The only real difference that I see is that this stuff doesn't have the strip of adhesive down the length
https://www.amazon.com/dp/B07PH4LDH9..._QHp.Eb0PAZY8N
Old 07-01-20, 04:14 PM
Litespud
Quoted: 645 Post(s)
I was just thinking that - Cinelli used to make yellow/black "blotchy" tape, which went with my Vortex's yellow theme, and which hid dirt better than plain yellow tape, but I think they stopped making it - I may have to get some of this stuff.
That really is a classic Classic - I remember that Synchros stem from when I was flipping through endless catalogs, shopping parts for my first decent build in the mid-90's. And they're Open Pro CD rims?
Litespud is offline
Old 07-01-20, 05:17 PM
merlinextraligh
pan y agua
that seems quite heavy. With Dura Ace 7800, threadless fork, and what was at the time a nice set of dura ace wheels, my bike came in at 16 pounds and change.
Old 07-01-20, 06:23 PM
CyclingFool95
Quoted: 148 Post(s)
Open SUP CD. I have two pairs built in 93 and 94 by Colorado cyclist. Chorus hubs and DT 14/15 spokes
Old 07-01-20, 11:09 PM
ridethecliche
Batüwü Creakcreak
Quoted: 229 Post(s)
Jeez thats nice. I am curious what the trek will end up at. The frameset with headset was like 6.6 lbs though using the ever so accurate bathroom scale method. Was done multiple times with the same result in the end.
My current 'nice' bike is like 18.5 lbs without any weenie parts on it. These bikes are 105 11 speed though, so nothing fancy. My caad9 back in the day was probably 17ish lbs with DA7800 and the SRM.
Old 07-02-20, 10:21 AM
HighAltitude
Liked 18 Times in 6 Posts
Interesting - if yours is a 1995, I wonder what year mine is (I'm the OP). I thought it was about the same age, but the graphics are quite a bit different.
HighAltitude is offline
Old 07-02-20, 10:35 AM
CyclingFool95
Quoted: 148 Post(s)
Mine is definitely 95/96 - I got it in fall 95.
Yours is probably a 94. You can find catalogs here: MOMBAT: Litespeed Bicycles History
Old 07-02-20, 10:52 AM
SSRI
Quoted: 114 Post(s)
@CyclingFool95
Those CC wheels were very well build - too bad they dont do rebuilds anymore.
I still have a pair of Campy yspislon rims lace to ultregra Hubs from 1990.
SSRI is offline
Old 07-03-20, 02:04 AM
Fox Farm
Fox Farm's Avatar
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times in 34 Posts
I use to have that same stem and post on my Merlin.
Fox Farm is offline
Old 09-15-20, 07:50 AM
scaldin
Bikes: 2001 Litespeed Classic, 1997 LeMond Zurich, Ross Mt. Olympus frankenbike
Quoted: 5 Post(s)
Liked 24 Times in 7 Posts
Wide tires?
I've got a 2000 classic with 23mm tires. Now my buddy wants to get into adventure biking and I was thinking of putting something like 40mm on there. Terrible idea? Has anyone tried this?
scaldin is offline
Likes For scaldin:
Old 09-15-20, 08:19 AM
Litespud
Quoted: 645 Post(s)
highly unlikely you’ll be able to fit 40s. I have 25s on Zonda C17 rims (actual tire width = 26mm) and I’m at the limit of my fork and close to the limit at the chain stays. I might possibly squeeze a 28 into the rear
Litespud is offline
Likes For Litespud:
Old 09-16-20, 05:29 PM
CyclingFool95
Quoted: 148 Post(s)
Mine turns out to be a 96, if the catalog text is to be believed. In 95 the Classic had horizontal dropouts, in 96 it went vertical. Of course, both 95 & 96 catalogs say the Classic has a braze on derailleur hanger, which mine does not.
I just scored a 97 Ultimate in polished finish - always wanted one. Cleaning starts tonight - fortunately, everything seems to have been properly prepped, but it doesnt look to have been used or cleaned in quite a while.
Old 09-16-20, 05:45 PM
Warren128
Bikes: 87 Raleigh 531C Team Replica, 96 Litespeed Classic, 01 Lemond Tete-De-Course, 99 Mongoose RX10.9, 03 Lemond Wayzata, 00 Litespeed Appalachian, 99 Bianchi XL Boron, 98 Litespeed Tuscany
Quoted: 35 Post(s)
Liked 53 Times in 27 Posts
It's fun seeing all these Classics. Mine is a 1996, decals removed by a previous owner except for the David Lynskey signature on the chainstay. I bought it as a frameset in 2008, built it up in 2013, and rebuilt again in 2018.
Warren128 is offline
Old 09-16-20, 06:05 PM
jleeg
Quoted: 30 Post(s)
My 93 Merlin with a modern gruppo. Still loving the ride.
jleeg is offline
Old 07-30-21, 12:59 PM
CyclingFool95
Quoted: 148 Post(s)
So it took the better part of a year (wasn't a high priority) but my 97 Ultimate is now road worthy. Needs bar tape and cages and its ready for tomorrow. And yes, it got the brand new 11 speed Centaur group I had sitting around for a couple of years. And yes, Centaur performs well enough. I did swap out the Profile fork it came with for this nice Litespeed Look, although I'd still rather have a Kestrel one. I may pick up the replacement decals and a decal head tube badge (the original one fell off while I was working on the bike so I put it on display with a couple of others)
