RALEIGH Superbe headset
I am looking for bearing retainers for 1" headset on a 1969 Raleigh Superbe. The manual says 5/32 x 25 per upper and lower and so far have had no luck finding retainer rings for that quantity and size. Any tips would be greatly appreciated!
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
The prevailing sentiment is to just use loose balls without retainers. Fill it to the max and remove one ball. Sticky grease holds it in place for reassembly. It'll work better, last longer
Likes For clubman:
Quoted: 5888 Post(s)
Liked 3,471 Times
If you find it binds a bit once you rebuild it, just remove another ball bearing.
Likes For bikemig:
Disraeli Gears
I fill to max and remove two, because why worry about what "full" or "max" means or whether one was enough, but whatever floats your boat.
Likes For Charles Wahl:
Liked 3,471 Times
Quoted: 702 Post(s)
Liked 672 Times
Why do you want to use a retainer?
