Question about using disc brake adapters to mount on old suspension fork?
Old 07-02-20, 11:13 AM
CaptainPlanet
Quoted: 51 Post(s)
Liked 8 Times in 7 Posts
Non-tapered 1 1/8 sr suntour fork, air suspension I think. I have a hard time finding another fork of the same grade with disc brake mounting for cheap and used, and I am looking to see if I could use these disc brake mounting adapters on my old fork. This doesn't look very secure, can I trust these things? It's not even screwed to anything on the fork, it looks like the brake could wobble every time I remove the wheel even if I tighten the ring on top.
And will the adapter fit the fork?
Are there any other adapter I should look into? The fork does have one screw hole at the bottom.
CaptainPlanet is offline
Old 07-02-20, 11:41 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1103 Post(s)
Liked 489 Times in 357 Posts
I wouldn't do it on my bike. With brakes, any doubt makes it a NO-GO for me. You might check out Magura hydraulic rim brakes: https://www.magura.com/en/components/bike/rim-brakes/ My HS-33s are great.
dsbrantjr is offline
Old 07-02-20, 11:42 AM
rosefarts
With a mighty wind
Quoted: 510 Post(s)
Liked 233 Times in 126 Posts
I wouldn't.
I have enough trouble keeping my regular discs adjusted between wheel changes, no way these would stay put.
Why not just get some nice sticky salmon pads and some compression-less housing for the v-brakes? Then clean the rims with rubbing alcohol and a scotch Brite pad. That'd stop you.
Magura still makes hydraulic rim brakes if youust have them, but they're worth more than your bike.
rosefarts is online now
Old 07-02-20, 12:26 PM
CaptainPlanet
Quoted: 51 Post(s)
Originally Posted by rosefarts View Post
I wouldn't.
So I guess it's back to search for a branded cheap front shock then. The reason I want disc brake is to prepare for winter weather. With the rim being wet and the tires not gripping the road as well, I want to improve my chances a little bit.
Old 07-02-20, 01:30 PM
Mir3886
I would not either. Unless youíre in muddy scenarios and braking is life or death, a solid v-brake and pads are all youíll really need.
Mir3886 is offline
Likes For Mir3886:
Old 07-02-20, 01:36 PM
LesterOfPuppets
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 5326 Post(s)
Liked 1,016 Times in 548 Posts
I have a hard time finding another fork of the same grade with disc brake mounting for cheap.
Would you call $225 shipped brand new cheap? Probably an upgrade from the SR Suntour. I'm assuming 26er. If not, they come in 27.5 and 29 also.
https://www.modernbike.com/product-2...xoCBoYQAvD_BwE
LesterOfPuppets is offline
Old 07-02-20, 01:40 PM
LesterOfPuppets
Bikes: everywhere
Oops, looks like they're sold out in a lot of places, some promising more stock mid july, some August. Universal claims to have ONE. I'm always skeptical of just one, but... and they want $250.
https://www.universalcycles.com/shop...s.php?id=90305
Old 07-02-20, 03:14 PM
CaptainPlanet
Quoted: 51 Post(s)
It's a very nice bike with quality parts, but I can't spend over 100 on a fork when I got the bike for a little over 100 bucks.
I probably have a better chance buying a newer brand name bike with dual disc brakes for 200 if I camp on Craigslist long enough.
It's not super dated because it still has with derailleur hanger and threadless stems, but it came out before disc brakes got mainstream.
Old 07-02-20, 03:18 PM
sch
Quoted: 231 Post(s)
Liked 47 Times in 39 Posts
The other unmentioned reason not to put disc brakes on a dropout/QR fork is that front disc braking torque has
been known to rotate the FW out of the dropout with catastrophic potentiality to ones head/face there. Not for nothing the
devising of through axles for disc wheels where the axles are in a complete circle of enclosing metal.
sch is offline
Old 07-02-20, 04:59 PM
dsbrantjr
dsbrantjr's Avatar
If your tires don't have any grip the best brakes in the world won't do you any good.
Old 07-02-20, 07:54 PM
CaptainPlanet
Quoted: 51 Post(s)
Say I take out the shock cover piece by itself and try to weld a disc brake mount to it, would it work?
Tires are cheaper and more readily available than the forks. Still in planning phase for all the potential mods and stuff.
Old 07-02-20, 09:14 PM
rosefarts
With a mighty wind
Quoted: 510 Post(s)
No, the weld won't work.
If you absolutely must have a front disc (forget about rear) then something like this will work. https://www.ebay.com/itm/264088134040
You'll lose suspension but I doubt you'll notice.
Still, you're ignoring the best advice here, get those v-brakes working like a charm. I think you're obsessing over something new when just tuning what you've got is enough.
People have managed to stop in water for the last decade. You don't need discs.
You paid $100 for it, it's not worth much more than that, don't break your budget over it. The original brakes are just fine.
Old 07-02-20, 10:24 PM
CaptainPlanet
Quoted: 51 Post(s)
I keep wanting to modify it because I really think this is going to be the definitive bike for me with its scratchless frame, almost complete set of Deore 3x8 speed groupset, sr suntour air fork, insanely decent mid rang specs that I have never experienced until now.
I was thinking of buying another okay bike that runs 27.5~29 inch tires and disc brakes but worse groupsets, and then swap the deore groupset onto there and then sell off the 26" bike, but so far I haven't had any luck
So instead I decide to put 27.5 tires (which I found to be compatible) and disc brake (mechanical, just the front) onto there so I can fulfill my vision of what an ultimate bike is like to me and call it a day. All my recent threads on this subforum are about working toward this.
Old 07-03-20, 01:32 AM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 374 Post(s)
Liked 137 Times in 114 Posts
The adapters are garbage and welding onto that fork is a good way to go to the ER. Seriously, get some good V brakes with Koolstop salmon pads and get them adjusted well--discs are great but you really don't need them for winter commuting.
cpach is offline
Old 07-03-20, 02:01 AM
dabac
Quoted: 912 Post(s)
Liked 84 Times in 63 Posts
Say I take out the shock cover piece by itself and try to weld a disc brake mount to it, would it work?.
1) I donít know the alloy
2) I donít know your welding skills
It is possible - in general terms. Iíve done it and lived to tell the tale. Made a fixture to hold stuff in place first. Despite that I got a lateral offset I still DONíT know where it came from which caused some assembly issues. Caliper and rotor were planar and centered though.
If you decide to go this route I suggest you put the caliper on the front of the opposite leg. This eliminates all risk of wheel ejection.
dabac is offline
Old 07-03-20, 05:44 AM
Ironfish653
Bikes: 1997 Cannondale, 1976 Bridgestone, 1998 Softride
Quoted: 425 Post(s)
Liked 132 Times in 87 Posts
I wouldnít mess with it. A well set-up canti or v-brake will be better than a bodged-up disk anytime.
Winter weather? Youíre on a bike, not Ice Road Truckers.
Get the orange Kool-stop pads an learn how to set up a brake. V-brakes with fresh pads and straight wheels are stone-simple.
Ironfish653 is offline
Old 07-03-20, 09:04 AM
Miele Man
Quoted: 1087 Post(s)
Liked 632 Times in 439 Posts
I have a rigid Miele MTB that I ride al through the winter. I had it with cantilever brakes properly set up but wanted better braking in the snow and slush. I converted it to V-brakes and even without the better stopping ability of KoolStop pads the bike stops when I want it to. The limiting factor for me now is the grip the tires have on the road. I find it quite easy to skid a tire in the snow or slush so disc brakes would NOT be an IMPROVEMENT for ME. YMMV
Oh, that bike has a dropbar handlebar and Tecktro V-brake brake levers.
Cheers
Miele Man is offline
Old 07-03-20, 09:27 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 7335 Post(s)
Liked 948 Times in 598 Posts
My foulest weather , Ice & snow bike uses drum brake hub wheels,,, they've been reliable for 35 years..
I retrofitted an old rim brake MTB.. Sturmey Archer company has changed hands during this time frame..
they're still being made & product range has expanded..
fietsbob is online now
Old 07-03-20, 11:08 AM
70sSanO
70sSanO's Avatar
Quoted: 407 Post(s)
Liked 147 Times in 111 Posts
Obviously a mid-90ís, what bike is it?
I would guess that is an old 90ís Suntour fork not a newer one. Maybe 63mm, but no more than 80mm. You can probably use an 80mm.
While thru axles are better, mountain bikers have probably ridden millions(?) of miles with QR and discs. Just make sure they are tight and use steel internal can QRís.
There are cheap new 80mm forks on eBay for less than $100 if you want cheap and feel you need suspension. If you donít need suspension you can go rigid. You also have to weigh the cost of the disc system.
If your old Suntour fork works well, donít get rid of it. I donít know who made it. I wasnít aware Suntour made (labeled) forks back then.
And it doesnít matter what you paid for the bike, if it is pretty much unused, in this market it would probably fetch more than $100. Between the pandemic buying and a nostalgia for 26ers, I donít see a lot of good cheap ones out there. But Iím not flipping either.
John
70sSanO is offline
Old 07-03-20, 12:08 PM
Dave Mayer
Quoted: 730 Post(s)
Liked 96 Times in 62 Posts
OK: I'm going to assume that you are riding on pavement and sometimes in the rain.
First, ditch the knobby tires; they have poor traction on anything but mud or loose gravel. Slick tires provide more surface area and therefore better grip to the road. High-pressure slick 1.5" tires will roll a lot faster as well.
Second, upgrade your V-brakes and pads. It looks like you have cheap stamped-steel V-brakes found on department-store bikes. Inexpensive Shimano V's are worlds better, and have better stock pads.
If you want a better all-round bike, also get rid of the suspension fork, which unless your commute involves travel over head-sized rocks, is a heavy and unnecessary impediment. It adds 2 pounds of useless weight, saps your pedaling energy due to suspension bob, and has less precise steering/handling than a rigid fork.
26" wheels are fine; 27.5" is dead, and 29" wheels and tires are heavy.
Dave Mayer is offline
Old 07-03-20, 06:56 PM
70sSanO
70sSanO's Avatar
Quoted: 407 Post(s)
I guess you are going to use mechanical front disc and v-brake for the rear.
John
70sSanO is offline
Old 07-05-20, 04:15 PM
CaptainPlanet
Quoted: 51 Post(s)
I just noticed something while scavenger hunting in local second hand market.
It was impossible for me to even find a 26 inch threadless fork that's rigid.
I either find
- 26 threaded rigid/suspension v-brake
or
- 26 threadless suspension v-brake/disc brake
Only in 700c can I find a threadless fork that's rigid.
Funny that by 2010, rigid mountain bike fork actually becomes a niche item you have to special order to get.
Old 07-05-20, 04:35 PM
rosefarts
With a mighty wind
Quoted: 510 Post(s)
That's certainly the trend of things but I don't think your local market is an accurate representation of what's available.
I'll bet you $100 that v-brakes with salmon pads and compression-less housing stops as well or better than any mechanical disc brake you can get on your bike.
Why are you so insistent on ignoring good advice that will save you time and money?
Old 07-05-20, 04:50 PM
CaptainPlanet
Quoted: 51 Post(s)
I was looking to see if I could find a rigid 26" threadless fork on the used market, after reading some of the advice, because ebay fork is not cheap, but I couldn't find one used.
Old 07-05-20, 05:01 PM
rosefarts
With a mighty wind
Quoted: 510 Post(s)
Once more. Slowly.
Cables, compression-less housing, salmon pads, and some steel wool to clean up your rims. Should run you about $30-35 for the bike. It'll stop better than you'll ever need it to. Double the price if you get a shop to do it but I bet you can handle it.
You're not going to get a fork under $75. Probably closer to $200. Now you still need to go get a front caliper. Or ideally, a hydro caliper with lever. New front wheel or rebuild with new hub. Rotor. And you still have v-brakes in the back. Let's be very generous and say $300
Is it worth trying to get those v-brakes working?
