Squeaky headset
Squeaky headset
I have an older Bianchi San Lorenzo (2003 i think) with replacement Origin8 carbon forks that I took possession of within the last year... It's a great bike in in great shape and I love riding it, but the headset started creaking recently. I took the headset apart and cleaned it, regreased, etc... but the creaking remains. Also, I can just barely get the compression plug tight enough to get the play out of it, while still maintaining free steering.
Whats going on!? Do i need to replace all the bearings and rings, etc...? Nothing seemed in that bad shape when i had it all apart, but i'll do anything at this point to get rid of the noise!
Any help would be greatly appreciated.
Thanks,
Joe
Thanks,
Joe
Quoted: 2026 Post(s)
Liked 1,095 Times
Are the headset bearings original to the bike or replacements? If they are not original, the replacements may have the wrong seat angles and/or wrong diameter.
Not sure... but they seem to be the right ones, they fit perfectly and seem to be in good shape. Also, the creak is something that has developed recently, was not happening when i first got the bike.
Liked 1,095 Times
Is this an "integrated" headset or one using press-in cups? If it's a press-in design, the squeak could be between the cups and the headtube. Remove the cups, clean the exterior stems of the cups and the interior of the headtube, grease thoroughly and reinstall the cups.
Old fart
Quoted: 3583 Post(s)
Liked 3,396 Times
Are you certain the headset is the source? Have you checked handlebar/stem?
Likes For JohnDThompson:
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Check & grease the stem bolts, as well as the top cap bolt, especially if you frequently ride in the rain. These points are a common source of creaking on my bikes. I have to remove, clean, and regrease those bolts about once a year to get rid of creaking from torquing of the handlebars and stem.
Headset is almost certainly the source, only squeaks when i turn, whether i'm on the bike or not.... so its not stress from weight on the handlebar or anything.
Gonna get a new compression plug and relube everything, see what happens then.
Old fart
Liked 3,396 Times
It's unlikely to be the compression plug, as that turns with the bars and the steer tube.
thanks - bearings are cartridges, they seem fine. i think it's a matter of how much i have to tighten the plug to get the play out of the headset... if that doesn't work i'll change the bearings as well.
Quoted: 6178 Post(s)
Liked 4,796 Times
Take the fork out and put the stem back on the steerer tube and tighten the bolt for the compression plug and see if it's bulging your steerer tube as you tighten it. Might be that it bulges so much that it's rubbing the head tube or bearing races somewhere.
Might can just run some calipers down the tube and see if the area around the compression plug is a wider diameter than the rest of the steerer.
Interesting... I'll take a look at that once i have all apart again.
Ok so here's a question. The compressor i have has a bolt and a cap that both tighten down. with the stem bolts loose, you need to tighten the compressor bolt first, then the cap to get the play out of the headset.
The question is, how do you know how much to tighten the bolt before you tighten the cap? is it a thing you just play with til it's right?
Liked 4,796 Times
......is it a thing you just play with til it's right?
We are talking about when it's installed in the headset though. Not removed as I previously posted.
