Totally Tubular
Totally Tubular
Old 07-03-20, 10:38 AM
  #1626
smontanaro
Bikes: many
Quoted: 1444 Post(s)
Liked 1,394 Times in 761 Posts
Originally Posted by woodcraft
Or just skip forward to where you take them off because of the annoying noise and no detectable benefit.
A gloved hand has always worked well for me.
Monti Special
smontanaro is offline
Likes For smontanaro:
Old 07-03-20, 12:07 PM
  #1627
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,931 Times in 2,556 Posts
Like smantanaro, I find the hand brush works well except on fendered bikes. That rear wheel, already prone to more flats just being a rear wheel, never gets brushed. Tiresavers are a real plus there, (They always went on my fendered and tubular bikes. Front was not required but I did on my rain bikes to keep my gloves cleaner.
Trick to reducing the noise - ride rib tread tires, those tires with longitudinal parallel ribs. Those were common on training level tubulars 45 years ago and Vittoria has brought it back with their G+ and G2,0 tires. (Aside - also my favorite tread pattern ever, Thank you Vittoria for bringing it back! Best tread ever if you have to leave the paved road surface and climb back on.)
Ben
79pmooney is offline
Old 07-03-20, 12:40 PM
  #1628
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times in 1,617 Posts
My second most popular tutorial - tire wiping.
I prefer a fine file tread, those straight grooved things just don't do it for me.
DiabloScott is offline
Old 07-03-20, 12:54 PM
  #1629
CV-6
If I own it, I ride it
CV-6's Avatar
Quoted: 591 Post(s)
Liked 663 Times in 312 Posts
https://youtu.be/4YBWhGcwlk8
Nicely done video.
Emphasis on wipe inside the triangle, not outside. Your hand could conceivably be "sucked" into the brake bridge wiping outside the triangle. That would hurt.
Lynn Travers
Photos
CV-6 is offline
Old 07-03-20, 02:57 PM
  #1630
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 7081 Post(s)
Liked 901 Times in 612 Posts
I have a couple sets of ancient tire wipers up on the board. The roads I normally ride don't require their use. Once I put tubulars on, however, with significantly more to lose, they will return to service.
seedsbelize is offline
Old 07-04-20, 08:17 PM
  #1631
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
Huh. I've never done the rear by reaching between the legs- seems easier to have the hand pulled down into the seat tube,
and hanging the fingers down alongside the spokes seems to add unecessary risk- like feeding a carrot to a horse by holding in the fingers.
woodcraft is offline
Old 07-06-20, 06:25 AM
  #1632
pastorbobnlnh
Freewheel Medic
pastorbobnlnh's Avatar
Quoted: 1453 Post(s)
Liked 2,196 Times in 963 Posts
I wish I had a closeup picture of the tire wipers on my 406mm wheeled Dahon folding bike. It wears high performance Comet clincher tires which are thin and supple. I rode it 750 miles during the first six weeks of the pandemic while sheltering in place. I had no problems with either "noise" or punctures.
The wipers certainly proved their effectiveness. I found shards of glass and crushed seashells slivers stuck to them every day. But never once had to stop for a flat.
P.S. Hand wiping a 20" tire, front of rear, would be suicidal, IMO. YMMV.
Bob
pastorbobnlnh is offline
Old 07-07-20, 10:33 AM
  #1633
seedsbelize
smelling the roses
I ordered three tires from ProBikeKit ahile ago. They sent one and back ordered the othr two. Now they tell me they can't get those other two. Challenge
Elite Pro.
So I'm looking for low priced suggestions.
Thanks
Old 07-07-20, 05:18 PM
  #1634
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,827 Times in 1,543 Posts
Elite Pro.
Thanks
Sorry dude....since I suggested those tires and source
squirtdad is online now
Old 07-07-20, 05:27 PM
  #1635
seedsbelize
smelling the roses
No worries. There is always Yellow Jersey to fall back on. The direction I was heading before you stepped in. This way I could do a real comparison.
Old 07-07-20, 05:29 PM
  #1636
SJX426
SJX426's Avatar
Quoted: 1608 Post(s)
Liked 2,216 Times in 1,103 Posts
I took my newly built up De Rosa out for a 15 miler last Saturday. Pumped up for another ride on Monday and found a hole in the front tire. Since the tires came with the wheels, not a big loss for me. Rear tire will be a spare.
Thought this wold be an easy change. Nope! took me over 45min to remove the tires from the rims. Looks like the PO used contact cement. Rear was worse than the front.
P1030573, on Flickr
Thought I could use a brass wire wheel. It gummed up with glue and melted the glue on the rim. Tried Acetone. Hardly touched it. Tried Mineral Spirits. Slightly better but I did not want to spend the next several day trying to remove it. Picked up a small screw driver about 1/8"wide that was well used, Scraped a little and it worked without scratching the rim. Must have spent two hours scaping it off. Example of what I was peeling off:
P1030574 , on Flickr
Here is the pile of pulled glue:
P1030578 , on Flickr
The after pic
P1030576 , on Flickr
Hardest part was getting around in in the spoke holes.
Glued then all up and installed.
P1030581, on Flickr
SJX426 is offline
Old 07-07-20, 05:34 PM
  #1637
smontanaro
Bikes: many
I use a plastic Park the lever. Also, if it's not too thick, I will just add another this coat.
Monti Special
Old 07-07-20, 05:43 PM
  #1638
SJX426
SJX426's Avatar
smontanaro Have a set of those but they are too flexible. I don't like them because it is hard to get under the bead. I used the Spin Doctor because of the steel reinforcement. I had to use two to pry up on either side until enough of the tire was off the rim so I could pull directly up. That was a slow process too.. I think they thought they had to fill up the valley with glue! Looked like one layer.
SJX426 is offline
Old 07-07-20, 05:49 PM
  #1639
smontanaro
Bikes: many
Bringing it back on topic, I was referring to using the lever to scrape tubular glue.
Monti Special
Old 07-07-20, 05:51 PM
  #1640
Wileyone
Wileyone's Avatar
Quoted: 1858 Post(s)
Liked 606 Times in 403 Posts
Are you sure that's glue? Looks more like tape.
Wileyone is offline
Old 07-07-20, 07:18 PM
  #1641
SJX426
SJX426's Avatar
Wileyone Yes, the spoke holes had excess glue in them. Tape would have gone right over them. It was thick! Maybe thicker than tape.
The pattern seen in the first photo is the pattern of the base tape of the tire. Leads you to believe it is tape but tape would not look like the resulting pile.
SJX426 is offline
Old 07-07-20, 10:58 PM
  #1642
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1627 Post(s)
Liked 630 Times in 356 Posts
Heat gun. Melt the glue and wipe with a disposable rag.
~ l0 min per rim.
Lascauxcaveman is offline
Old 07-08-20, 07:49 AM
  #1643
SJX426
SJX426's Avatar
~ l0 min per rim.
D0000! Forgot I had one! I was thinking tourch for only a microsecond! Getting old is a disadvantage in so many ways!
SJX426 is offline
Old 07-08-20, 10:25 AM
  #1644
woodcraft
woodcraft's Avatar
+1 Looks like tape.
Old 07-10-20, 10:09 AM
  #1645
smontanaro
Bikes: many
I've been meaning to install better tires on my Redcay. I had been running 25mm Vittoria Rally tubulars, but had 27mm Veloflex Vlaanderen on my Frejus Tour de France (which I am contemplating selling at some point and which is currently down, loaning its derailleur to an evil project). So I gave that a whirl yesterday. Pulled tires, cleaned rims, glued tires and rims, then installed the Vlaanderen. Whew! Talk about tight clearance. This is with 80psi while the glue cures. I will probably run with a bit less than that. I think parallax makes the tire seem more off-center than it really is, but will need to check things out at some point.
Old 07-12-20, 03:59 PM
  #1646
Ferrouscious
Some Weirdo
Ferrouscious's Avatar
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times in 92 Posts
I'm currently getting my tubular wheels out of the closet to try for the first time. I have tires on order (Challenge Strada Pro's) and glue in my cart. Sorry if this has already been covered in the thread, but it's a bit long to read through the entire thing. What was the so-called "old fashioned" way of gluing tires? I know that modern tubular users use mastic adhesives to attach the tire pretty much permanently, but I don't want to do that. I'm looking for the ol' slap the tires on pro mechanic way in case I get a flat. How many layers and how much time between them? BTW, the glue I have in mind is Tubasti. Continental is also available. Should I go with that instead? Sealant?
Ferrouscious is offline
Old 07-12-20, 09:20 PM
  #1647
squirtdad
squirtdad's Avatar
old school but as a newbie has been my go to invaluble help....Tubular Tire Mounting Cement Gluing Adhesion by Yellow Jersey; Thoughts on a Front Wheel
Old 07-12-20, 10:23 PM
  #1648
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3898 Post(s)
Liked 4,836 Times in 2,229 Posts
How do you ride your bike? Fast & racy or More sedate & generally careful.
Where do you ride? Mountains or any hilly areas where speed and turns may be very fast.
As a minimum - one coat (not too thick but covering) on each of the rim and tire. Cure overnight. Thin coat on tire, wait an hour or so. Mount tire.
For hard mountain riding - I add a 2nd coat to each the rim and tire with a 2nd overnight cure (emphasis on edge to edge with coverage) , then the 3rd light coat on tire with an hour wait before mounting tire.
edit: This process has worked for me many years, and I've never rolled a tire.. Several times a year I'm descending Cascade Mt. roads, with hairpins. Most of my bikes are not ridden in the mountains, given vintage gearing. But I have 3 tubular bikes for pass hunting, and 2 clincher equipped triples.
Wildwood is offline
Old 07-13-20, 07:34 AM
  #1649
Ferrouscious
Some Weirdo
Quoted: 223 Post(s)
I'm a pretty aggressive rider, so I want some margin of safety. At the same time, I know how to ride carefully and wish to be able to remove the tire without damaging it (fixing flats). I also live in a pretty flat area with only a few short but steep hills. Basically old school racer dude.
Somewhere, a village is missing its idiot.
Old 07-14-20, 06:40 PM
  #1650
WGB
WGB
WGB's Avatar
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times in 1,378 Posts
Was planning on trying to set up tubulars this week.
Problem, I can't find anyone with Tubular glue locally. Was going to try grabbing one of the large cans I see which are the equivalent of 10 small tubes. Can order from Amazon or what have you but won't have this week. If I'm going to order I was thinking of trying the tape method. I found a listing for "CX Tape 10-wheel Shop Roll for Tubular Tires"
https://www.amazon.ca/CX-Tape-10-Whe.../dp/B008OVAMZU
(Sorry for the over sized font) Does anyone have any experience with this brand?
WGB is offline
