Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 12-06-13, 11:50 AM
  #51
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Originally Posted by Pantani98
Shopping around for some DA cranks and BB-7710 bottom bracket. Carleton probably knows the answer right off the bat with his Tiemeyer collection, but what size bb do I need for my Tiemeyer Signature track frame? I've seen posts of 68x109.5 and 68x110. Just want to make sure I get the correct size. Thanks!
Originally Posted by brawlo
109.5 should be the standard. The only other size is 115 which I'm pretty sure is for the road BBs
+1
Get the 109.5.
carleton is offline
Old 12-06-13, 11:51 AM
  #52
carleton
Elitist
carleton's Avatar
Originally Posted by Soil_Sampler
$57 US delivered.
Nice price.
carleton is offline
Old 12-06-13, 11:55 AM
  #53
Kayce
Kayce's Avatar
88mm rims to wide flange hubs? I'm pretty sure this was a bad idea because of the increased angle of the spokes to the rim but I'm stuffed if I can find where it was discussed before. Should I be going for low flange hubs?
I will do some hunting later but Boyd, of Boyd wheel fame, has done a lot of blogging on this subject.
Kayce is offline
Old 12-06-13, 01:00 PM
  #54
slindell
Zipp does track wheels with 808 rims but did not recommend using a powertap hub (large flange) with a 1080 rim due to the angles. So in their case ~88mm rim is ok. It will depend on the rim and the drilling.
slindell is offline
Old 12-06-13, 02:55 PM
  #55
Impreza_aL
Impreza_aL's Avatar
Bikes: yellow tricycle di2 grip shifters
i saw a local racer on track fc 404s with a PT...
Impreza_aL is offline
Old 12-06-13, 06:03 PM
  #56
Soil_Sampler
A little North of Hell
Quoted: 71 Post(s)
Liked 4 Times in 4 Posts
fyxo/cycle underground
Originally Posted by carleton
Nice price.
Excellent chainring for the money.
Runs quiet.
Chain take up is smooth.
Concentric, and very well made.
Soil_Sampler is offline
Old 12-06-13, 10:11 PM
  #57
brawlo
brawlo's Avatar
Quoted: 288 Post(s)
Liked 76 Times in 57 Posts
They are the default standard for me, but there are others I like better.
FYXO/Chain Underground
Those are the Cycle Underground chainrings made down here in Oz. FYXO is handling the distribution of them nowadays
brawlo is offline
Old 12-07-13, 12:57 AM
  #58
Racer Ex
Resident Alien
Racer Ex's Avatar
Quoted: 349 Post(s)
Liked 10 Times in 6 Posts
The high flange hubs were designed to shorten the spoke to rim length to take the additional effective weight loading caused by g-forces on a banking back when people were using box section rims. When you start going to taller rims, especially once you start hitting 80-90mm they really aren't necessary if you have a good build, which would include a hub with an adequate axle.
I ran a road HED S9 front with a screw type skewer when we set the Nats 45+ TP record at Carson and a bunch of other races. Thought it was stiffer than the high flange box wheel I use in training.
Why anyone wouldn't run a disc rear in all events, I dunno.
Racer Ex is offline
Old 12-07-13, 07:26 AM
  #59
coachboyd
Boyd Cycling owner
coachboyd's Avatar
Quoted: 10 Post(s)
Liked 3 Times in 1 Post
If you were using internal nipples I could see this being a problem as the spoke would make a sharp bend at the nipple when the nipple sits inside the rim. I am thinking if you have a wheel that needs washers this may also be a problem as the washer makes the nipple sit at a straight angle inside the rim. I know the nipples we use (Sapim Polyax) have a rounded bottom that allows them to take on a good angle and keep the spoke in a straight line (not having to bend to adjust to the nipple). On our super deep track wheels we are still using high flange hubs and there's no issue at all with the spokes taking a good line into the nipple. . . and with a bracing angle that big, man are they stiff wheels!
coachboyd is offline
Old 12-07-13, 12:01 PM
  #60
Racer Ex
Resident Alien
Racer Ex's Avatar
Quoted: 349 Post(s)
I would bet. Just took a look at the 2013 wheels, anything new for 2014? I'm considering going over to a tubeless clincher in the 50-60mm depth for crits...have folks used the Stan's conversion with your 60's?
I've also noticed some straight pull hubs coming out of Taiwan this year, thoughts?
Racer Ex is offline
Old 12-07-13, 06:43 PM
  #61
Pedal Strike
Bikes: 2002 Cannondale Track
Is Keirin considered a sprint or endurance race? Seems just as long if not longer than a Kilo but it seems people categorize it more as a sprint.
Pedal Strike is offline
Old 12-07-13, 07:34 PM
  #62
Racer Ex
Resident Alien
Racer Ex's Avatar
Quoted: 349 Post(s)
If you can pass the motor and keep going it's an endurance event.
Racer Ex is offline
Old 12-07-13, 10:11 PM
  #63
Kayce
Kayce's Avatar
The time behind the motor you spend so little energy it doesn't really count as race time.
Kayce is offline
Old 12-08-13, 06:37 PM
  #64
8bits
Quoted: 7 Post(s)
what is a good tubular tyre to use on concrete velodromes mainly for training but good enough for racing?
8bits is offline
Old 12-08-13, 06:43 PM
  #65
VanceMac
VanceMac's Avatar
Quoted: 31 Post(s)
This comes up often enough, probably worth its own thread. I will start one...
VanceMac is offline
Old 12-09-13, 04:29 AM
  #66
bitingduck
bitingduck's Avatar
Quoted: 43 Post(s)
If you're a pure sprinter it's an endurance event. If you're anybody else it's that time when you take a break while they drive a motor around the track and then sweep up crashes.
Track - the other off-road
https://www.lavelodrome.org
bitingduck is offline
Old 12-09-13, 05:20 AM
  #67
Dalai
Quoted: 89 Post(s)
Liked 8 Times in 6 Posts
Apt comment... Result is a broken collar bone and ribs I believe!
Dalai is offline
Old 12-09-13, 06:16 AM
  #68
Velocirapture
Velocirapture's Avatar
Bikes: S-1 :-D
Quoted: 17 Post(s)
oh man, he had no chance!
Velocirapture is offline
Old 12-09-13, 01:45 PM
  #69
Kayce
Kayce's Avatar
Any WC videos popping up yet that we can watch in the states?
Kayce is offline
Old 12-10-13, 05:39 AM
  #70
Dalai
Quoted: 89 Post(s)
This work?
Dalai is offline
Old 12-10-13, 01:42 PM
  #71
bigfred
Bikes: More than 1, but, less than S-1
Quoted: 5 Post(s)
Originally Posted by Dalai
This work?
"The uploader has not made this video available in your country"
And I can't be bothered to start finding ways to view through proxy.
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
bigfred is offline
Old 12-10-13, 01:51 PM
  #72
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
There's a really easy way. It'll change your whole world.
Download the Hola plugin for your browser.
Install it. It will put an icon in your browser interface.
When you hit a blocked video, click the icon. Select a different country to route your connection through.
Re-load the page.
Enjoy the video.
queerpunk is offline
Old 12-12-13, 08:55 AM
  #73
Velocirapture
Bikes: S-1 :-D
Quoted: 17 Post(s)
So, my small random question :-)
Going by Carleton's recommendation of money-spend order (below for memory refreshement), the basic aerodynamic goodies sit slightly above half way in importance, what are folks' views on the relative advantages between:
a - mass start aero-helmet, (i've got my beady eye on the Giro Air Attack Shield. Currently ride with a standard road helmet)
b - super narrow bars (the 33cm Alpina..) - my current bars are 37cm sprint bar, but my shoulders (distance between acromonions) is ~33cm.
similar prices.
I'm an enduro, focusing on points, scratch and team pursuit.
Thanks
(in my humble opinion) spend money in this general order:
- Track season pass (ride/race as much as possible)
- Road Bike
- *basic* equipment (chainrings, cogs, tools). Notice that I didn't say fancy carbon or aero gear.
- Race entry fees (but this should be covered in the season pass)
- Clinics
- Skinsuit, aero helmet, booties
- Diet for Athletes book. This will change your energy and fat levels.
- Gym membership (if you plan to be a sprinter)
- Coaching (optional really)
- Travel to other tracks for regional type events to broaden your horizions
- Aero front wheel
- Fancy carbon/custom frame
- Aero disc
Old 12-12-13, 09:28 AM
  #74
Brian Ratliff
Brian Ratliff's Avatar
Bikes: Three road bikes. Two track bikes.
Quoted: 47 Post(s)
I'd get the bars first, for no other reason is that bars tend to be more or less forever. Start getting used to the narrower bars ASAP. IMHO, position on the bike (including bar width) is what you sort out first prior to messing with aero wheels and helmets.
Besides, the benefit of an aero helmet for mass start is tenuous at best. Not nearly as clear cut as for individual events or sprint.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Brian Ratliff is offline
Old 12-12-13, 11:03 AM
  #75
Impreza_aL
Impreza_aL's Avatar
i have the scatto 35s going to try those for mass start. i also ordered some deda 36s for both the road and track. i'll probably end up using the dedas since i tend to ride on the tops during a mass start.
