I think it is too cold to ride.
Bikes: Masi Giramondo, Trek 830 monstercross build, Raleigh Gran Sport, Lemond Tourmalet
Quoted: 121 Post(s)
Liked 19 Times
In the middle of two straight weeks of highs below freezing, and I don't have a good way to ride any real speed or distances without risking frostbite. So I am running instead, which is less exciting.
Quoted: 5224 Post(s)
Liked 3,581 Times
been having seemingly never ending excuses not to ride despite good intentions. today had to do something about the steady breeze from the from door making our heat kick on seemingly continuously. bought 3 kinds of weather striping & a door knob. problem solved but I'm not riding, yet again
Liked 3,581 Times
Bikes: Giant Escape 1
Quoted: 136 Post(s)
It iS too cold to ride (at least in Vermont). Bad for the rider, bad for the bike. Dangerous on a number of levels. I haven't even been seeing fat bikes lately.
Quoted: 101 Post(s)
Liked 41 Times
Today the high here was 10F. Too cold for me to want to do either, I rode my trainer!
commu*ist spy
I got sick trying to man it out at 20s in KS (a week ago) and 30s in TX (back from holidays). and I agree running is much better than cycling because of the wind
it's a nation wide cold front right? expect it to get better soon. besides, january is when the days get longer and temps get warmer, right?
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
I did get out yesterday for a few miles in 11 F weather, but I lean more toward walking and snowshoeing when it's that cold. When I bike, it's usually just for fun around town with friends, or for a short errand.
Quoted: 1364 Post(s)
Liked 1,677 Times
I used to run cross-country and track in high school, and I've been a year-round bike commuter for 25 years, with a low temp threshold of 10F. Besides the "steady breeze" adding an additional potential chill factor (depending on how you dress), my thumbs get cold below 12F regardless of handwear (gloves or mittens) or handlebars (straight or drop); I think it has to do with weight and pressure on the hands impinging circulation. This also goes for the feet which have more constant pressure on them while cycling than the more stacatto contact of running.
I also think running warms the body better as both legs and arms are in constant motion and there is no "coasting" as opposed to cycling where the arms don't really move as much.
Quoted: 121 Post(s)
Liked 19 Times
Today in STL the high was 10 and the low was 3, we've been in this range for a few days. Although I technically *can* run in that, the layering up, fogging of my glasses, air entering my lung etc makes it unpleasant, and difficult to maintain a cardio intensity. 10F is usually my running threshold. I think for the reasons mentioned above...feet and hands being relatively immobile compared to running...my hands and feet get cold quick on a bike if it's below freezing in spite of insulated gear, as does the part of my face that is exposed. Wind speed makes it really unpleasant, particularly if it's the cold/humid combo that is common here and that finds a way to seep in.
Quoted: 1218 Post(s)
Liked 298 Times
too cold, never!!!
bad gear Always!
below zero is definitely begging for a singlespeed bike though. and probably mechanical disc brakes. I am divided on drop bar. flat bar. both offer bar mitt options.
I need to ditch the balaclava and just sew/glue a face shield onto the bottom of my goggles to cover face.
I say bad gear, only because I typically ride somewhere in the above 20 range. -10 + is really pushing into a gear/equipment range that I don't have.
bad gear Always!
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
-18deg currently.
Jan 1st high of -1deg
Dec 31st high of -2deg
Dec 30th high of 5deg
Whether ill have time after work to ride outside isnt even the 100th thing on my mind. Ill jump on my trainer and spin. Only decision to make is if ill watch something on hulu or netflix.
Liked 298 Times
there is another side to this, the money spent on winter gear/maintenance would easily buy someone a new bike A REALLY nice new bike come spring.
Liked 3,581 Times
thinking about using toe warmers sitting inside at my desk today
Liked 3,581 Times
Liked 298 Times
If I recall, I went to take it off, forgot it was clasped, I felt my goggles while reaching for the strap, and decided to take a photo. Matter of fact I normally don't ride with the straps that loose either, but any tighter and it pulls the balaclava in and smashes my nose.
I see people ride with helmets cocked back like that and It kills me.
I am almost between sizes on Giro. a Large will fall down to my eyebrows, and almost won't tighten enough. So medium is correct, when sitting on head correctly.
You've a Good eye
Randomhead
Liked 3,698 Times
The gravel here is now under snow. Actually, if it's ridable, it's probably under ice. i don't have studded tires on my gravel bike, so it would have to be mountain bike or fat bike for me. I'm mostly riding the trainer though. Probably be icy conditions until sometime in March.
I have ridden to work in -20F weather. Fortunately, at that temp there was no wind. i feel that is a little dangerous though. I got frostbite doing that, and it didn't take long at all. Less than a minute before I felt my skin burning.
I have ridden my fatbike in the low teens. That isn't so bad. I think I probably would cut off at 10F. I have some really heavy winter cycling boots.
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
Windchills in the teens means temps in the 20's. Much different than temps below zero. I had a good ride in mid-20's to work, but I won't ride when its close to zero.
I was riding last week when it was sub zero here in Chicago. People think you're crazy for cycling...but it really isn't any different than skiing.
All you're really doing by throwing extra money at the issue is reducing bulkiness.
I will throw a nod to good baselayers though. Nice ones make a difference.
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
I've been doing the same thing, running instead of biking. But I rode to work today now that it's warmed up a little in Chicago (to 15º)... and I've found that running has made my legs weaker on the bike! Weird.
The headwind still pisses me off in general though lol
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
My problem is feet. I guess I should stop using clipless pedals in the winter, and or find thicker shoes.
Motorcycle helmet and down hill goggles are popular around here.
Quoted: 40 Post(s)
Nonsense. All you really need in addition to basic cold weather clothing is a $40 worth of goggles/balaclava off of amazon. That will get you through the winter.
Do you typically use ski gloves or do you go for pogies?
I just don't mess around now. For feet, I have a big 800gram thinsulate heavy boot I wear with 2 pairs of socks, 1 of which is a heavyweight wool sock. For hands, I have a medium weight glove underneath ski gloves that are a size too big. Hands and feet are now nice and toasty when it's 0F. Which leads to the main issue with winter...
Gearing up is just a massive pain in the ass. It really isn't cold when you're out on the bike. It's all the other annoying things. Fogging goggles, spending 15 minutes putting on 2 pairs of socks, then my storm trooper boots, wool long johns, then pants, then wind pants, then wool t-shirt, sweater, windbreaking softshell, thin balaclava, thick fleece balaclava, goggles, helmet, 2 pairs of gloves. Deciding I have to pee and redoing everything before I get out the door. Then feeling like Ralphie from A Christmas Story while riding.
