rusty/corroded fasteners- should I care?
Old 06-07-19, 04:37 PM
epnnf
epnnf's Avatar
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 268 Post(s)
Liked 80 Times in 55 Posts
Screws around the stem, headset, levers etc. I seldom get caught in the rain, and when I do, I immediately dry & clean everything off. Still, some fasteners deteriorate. sup?
epnnf is offline
Old 06-07-19, 10:14 PM
CliffordK
CliffordK's Avatar
Quoted: 18349 Post(s)
Liked 4,501 Times in 3,346 Posts
Originally Posted by epnnf
sup?
We don't know without seeing photos of your bike.
Many people purchase stainless water bottle cage screws, rack & fender screws, etc.
The higher the quality of components, the less likely they'll rust. The cheaper the component, the more rust.
Many screws, bolts, & etc can take a fair amount of rust without seizing. Or, perhaps you'll see rust on the outside, but the threads will be free of rust, or cones will be rusted on the outside, but have clean races.
Of course, I've also seen bearings, races, etc all rusted up.
CliffordK is online now
Old 06-08-19, 11:23 AM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,782 Times in 3,300 Posts
Surface rust is mostly a cosmetic/aesthetic issue. If it doesn't bother you, it's unlikely to bother anyone else that pass you on the road.
If it gets to the point of pitting or eroding away the shape of the fastener, then you need to deal with it.
Iride01 is offline
Old 06-08-19, 11:58 AM
jimc101
Quoted: 453 Post(s)
Liked 104 Times in 87 Posts
Sometimes, corrosion happens, no matter what you do, for brake, With brakes (levers and the brake themseleves) I have found that it will take years of daily use to get Shimano ones to have any sign of corrosion, but with SRAM if it's overcast outside, you know rust is comming on the steel hardware.
even with in tiers of brands, some will hold up better than others, if it's just surface corrosions, it's not really an issue, it's if the part need to be removed, and the corrosion is on the threads/you unable to remove it, that it becomes an issue.
jimc101 is offline
Old 06-08-19, 12:10 PM
base2
I am potato.
base2's Avatar
Quoted: 1782 Post(s)
Liked 1,620 Times in 926 Posts
FWIW: It's good practice to grease every nut, every bolt, every threaded everything, every time.
Stainless fasteners are a bit pricier than not, but at a $ or 2, at a time it's a managable expense when it comes to maintenance time. I'd put them in the "luxury" category of bike accessories.
I wouldn't care if surface rust developes. I'd care greatly if the fastener didn't work as intended because of rust.
base2 is offline
Likes For base2:
Old 06-08-19, 12:23 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2738 Post(s)
Liked 3,381 Times in 2,046 Posts
Stainless and grease are cheap insurance for down the road.
https://www.bikeforums.net/bicycle-m...e-fixable.html
dedhed is offline
Likes For dedhed:
Old 06-08-19, 12:43 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Stock is chrome over steel you can paint them once they are tight,
if you put a wrench on , touch the paint up..
fietsbob is offline
Old 06-08-19, 06:36 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 178 Post(s)
Liked 177 Times in 101 Posts
It’s your sweat that’s causing it. Worse than rain.
Rogerogeroge is offline
lineinthewater
Bicycle Mechanics
7
03-14-16 07:57 PM
davey67
Bicycle Mechanics
8
04-24-15 01:28 PM
Dongtokes
Singlespeed & Fixed Gear
4
12-22-14 03:30 PM
riggyk
Bicycle Mechanics
3
05-12-13 09:09 PM
AceH
Bicycle Mechanics
10
01-31-11 07:14 AM
