Clickety click!
Clickety click!
I've had a click when I stand and climb hills for about a week now. Turns out my factory TREK 1.5 wheels are so weak that the rim flexes over 1/4inch and makes the sensor touch the pick up. @ 3/8's it won't do it. Should probly tighten and true the rim. What can be expected of a nice set of carbon wheels in the $1200-$1700 range?
I have a set of bontcrapper wheels too and had a similar problem. I switched groups and found that my spokes rubbed on the rear der if I stood on it in the lowest gear. The spokes were flexing that much (the old der must have sat a little farther away). If you hit a bump you could get it sitting down.
Took it to the shop and talked it over with them, they said the rear wheel had insanely low tension and he added 3/4 of a turn. Since then I only get a slight rubbing in the lowest gear if I really stand on it hard.
I would take it to a guy who knows wheels to see if it's a problem with the wheel. I'd been riding that wheel for almost 3 years and many thousands of miles. After he added tension the bike felt a little better, honestly, but the difference was tiny. The main difference was that I could use my granny cog again!
