Shimano Free wheel compatibilty advice needed
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
Hi,
I picked up a Nishiki Tri-a yesterday and it is in perfect shape with the exception that the freewheel was missing.
My question is do I need a special freewheel for SIS index shifting or will any freewheel work?
I would like to have it shift smoothly etc, and see a number on ebay right now that are inexpensive.
Will this one work SHIMANO MF-TZ20 6 Speed Index Freewheel
Will any Shimano freewheel work? Recommendations appreciated.
Thanks, Ben
Thanks, Ben
Voltaire
Voltaire
Quoted: 4210 Post(s)
Liked 3,875 Times
Pretty much any current same cog count freewheel is likely to be SIS compatible. But any SIS compatible freewheel should also state that in the specs. Even if all the docs suggest things are good the proof in in the actual trying. BTW a new cog set might also want a new chain. Andy
Mechanic/Tourist
Any Shimano SIS compatible 6 speed freewheel will work, including the one you cite.
Liked 2,182 Times
Thanks for the reply...the one I listed in the post has that strange large black ring on it (why the difference?), in your estimation, will the freewheel allow for smooth shifting. I do not know what freewheel was on there originally, any ideas what it might have been if I want to find an original one?
Voltaire
Voltaire
Liked 3,875 Times
[QUOTE=xiaoman1;20226127]Andy, a little hard to tell when buying on line...new chain yes
QUOTE]
Are you in LA, CA? I understand they have bike shops there where you can touch and get eye to eye questions answered. Andy
QUOTE]
Quoted: 1944 Post(s)
Liked 2,164 Times
Only caveat on "any" would be a TZ30, or similar, that has the largest cog of 34t. If your derailleur max cog rating is 28t, you could have problems. This is just a word to the wise if you want to replace the TZ20 someday with one that has lower gearing.
John
John
Mechanic/Tourist
Thanks for the reply...the one I listed in the post has that strange large black ring on it (why the difference?), in your estimation, will the freewheel allow for smooth shifting. I do not know what freewheel was on there originally, any ideas what it might have been if I want to find an original one?[/QUOTE]It would have originally had a very similar one, but without the black cog. The black is just marketing/advertising. You're not going to have much choice for equipment that dated, unfortunately. I tried a quick search for Hyperglide 6 speed freewheels (which would shift better) but only found an off-brand - https://www.google.com/search?q=sunl...17143638901023
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The color difference is just marketing; calling attention to the extra-low gear the cog provides.
Liked 2,182 Times
Thanks to all for the help.
Best, Ben
Best, Ben
Voltaire
Voltaire
Old fart
Liked 3,401 Times
Don't know where you're sourcing your parts, but if you're looking for used, before hyperglide there were twisted tooth SIS 6 speed freewheels.
either will work, but the hyperglide freewheel will shift much better.
John D. posted a picture of a hyperglide freewheel above. Notice the ramps cut into the side of the cogs? The original SIS freewheels didn't have this feature.
Quoted: 913 Post(s)
Liked 515 Times
Hilarious! I'm sitting in my garage this minute waiting on a local buyer fondling two twist tooth Shimano freewheels in six speed wondering what to do with them.
Liked 2,182 Times
Maybe I should take a look in my garage....Thanks again, Ben
Voltaire
Voltaire
