Bottom bracket weep holes
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
I've got a steel frame roadie stripped for painting. I notice similar later frames from Giant have holes in the bottom, I assume for drainage. My frame's bottom bracket does not have any holes and was badly rusted.
Should I drill a couple of weep holes in the bottom bracket?
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 44 Post(s)
Liked 58 Times
Rusted outside or inside the bottom bracket? If outside, no need to. If inside, you could use a wire brush to remove the rust scales and clean, and then brush in rust converter, primer, paint, grease or a combination of them to protect the bare metal. Some have a weep/drain hole, but on most late 80's-on bicycles it is to screw on a plastic cable guide. You could drill one if wanting to, but could void the warranty if it is still valid.
Quoted: 482 Post(s)
Liked 1,593 Times
Likes For BTinNYC:
Bikes: Koga Miyata GranTourer 1985, Koga Miyata Adventure 1992, Cinelli Sentiero, Giant Terrago 1993, Presto Amsterdam 1975(?), Dahon Classic III Stainless
Quoted: 38 Post(s)
Liked 37 Times
I always drill two holes on bikes that don't have any drain holes. Better to let the water out.
Likes For lubloi:
I have an old hybrid bike that I have had to replace the bottom bracket bearings on twice, they were rusted, presumably from me washing the bike... Then I noticed the holes in the bottom bracket of a road bike I picked up, I drilled out the BB on the hybrid several years ago and no issues since.
