new axle.
Old 09-24-22, 08:08 PM
flattyfattie
Bikes: kent schockwave 26 in
new axle.
i need a new axle on my bike. it has a freewheel hub, it says r&r fluid drive. it also has a2bt b1. i cannot find that anywhere. my axle is bent, and i have straightened it once. took the freewheel off to clean it. found most of the tiny 1/8 inch bearings, only had to buy about 10 of them, got that all back together and working now just the axle it was all apart and i am not sure how it goes back together and how many bearings. everything was in a bucket covered with dirt and hair. all clean now. just need to reassemble the axle. then i notice a big crack on the rim. i guess it was good practice. Does anyone knows where i can get a well-used rim? or should i jb weld it?
flattyfattie is offline
Old 09-24-22, 08:17 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Your whole post...you're kidding, right? JB Weld? Zero details about size of rim, drilling...nothing. No details about the axle either. How on earth can anyone help you?
cxwrench is offline
Old 09-24-22, 09:45 PM
flattyfattie
yes, i was kidding about the jb weld. the axle is 7 inches and the rim is a 28-inch rim with a freewheel gear system made by r&r the only no. i can find is2bt b1. i am new to bikes i don't know the terminology or measurement requirements. i am new to this stuff give me the befit of the dought. i am learning.
Old 09-24-22, 11:09 PM
Juan el Boricua
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 44 Post(s)
Liked 58 Times in 46 Posts
See if there is a bike coop in the WA area, bring in your rim so that they can see the wheel size and let them help you find a suitable replacement; shouldn't be expensive. One way to learn the basics might be volunteer hours at said coop, and you'll be able to not only help yourself but others that might be "in tour shoes" in the future
Juan el Boricua is offline
Likes For Juan el Boricua:
Old 09-25-22, 06:30 PM
Hondo6
Bikes: Yes
Quoted: 550 Post(s)
Liked 672 Times in 464 Posts
1/8" bearings in a rear freewheel hub?
Even a Helicomatic uses larger balls, and they're tiny compared to the normal 1/4".
Sounds like he may have disassembled the freewheel itself. I believe freewheel internal bearings are 1/8".
Hondo6 is offline
Likes For Hondo6:
Old 09-25-22, 07:16 PM
cxwrench
cxwrench's Avatar
Bikes: lots
I think you really should take it to a bike shop. Sorry, but I doubt (see what I did there?) you're going to be able to fix this on your own. Maybe a co-op will teach you while they fix it. I agree w/ the others, you've taken the freewheel apart, possibly as well as the hub. No hubs have bearings that small.
cxwrench is offline
Old 09-25-22, 11:42 PM
well biked
well biked's Avatar
Quoted: 140 Post(s)
Liked 163 Times in 89 Posts
Exactly.
well biked is offline
