looking for a pair of dummie brake levers..
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1085 Post(s)
Liked 1,822 Times
Is that what we call them?
I know Dia-Comp made some. Thought I'd ask these two questions…..
1, does anybody have a set they want to sell? I know I can look on ebay, but would rather ask here first.
2, I have a drawer full of Italian brake levers, including some Campy with scratched tips. Does anybody know how to convert them to dummy?
I could shorten them to just below the branding, but how to make them stay in place, or at least not flop about.
Thanks all,
Robert
New COLNAGO tandem owner (I'm new, not the 'Nago which was built for the 1980 olympics that America's boycotted.)
Thanks all,
Robert
"Leave the gun. Take the Colnagos."
Quoted: 2496 Post(s)
Liked 739 Times
If I had a drawer full of vintage brake levers I wouldn't shell out good money for the Dia-Compe dummy levers. I'm not sure I would even bother trying to shorten the lever blades. As for immobilizing the blades ... just go for it. Pack the area with something. You're not trying to make it rigid, you're just keeping it from flopping, like you said. You'll come up with something.
Likes For Leisesturm:
Liked 1,822 Times
Headed to Tacoma Screw. I think I can get a spring to fit in there somehow.
I'll post results.
I'll post results.
Likes For Robvolz:
Quoted: 2487 Post(s)
Liked 2,956 Times
Removal of the lever blade, if that's what it's called, so that only the body of the lever remains is usually easy.
Liked 1,822 Times
agreed, but then there is a gaping hole.
Likes For Yamato72:
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
Thanks all,
Robert
New COLNAGO tandem owner (I'm new, not the "Nano which was built for the 1980 olympics that America's boycotted.)
Thanks all,
Robert
Liked 1,822 Times
and you are in San Diego!!
I was just down there for the big swap meet at the velodrome
I appreciate your offer. I'm experimenting with both a skinny screw that locks the lever in place. Plus, the little springs from Shimano 105 levers if I swap the grub screw on the Campy with one with a head to hold the spring in place.
I already cut down a scratched to hell campy lever set, so let me play around a bit more before I go Dia-Comp.
I do appreciate the offer.
Robert
Robert
Quoted: 346 Post(s)
Liked 175 Times
Robert
Robert
Quoted: 4806 Post(s)
Liked 3,932 Times
If you know someone with an ultrasound, you could clean the levers with it then dribble/pack epoxy into the hinge. Clean enough and enough epoxy and that lever or lever base isn't going anywhere.
Likes For 79pmooney:
Liked 1,822 Times
I wish I could find a cone shaped nut to go in the cable head hole that looks like this
Are these what you are looking for? If interested, PM me. For the cone shaped nut you show above, this is something that might be 3D printable in plastic if it does not need to provide a super strong clamping force.
(Sorry about the messy worktable, I am in the middle a few projects)
Liked 1,822 Times
those are them!!
