Are there Single-Speed or Fixed-Gear bikes that does not have coaster brakes?
First let me ask a noob question...what's the difference between a fixed-gear bike and a single-speed? Does one have coaster brake and the other doesn't? I want to buy a single gear bike meaning there is only one gear and no shifter, but I want hand brakes/brake levers on the handle-bar. Also I don't want coaster brakes, I want the pedals to NOT follow the wheel as it spins...is there such a bike? Or all fixed-gear and single-speed bikes have coaster brakes? I don't want to be flying down a hill and lose control of the pedals and not be able to brake...
A coaster brake is different than a fixed gear. A fixed gear has the rear cog attatched directly to the wheel, so however the wheel is spinning(speed and direction) is related directly to the speed of the pedals moving. So when the bike is moving forward so are the pedals. You cannot coast.
A coaster brake is an internal mechanism that causes the brakes. It has the normal freewheel mechanism, so that you can coast. But when you pedal backwords it causes the internal parts cause the hub to stop spinning which means the whole rear wheel stops.
What you are looking for is called just a single speed. Usually they are similar to road bikes, but with one gear and normal brakes. You have lots of options in all sorts of price ranges and qualities. Its a really open market depending on what you want, and how much you want to pay.
Bikes: klein quantum, litespeed tuscany, bianchi pista concept, centurion comp ta, centurion super le mans, traitor ringleader
ok, here it goes:
singlespeed / FREEWHEEL bikes have the ability to coast (ie peddles wont spin when bike is moving). they NEED a brake to stop. Coaster brake bikes are singlespeed/freewheel, but instead of a hand brake they have the coaster hub brake.
FIXED GEAR bikes (technically also singlespeed since they have only one gear as well, but when people say singlespeed they are usually referring to coasting, freewheel bikes) are bikes where, as you say, "the pedals follow the wheel as it spins"
there definetly freewheel singlespeed bikes without coaster brakes, they just have hand brakes for the front and rear (well, some people have just front but its safe to have both front and rear)
Radac!
Bikes: Visp with way better parts than a frame,2010 fuji track pro, motobecane phantom cross outlaw
fixed gear is fixed
single speed is a single gear with flywheel
coaster brake can be had on anything
so can normal brakes
also, MOST fixed gear bikes have what is called a "flip flop" hub, so you can have a fixed gear cog on one side, and a freewheel cog on the other......so many fixed gear bikes can be coasting singlespeed freewheel bikes by just flipping the back wheel around.
Quoted: 2952 Post(s)
Liked 3,106 Times
And if you have a freewheel, you should have at least one brake. (This should be obvious, but judging from some of the Midtown hipster bikes I see around here, it's apparently not obvious to all.)
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
so, now that has been answered. are you going to buy a singlespeed or convert an existing bike?
cheapest/easiest conversion is to just remove the shifters. done.
So tragically hip.
Bikes: 2009 SE Premium Brew, 2001 GT Interceptor, 2010 Motobecane Fantom 29
Does anybody else think the OP is trolling?
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
One of my favorite SS rides had coaster on the back and caliper up front. Some ol' sixties rig.
i'm going to convert my existing bike to a SS but if I remove the shirfters the rear wheel is still heavy with the rear wheel derailleur. How do I take that off? do I need to buy a new wheel with a single derailleur ?
Bikes: everywhere
Liked 7,695 Times
Awww, I like the yo' mama action better!
Nü-Fred
Bikes: Torelli Tipo Uno (stolen), Peugeot Nice, Mercier Kilo TT
remove shifters.
remove derailleurs.
shorten chain.
read: https://www.sheldonbrown.com/singlespeed.html
g'luck
for the wheel, depending on your current hub, you may be able to remove the old freewheel cogs and replace with spacers and single freewheel.
otherwhise your options are buying a new hub and relacing the spokes or buying a new wheel. for me, at this point i just found a better bike on ebay
you dont use a derailleur with singlespeed.
well, the derailleur could be used as a tensioner if you have vertical dropouts
https://www.sheldonbrown.com/singlespeed.html#vertical
