Bike Rack Clearance Question
Old 04-23-15, 03:13 PM
dmsone
I have installed a bike rack that is for an up to 700cc tire on a 29er hardtail and there is exactly 1/2" clearance between the Tire (which is new and properly inflated) and the lowest point on the bottom side of the bike rack.
Is this enough clearance or will I run into problems.
If this is on the wrong section I apologize.
Thanks is advance, I will try to test ride it this weekend.
dmsone is offline
Old 04-24-15, 07:04 PM
dwmckee
dwmckee's Avatar
Quoted: 427 Post(s)
Liked 339 Times in 229 Posts
You are fine as long as you do not put something like a jacket on the rack that can hang down between the rack bars and contact the tire. You likely have more clearance around the rack than you have around your chain stays. seat stays and brake bridge.
dwmckee is offline
superjoe95
Commuting
6
03-02-19 02:26 PM
honey locust
Touring
7
07-15-16 03:02 PM
popsicleian
Commuting
26
03-25-14 08:50 PM
unterhausen
Framebuilders
1
03-05-11 08:12 PM
morphius
Road Cycling
16
10-24-10 07:43 AM
