Mounting a Phone in an Otter Box
I am having a heck of a time finding a phone mount that will fit my iphone 6s in the Otterbox case. Ideally I would like one that mounts to the steering stem. Any thoughts on what I might use?
2023 Salsa Journeyer
2023 Rad Rover 6
1980ish Raleigh Marathon (Vintage Steel)
2006 Trek 820 (Captain Amazing) RIP
2010 Specialized Tricross (Back in Black)
2008 Specialized Roubaix RIP
"I'm built like a marine mammal. I love the cold! "-Cosmoline
"MTBing is cheap compared to any motorsport I've done. It's very expensive compared to jogging."-ColinL
Rides:2023 Salsa Journeyer
2023 Rad Rover 6
Quoted: 103 Post(s)
Liked 28 Times
I have tried this with a couple different things and ultimately decided that if I was to mount the phone it would need to be removed from it's case.
Perhaps this: https://www.rei.com/product/884717/t...unt-iphone-66s
2023 Rad Rover 6
2023 Rad Rover 6
Quoted: 4560 Post(s)
Liked 2,802 Times
A Delta mount designed for a phone larger than the iPhone 6s might fit around the Otterbox. I use a generic protective edge bumper around my iPhone 4s (edges only, doesn't cover the front or rear) and it fits in my Delta mount. A bit snug but it works.
The Delta mount should have options to clamp around the handlebar (which I use on my bikes with quill stems) or threadless stems.
mosquito rancher
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
About the only thing I found that worked over a long time was the ram mount products
Location: born in DC, . . . . . . . . . . . raised in MD, living in the OC. . .
Bikes: TREK 2300 carbon Frame|-&-|LEADER 735T
Quoted: 5 Post(s)
check out my brava bianchi in this thread
https://www.bikeforums.net/classic-v...hangeable.html
if you take the phone out of the case, drill two holes with the width distance of your stem in the middle of the 2 holes, take a heavy duty zip tie, dont use the thin ones, fasten the case to the stem, plugin your phone into your case.
you can also make two sets of holes near the top and the bottom of stem alignment.
i have found that me using a 1$ case for my iphone 5 that i dont use anymore, has been the best bike cellphone mount over all the other products and expensive click in cases.
J.
Hello
