Found product: French 22.0 threadless stem adapter
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
While continuing my elusive hunt for a black French-diameter (22.0) quill stem with 100mm-120mm reach, I stumbled across this product on the auction website:
https://www.ebay.com/itm/233467408083
Note: I have no affiliation to the seller ("hunkyshaw"), but as someone that's had to sand down shafts to make things fit in a French steer tube in the past, I can appreciate someone is making pre-machined adapters for folks, although I don't need or want to go threadless in my case. It looks like this seller is setup to manufacture, and I like it doesn't look horribly chronologically-off when installed...
Likes For francophile:
Quoted: 7351 Post(s)
Liked 2,478 Times
There you go. That could work!
PM me your cotters
Liked 590 Times
Except I'm not looking to go threadless and, in my case, I'm going black.
I have no less than half a dozen 22.0 quill stems in the shop, probably closer to a dozen. Just none in black.
Tonight I'm going to spend my evening reading up on how to anodize at home. Maybe I can just strip ano off one of my silver stems and re-ano it black. I seem to recall it's a really messy and/or dangerous process though, both due to electricity and chemicals/gasses for removing old ano.
Quoted: 767 Post(s)
Liked 1,898 Times
Yes! I've had their website bookmarked for future possibilities:
https://www.bandlbicycles.com/produc...dless-4978.htm
Have not ordered anything from them, so no experience to share.
PM me your cotters
Liked 590 Times
Liked 2,478 Times
Likes For noglider:
PM me your cotters
Liked 590 Times
I may buck up and just use one of my silver stems. Just love the way this specific bike looks with a black stem.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Likes For joejack951:
I bought one of those adapters from that seller a few years back. It's been accurately turned down, and is a high quality piece. At the time, I hadn't been riding for a while, and wanted to experiment with a more casual positioning on my PX10 build. It worked great for that. At some point it was always the plan to put a quill stem on, but I've not gotten around to it yet. It doesn't really stick out too much, if you're not looking for it. ( I guess that's arguable, )
I have no doubt finding a black French 22.0 stem is going to be difficult. By the time black stems were in fashion, French stems were very rare. If you are patient enough, one might eventually turn up. If you are on a shorter time schedule than that would entail, I agree with the others, get a stem, polish it up (sand down if necessary), and have it anodized or anodize yourself.
You've probably seen it, but check out Caswell plating.
Likes For Salamandrine:
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 430 Post(s)
Liked 476 Times
Have had one of those B&L 22.0mm threadless adapters for several years.
Fit and finish are solid, no complaints...except that you're threadless!
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Thin anodizing is clear. As the coating gets thicker it becomes darker gray then brown as in the color of "hard anodized" rims. The dark anodizing can be as much as .005" thick.
Anodized surfaces are porous and in most cases the black color is a somewhat permanent dye that has been treated afterward with a hard sealant. Same thing with other anodized colors.
An anodizer may be willing to throw a stem or other part into a batch of items being dyed but they also may be reluctant because the part could contaminate their process and result in splotchy finishes.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
