Go Back  Bike Forums > Bike Forums > Advocacy & Safety
Why do so many drivers think speeding is safe?
Advocacy & Safety Cyclists should expect and demand safe accommodation on every public road, just as do all other users. Discuss your bicycle advocacy and safety concerns here.
Old 12-02-23, 02:06 PM
Korina
Happy banana slug
Korina's Avatar
Quoted: 1533 Post(s)
Liked 1,530 Times in 917 Posts
AAA survey says it all.
Korina is offline
Old 12-02-23, 03:43 PM
tomato coupe
Quoted: 3957 Post(s)
Liked 7,310 Times in 2,950 Posts
Originally Posted by Korina
The title of the article ("Why So Many U.S. Drivers Think Speeding is Perfectly Safe") is very misleading, and actually contradicts the results of the study that it is based on. For instance, the article states:
Only 46.5 percent of U.S. drivers consider going more than 15 miles per hour over the speed limit on the freeway to be "extremely" or "very" dangerous
Nearly 80% of those surveyed consider driving more than 15 mph over the speed limit on the freeway to be "
extremely", "very", or "somewhat" dangerous. 17.4% stated it was "slightly" dangerous, and only 2.7% stated it was not dangerous at all. So, although the statement in the article is correct, it misrepresents the overall results, which is that the vast majority of people do consider speeding to be dangerous.
tomato coupe is offline
Bald Paul
Bald Paul's Avatar
Quoted: 827 Post(s)
Liked 1,660 Times in 784 Posts
As a retired automotive regional technical specialist, I can tell you that there are a lot of drivers that think speeding, tailgating, driving distracted, etc are all okay, because they are sold on the advertising that the systems in their vehicles (automatic braking, automatic lane correction, etc) will keep them from crashing. Even if they do crash, the safety systems (SRS Airbags, primarily) will keep them from being injured.
It's only when they slam into that stout, immovable object at a high rate of speed that they learn that all the systems in place won't overcome the laws of physics and stopping suddenly at a high G force while relying on airbags alone and not wearing a seat belt (SRS stands for Supplemental Restraint System) can result in some pretty painful and long lasting physical consequences. Believe me, I've seen it too many times in my career while investigating crash claims.
Bald Paul is offline
Likes For Bald Paul:
Old 12-02-23, 05:27 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10444 Post(s)
Liked 11,924 Times in 6,105 Posts
Perhaps a more telling survey, which I heard about years ago but can't be bothered to look up, found that 90% of drivers think they're better than average at it. Like Lake Wobegon, all the children are above average.
So, the answer to the question is, "Hubris".
genejockey is offline
Likes For genejockey:
Old 12-02-23, 07:27 PM
Steve B.
Quoted: 3243 Post(s)
Liked 2,091 Times in 1,183 Posts
Which is remarkable as I m always wondering what some of these people do for a living, because judging by how they drive, they appear to be the stupidest people on the damned planet.
Steve B. is offline
Likes For Steve B.:
Old 12-02-23, 07:47 PM
Korina
Happy banana slug
Korina's Avatar
And a bit over 40% admitted to having done it in the last month. And there's this: 'And because those numbers are self-reported by drivers, researchers say the reality is likely even worse.'
Nearly 80% of those surveyed consider driving more than 15 mph over the speed limit on the freeway to be "extremely", "very", or "somewhat" dangerous. 17.4% stated it was "slightly" dangerous, and only 2.7% stated it was not dangerous at all. So, although the statement in the article is correct, it misrepresents the overall results, which is that the vast majority of people do consider speeding to be dangerous.
Korina is offline
Old 12-02-23, 08:25 PM
StanSeven
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times in 1,470 Posts
Let’s tie this into A&S and cycling. The survey is talking about freeway speeds
StanSeven is offline
Old 12-02-23, 08:32 PM
Rick
Quoted: 626 Post(s)
Liked 401 Times in 277 Posts
I live in the high desert and the roads between cities are 45 mph, 55 mph and 65 mph speed limits and most speed above the limit.
Rick is offline
Old 12-02-23, 09:08 PM
Steve B.
I commuted by car in Brooklyn and parts of NYC, where they artificially set the speed limits on the highways about 5-10 mph lower then needed so as to increase the cost of a speeding ticket. Pretty much nobody pays attention to 50 and it’s typical to be the slow poke doing 60. The local streets are mostly 25 mph, also about 5mph lower then typical communities in NY State, but IMO a good thing as they have a huge problem with people going much faster then 25 and mowing down pedestrians and cyclists, so 25 I’m OK with. They need to be installing speed cameras in the highways and giving out tickets to the morons who think 75-80 in a 55 zone is appropriate.
Steve B. is offline
Old 12-02-23, 09:24 PM
tomato coupe
That doesn't change anything. The article totally misrepresents the results of the survey. End of story.
Old 12-02-23, 09:44 PM
TC1
Quoted: 360 Post(s)
Liked 129 Times in 84 Posts
A large part of the answer is because many drivers drive on interstates that were designed for 75 mph speed limits, but are posted at 55 or thereabouts. Many are also old enough to remember the NMSL, which artificially limited legal speeds well below roadways' design speeds. So many drivers have been unintentionally trained to regard speed limits with skepticism, or worse.
Also, it is actually impossible to crash due to speed alone, without violating at least one other rule of the road. Lazy cops cite speed as the cause of almost all crashes, but that's because they are constitutionally opposed to thinking and/or working. So, technically anyway, speeding is safe if the driver can manage to obey all the other rules.
TC1 is offline
Likes For TC1:
Old 12-02-23, 10:35 PM
Russ Roth
Quoted: 1088 Post(s)
Liked 1,028 Times in 724 Posts
Is it possible to do 80 on a Brooklyn freeway most of the time? I've had a sat morning or two when leaving for TTown when the beltway was nearly clear and 80 was possible but otherwise I'm happy when everyone manages to flow at 45.
I tend to be at the extreme end of things, driving around neighborhood roads I tend to stick to about 20mph and annoy people because I won't go faster. On the main roads of the town I often do the 30mph listed speed. On the highways/freeways I do 70-75 unless they're really clear with no real traffic then I have no problem doing 80-85 unless I have kids in the car, in which case its 65 maybe 70 if the roads are clear. And if its a truly deserted highway, with absolutely nothing in sight, and I'm in the miata, then I've got no problem stepping on it.
Russ Roth is offline
Old 12-03-23, 01:57 AM
Korina
Happy banana slug
Korina's Avatar
The safest route between Arcata and Eureka is on the highway between them and yeah, I didn't notice it was specifically about freeways. My bad.
Korina is offline
Old 12-03-23, 04:23 AM
TMonk
Not actually Tmonk
TMonk's Avatar
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times in 1,660 Posts
I'd much rather take Old Arcata road. Way more sccenic/pleasant. Gonna take longer and you have to climb up into Myrtletown, but worth it! Also I'm not sure that the 101 is safer.... faster cars with more traffic, but a wider shoulder. So there's a trade-off.
HSU alum here, class of 2010. I do miss the riding up there, esp. the Maple Creek / Butler Valley loop, Fieldbrook loop etc.
"Your beauty is an aeroplane;
TMonk is offline
Old 12-03-23, 06:41 AM
work4bike
work4bike's Avatar
Quoted: 3781 Post(s)
Liked 1,049 Times in 793 Posts
I'm sure most people, including cyclists speed. Even cops speed. I've been passed by motorists going much faster than me with a very nice bike on their bike rack.
work4bike is offline
Likes For work4bike:
Old 12-03-23, 07:06 AM
I-Like-To-Bike
Been Around Awhile
I-Like-To-Bike's Avatar
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,538 Times in 1,047 Posts
Only 15 posts before anything about cyclists or cycling was even mentioned, unless rants about evil and stupid motorists are considered bicycle A&S related.
I-Like-To-Bike is offline
Likes For I-Like-To-Bike:
Old 12-03-23, 07:10 AM
PeteHski
PeteHski's Avatar
Quoted: 4420 Post(s)
Liked 4,873 Times in 3,017 Posts
Speeding can be safe or dangerous depending entirely on traffic and road conditions. It is often far more dangerous to be driving too slow on a motorway. It always amazes me how many drivers like to mix it up with tailgating HGVs at around 60 mph.
So yeah I speed a little on the motorway when it’s safe and it often is. The biggest risk is getting a ticket.
PeteHski is online now
Likes For PeteHski:
Old 12-03-23, 09:00 AM
Bald Paul
Bald Paul's Avatar
Quoted: 827 Post(s)
You're kidding, right? How do you explain (as an example) a crash during a qualifying run at the Indy 500? Professional driver, a car that is meticulously maintained and set up for the conditions, a track surface that is clean and free of bumps or holes, running out there with no other traffic? There are things called physics, limits of traction, aerodynamics, etc. Too much speed and you exceed those limits, and bad things happen.
Old 12-03-23, 09:09 AM
Steve B.
Originally Posted by Russ Roth
Is it possible to do 80 on a Brooklyn freeway most of the time? I.
Well of course. 7AM on a Sunday, going down the Belt ?. Just watch out for cops as that's an expensive excessive speed ticket (30 over) as well as possible reckless driving. The actual highway is designed for such speeds though.
Steve B. is offline
Old 12-03-23, 11:00 AM
flangehead
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 573 Times in 332 Posts
AAA has done these studies annually for many years. I have found them useful. (2022 study is published in 2023, etc.)
The 2022 summary is at https://aaafoundation.org/wp-content/...Index-2022.pdf
The full report is at https://newsroom.aaa.com/asset/traff...ndex-nov-2023/
I will say any article I read which doesn’t link to the x they’re addressing has low credibility with me.
flangehead is online now
Old 12-03-23, 11:25 AM
jon c.
Quoted: 1591 Post(s)
Liked 1,020 Times in 572 Posts
The safest speed is the average speed, which is most always higher than the posted limit.
jon c. is offline
Likes For jon c.:
Old 12-03-23, 12:04 PM
TC1
Quoted: 360 Post(s)
There are no rules of the road applied to solo qualifying on a race track.
Make some effort to understand the point before continuing your inane attempt at discussion.
TC1 is offline
Old 12-03-23, 12:15 PM
john m flores
Rider. Wanderer. Creator.
john m flores's Avatar
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 395 Post(s)
Liked 785 Times in 378 Posts
Are you sure that the Belt Parkway was designed for 80mph? It's an older road with pretty narrow lanes, poor shoulders, tight underpasses, and short ramps. By modern safety standards, it's not a great road
john m flores is offline
Old 12-03-23, 12:20 PM
Kontact
Kontact's Avatar
Liked 1,568 Times in 1,030 Posts
The problem is that we are all perfectly aware that speed limits are somewhat arbitrary, that the police can ticket you for not maintaining above-limit traffic speed and that police and fire demonstrate all the time that speeding is safe and perfectly acceptable when "necessary".
With all that ambiguity, of course people speed. It's just a question of how much and in what circumstances.
Kontact is offline
Likes For Kontact:
Old 12-03-23, 12:33 PM
Steve B.
I was thinking of the section from about the Sunrise overpass all the way down to Flatbush Ave., it’s an interstate quality road.
Steve B. is offline
