How to remove a stuck BB?
Kilo TT
I am replacing the cranks and BB on my Windsor Hour, and noticed that the drive side of my BB is stuck to the frame. I already removed the non drive side, but cant seem to budge the drive side. I read somewhere that they sometimes loctite it to the frame, is this true? I am turning it clockwise to loosen, correct? Its just the stock BB that came on my bike..
Quoted: 1572 Post(s)
Liked 643 Times
What kind of bottom bracket?
There are generally two problems.
The first is getting your BB remover to stay in contact with the bottom bracket. If it's a cartridge bottom bracket you can usually find a bolt to hold your BB remover in place. Also, a genuine Shimano BB tool, which sets closer to the centerline of the bike frame, works much better than the Park equivlent.
The second is getting enough torque on the BB. I've had good luck chucking my BB remover vertically in a sturdy vice and using a helper to thread the bike onto it. Take a minute to determine which way you need to go and use the whole bike frame as a lever. This has never failed me and I've never damaged a frame.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Kilo TT
Still kicking.
If that fails, a little penetrating oil and let sit for 24 hours.
Appreciate the old bikes more than the new.
