Question - Campy Nuovo Record Rear Derailleur
Bikes: LESS than I did a year ago!
Quoted: 70 Post(s)
Liked 6 Times
Does anyone know whether a 1970 model Nuovo Record Rear Derailleur has a date stamp? It seems, as I research it, that is about the time that Campy started putting date stamps on them...but not sure if it was in 1969, 1970 or 1971...
Quoted: 3464 Post(s)
Liked 2,831 Times
1970
And Don’t be confused by the no date stamp on the ‘85 and sometimes later models of NR Rear Derailleurs. These are obvious because of the difference in pivot pins. Early had alloy riveted rods, newer had SS(?) rivets with hollow ends. Too bad Campy didn’t use their newer style threaded pivot pins as seen on Carbon Front plate models.
Quoted: 1372 Post(s)
Liked 1,752 Times
I have had a NR rear derailleur with a 68, 71, 72, 73, 74, 77 and a few in the 80s date stamps. I have yet to run across one with a 70 stamp. I also seem to remember having one with a 69 stamp but not sure anymore. I did have a picture of the 68 but it is at the summer cottage, buried beneath the cottage, under a LOT of snow.
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,100 Times
Do these threads have date stamps?
Likes For Spaghetti Legs:
feros ferio
Quoted: 1393 Post(s)
Liked 1,330 Times
Confirmed -- mine (on a 1982 Bianchi with frame built in late 1981) says PAT 80.
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 377 Post(s)
Liked 1,090 Times
Edit and PS - is the picture or the derailleur under the snow?
Likes For styggno1:
Liked 1,752 Times
Are you sure you have had a NR rear derailleur with a "68" stamp?
pinch1967
10
05-09-11 04:27 AM
