chain tensioner vs no tensioner
commu*ist spy
I want to build a igh bike for touring and commuting and have the option to use a track style frame or a vert dropout frame. I prefer the vertical dropout bike because it's a lot lighter. I'd just like to know how the tensioner feels compared to a true singlespeed. I read it's not as smooth. There's a little friction. Less responsiveness. I'd like to get a clearer perspective on the pros and cons of a tensioner. Thanks
Chain tensioners are for people that are too lazy to figure out how to properly cypher the correct length of chain. There's many ways to figure this out. Google chain length calculator and you will get many avenues.
Even with a SS, I would rather have a well fitted chain with little to no slack than a tensioner.
commu*ist spy
my mistake, I must have overlooked the part in your original post where you said vertical drop out. I could choose to be an ass here but I'll leave this image instead.
The reasons for avoiding it are simple: it sucks. Vertical drop outs are the cross section love child of lawyers and cheap bicycle manufactures. If I had a vertical drop out bike (which I do) I would leave it geared (which I did).
commu*ist spy
OK I'm still looking for the answer to my question. I see there's an aversion for vertical dropouts. Are any of the reasons for avoiding vertical dropouts and tensioners legitimate from an utilitarian point of View
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
You say this bike is intended for touring and commuting. If you plan on installing mudguards (a good idea on any touring or commuting bike, IMO), vertical dropouts are preferable to rear-facing track dropouts (hard to get the wheel out with track dropouts and mudguards). Is there some reason you aren't considering forward-facing horizontal dropouts? They work well with mudguards and obviate the need for a tensioner.
Bikes: 1/8th inch Scrambler FG, Masi Coltello FG
Personally I think vertical dropouts were designed to accommodate gears.
By using a vertical dropout frame as a singlespeed with a chain tensioner, doesn't it defeat one of the main purposes of singlespeed bikes? Seems the more crap you add to the drive train the more crap can break.
Not to mention the loss of efficiency and added friction. Sure it can be done, but if you want singlespeed just get horizontal dropouts and go enjoy the ride. My $.02
Pirate/Smuggler
I ... have the option to use a track style frame or a vert dropout frame. I prefer the vertical dropout bike because it's a lot lighter.
Quoted: 17 Post(s)
Liked 9 Times
I tried a conversion like that, and couldn't stand the noise from the tensioner (alfine one). I get a nice chainline, with no noise at all. As soon as I put the tensioner on, a LOT of noise. Tried a lot to get a silent working, but nothing works. Instead of trying again, with other tensioner, I just bought a horizontal dropout bike. Maybe I was unluck, but will not try again...
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
There will be some friction and it won't be very smooth unless maybe you replace the pulleys with nice ceramic bearing'd ones and used a nicer grease.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Agreed. Not very nice.
OP, I used a tensioner on a single speed one time and was less than impressed with the results. Others may be happy with it. Since it sounds like you already have the frame, give it a go. If you don't like it you're not out much money or effort.
Night Shift answered your question in the second post in this thread. The Magic Gear can be annoying (IMO) for a singlespeed because you might not get exactly where you want but bc you have an IGH you will never notice.
A. Figure out the Magic Gear
B. Obtain proper Chain ring and Cog
C. Profit
or
A. Use a tensioner
B. Break tensioner while touring from <undisclosed> to (<undisclosed> + 500 miles)
C. Hitchhike
Liked 941 Times
I used this unit on a nice Bianchi that was found in the trash. At $25 it's not a lot of money in my book.
Effort wise was even less. It took me longer to properly re-dish the wheel, than to install and adjust the tensioner.
You claim that tensioners will break... apparently in short order too. If this is fact, I am not aware of it. Show your evidence.
The Forte unit I used had good reviews. My main objection to it was aesthetics, and a little more drivetrain sound.
commu*ist spy
Absolutety - it's another part on your bike that will get screwed up. If you are touring on this bike what are you going to do when the tensioner breaks?
C. Profit
or
A. Use a tensioner
C. Hitchhike
C. Profit
or
A. Use a tensioner
C. Hitchhike
commu*ist spy
The math on the money, or the effort?
Quoted: 399 Post(s)
Liked 274 Times
If you absolutely must have a vertical dropout bike there is nothing wrong with putting a chain tensioner on it if you are unwilling to spend for eccentric solutions. Don't get me wrong, when I buy a new frame that's intended for SS/FG for myself now, I get one with horizontal do/trackends. But since you seem to have your mind made up...
I have experience with tensioners from converting geared mountain bikes to singlespeed so have used quite a few different tensioners over the years, with mostly good results. If the doofuses here telling you that a tensioner will automatically fail think they put their road bikes through anything near how I treated my SS MTBs, they are delusional - the things held up pretty damn well to the beatings I gave them. I am not saying I never had a failure, but lots of other components went bad on me in the past as well. Should I never buy anymore of those because I busted one?
I've had tensioners that pushed the chain from above and from below, but my particular favorites worked up by the chainring, attached to the bb. There was one from YESS, and also one from Blackspire that was very inexpensive but worked fantastic.
Or...there is always this
Liked 941 Times
Singlespeed Bicycle Conversions
Bikes: Salsa Fargo Ti, Cannondale CAAD9, Carbonello Fixed Gear, Specialized Epic Disc
Quoted: 39 Post(s)
Liked 16 Times
You could keep the vertical dropout bike and use an ENO eccentric hub. It has enough of adjustment to allow for a few teeth differences in cogs.
The math on starting with two frames, one vertical one horizontal, building one up and deciding you don't like it and then building up the other instead. Don't assume that all of the parts will fit each bike. Right out of the gate you are buying new no-turn washers and probably installing new cable and full housing.
why should a tensioner be any more likely to break than a derailleur? and I'm not planning to use one of the spring tensioners, but one of those where you tension it manually and tighten it. It's simpler, and more robust. and if I choose, I can carry a 20t and a 16t, depending on the wind and terrain, and not worry about a thing, while getting as much gearing range as a 34/28 to 53/11 hypothetical derailleur setup. taking the wheels off will be a pain in the ass, but that's the only real draw back i see.
And I did not say it is more likely to break.
I have no tensioner on my horizontal drop-out IGH bike and I am totally glad I did it that way.
Bikes: '84 Basso Pista, Masi Heinz '57 SS beater. Couple Stingrays...
If you are going to be changing your rear cog it's a no brainer, not even worth asking the question. Track ends cannot take up four teeth worth of slack (but of course you could change the length of the chain).
Calamari Marionette Ph.D
Bikes: 2008 Surly Cross Check, 2010 Fuji Track Comp
Quoted: 255 Post(s)
