Grease for seat post
Quoted: 2026 Post(s)
Liked 1,096 Times
The same stuff I use for my wheel bearings, etc. Actually ANY grease you have around will work for keeping the seatpost from sticking. The exception is a carbon seatpost in a metal frame where "carbon assembly paste" is a better choice.
Bikes: 1993 Fat Chance Wicked Lite, 1997 Spooky Mothership, Litespeed Obed, 1996 Cannondale R900, 1995 Diamondback Vertex. Note: None of my bikes are original spec. All are custom build ups.
I use white lithium for my aluminum and steel bikes and anti seize on my Ti bike. Never had an issue with a post getting stuck.
Quoted: 1438 Post(s)
Liked 1,092 Times
+1 Just remember to pull the post, clean and reapply the grease/assembly paste every few months or so.
Constant tinkerer
incazzare.
Whatever I have. I have a tube of Phil grease and a tub of some random automotive grease. I use whichever is at hand.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Non omnino gravis
I use good old anti-seize, because that's what I want the post to do. Not seize.
But as everyone else has said, anything will work.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Yes... Same that I use for bearings, same tub.
slipping with a 300# riser is different than slipping from a loose fit between post and frame..
Liked 1,096 Times
You've been very lucky or you remove your seatpost frequently enough to avoid rather than prevent the problem. We get way too many threads here on how to remove horribly stuck seatposts to ever think it can't, and won't, happen. A properly fitting seatpost tightened securely will not slip even if greased thoroughly.
Bikes: '85 Bridgestone 400
CRC SL3121 Marine Boat Trailer and 4 x 4 Wheel Bearing Grease. On Amazon. I have had to torch my seat post twice now. Must be something more common with vintage bikes like mine?
Anyways Marine Bearing Grease is waterproof and really cheap.
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
Frances Seatpost Grease. The finest pure seatpost grease made from organic materials and guaranteed not to stain your clothes.
Quoted: 4806 Post(s)
Liked 3,933 Times
Calamari Marionette Ph.D
Agree. I built a bike in May of 2002 and greased inside the seat tube with high quality bearing grease. The saddle height was never adjusted for 12 years. I took the bike apart last summer for a new paint job and the post slid right out, still covered with a greasy film. Cleaned the inside of the tube with a long allthread wrapped with a rag. Guess what came out? Lots of clean grease.
Depends on post/frame material. For metal posts in metal frames I uses Phil Wood or any other good quality grease. For carbon posts or frames I use carbon assembly paste and also for aluminum into aluminum if the post is slipping. If the post is slipping I also break out the calipers since I've encountered some undersized seat posts.
incazzare.
Quoted: 29 Post(s)
I've been riding bicycles for 50 years, never lubricated a seatpost or had one stick in the least.
I have had trouble tightening them enough to prevent slipping. I had a period when it slipped about 2mm/month. I broke the bolt trying to get it tight enough - keep it around as a souvenir. I solved that by cleaning the inside of the seat tube and the post thoroughly, consistent with grit or corrosion lubricating the surfaces.
Wouldn't an anti-seizing stuff serve this alleged purpose better?
Constant tinkerer
It sounds like you're using a seat post that's too small. That's why you're having problems with it slipping (and broken bolts) and yet have never suffered a stuck post. A good fit has slight friction as the post is inserted into the frame. Grease delays the galvanic corrosion that occurs between the two parts.
incazzare.
