Broken Spoke
Broken Spoke
I need to replace a broken spoke on the rear wheel of my Giant Escape 0. Please tell me which one I need to buy - the rim is Giant S-X2.
Also, I will need to remove the cassette first so I need advice on the tools for this.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Quoted: 2026 Post(s)
Liked 1,096 Times
You will also need a "chain whip" to hold the cogs stationary while you use the lock ring tool (the Park FR-5 as above) and a big wrench to unscrew the lockring.
As to which spoke to buy, take the wheel to a bike shop and have them match the broken one for diameter and length.
Likes For HillRider:
Quoted: 4206 Post(s)
Liked 3,870 Times
Sometimes the rim labels or the company's spec lists have spoke length info. But also sometimes specs change w/o notice... Best advice is to remove a good spoke from the same side of the wheel and use it to match the replacement. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Likes For dsbrantjr:
I don't think Giant has spoke length data for all factory wheels--they do for the wheels they sell aftermarket. The easiest way to measure a spoke without removing it is to measure from the center of the bend to the end of the nipple, then add 12mm. The surest way is to remove a spoke on the same side of the wheel. Either way, if in doubt or if you can't match the spoke length exactly, err on the side of too long.
Likes For cpach:
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Likes For operator:
Senior member
Quoted: 943 Post(s)
Liked 658 Times
I should have mentioned that the spoke kindly snapped at the connection to the hub - see pic. I don't know if I've measured from the correct side of the J.
Also I'm thinking of this set for the removal of the cassette.
Likes For Dan Burkhart:
Likes For cpach:
That tool set has a freewheel removal tool, not a cassette removal tool.
Likes For cpach:
As pictured they show a freewheel tool in a freewheel. Of course a lot of the Chinese listed auctions have crap descriptions. All the images are of a freewheel tool--I think they just messed up the written description.
Likes For cpach:
Got a set from Amazon - worked out well although I had to get a muscle man to move the wrench. I managed to true the wheel with some nifty improvisation.
Thanks everyone for your kind attention and knowledge.
