Alfine 11
Alfine 11
Breezer Beltway 11+
Breezer Bikes - BELTWAY 11+ - Bike Overview
FAIRFAX SC6 DLX
https://www.marinbikes.com/bikes/fairfax-sc6-dlx
FAIRFAX SC6 DLX
Quoted: 608 Post(s)
Liked 352 Times
Both are very nice and would make great commuters. There is a $550 price difference between the two with the Marin being more expensive. The only part I would like to see changed are the fenders, they could be longer especially in the front of the Marin. Otherwise what's not to love?
Bikes: Death machines all
Quoted: 297 Post(s)
Liked 86 Times
The Marin appears to have a shorter wheelbase. My Breezer Beltway had a layed-out geometry and was very stable, but a little dull. The Marin might be more lively, can you get test rides?
Work is the curse of the drinking classes - Oscar Wilde
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Marin is better spec’d. Geo numbers indicate the Breezer will be slower handling and stable to the point of almost boredom. 465 chainstays?! If you plan on packing heavy and place a premium on stability, the Breezer would be where you start. I would expect the Marin to be far more nimble and lively, but agree the fenders are a bit too short. Spec differences favor the Marin, though the dyno hub on the Breezer is higher grade. If it was gonna be my money, I’d buy the Marin and snag me a scrap of conveyor belting and cut myself a nice looking mud flap to hang off the front fender. Tight budget? The Breezer is no slouch and could easily be one of the nicest bikes on the rack. Either bike raises concern for theft, so I’d have a plan for something extraordinary to keep it mine.
-Kedosto
-Kedosto
Quoted: 297 Post(s)
Liked 86 Times
I'd pick up a backup belt either way. Does the Continental have a good/bad reputation in terms of performance and durability? My Gates CDX has been bomber!
Bikes: Colnago Crystal, GT MTB, Fuji D6 TT bike, Breezer Beltway commuter
Quoted: 35 Post(s)
Liked 13 Times
I have the beltway. My first foray into commuter bikes- and I've been happy. Other than changing the rim to go tubeless, it's had no problems- I like the quietness and lack of chain grease from the belt drive. It is a bit heavy, but very stable.
As in, the Continental components can't be found at all without contacting Continental directly.
You search and tell pakeboi, It's not my issue, I have chain driven IGH bikes.. my nearby shop is not a breezer dealer..
At my Local shop the distributor selling Continental tires has nothing in their dealer catalog about their belt drive stuff.
even a broken Gates crank ring was a special order, so the touring cyclist got to buy local hospitality services for a few days
Which are many.. so no suffering..
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
Bikes: Raleigh Carlton (commuter, all-rounder) || Xprezo Wuuu 2011 (XC) || Poliquin Randonnée 90 (ongoing process) || CCM Nevada (winter commuter)
Quoted: 25 Post(s)
Are you satisfied ?
A few weeks ago, I found some critics dating from circa 2012 complaining about the overall quality of the Breezer Beltway.
I am ambivalent between the Marin Presidio 3 or the Breezer Beltway11+.
The Presidio 4 DLX seems also nice much more expensive and some of the options I could retrofit later from an Presidio 3...
What about your Beltway ?
Quoted: 297 Post(s)
Liked 86 Times
I am looking for an all-year-round commuter bike. I live next to Montreal, Canada and this means winter, slush and deicing salt.
A few weeks ago, I found some critics dating from circa 2012 complaining about the overall quality or Breezer Beltway.
The Presiodio 4 DLX seems also nice much more expensive and some of the options I could retrofit later from an Presidio 3...
Quoted: 25 Post(s)
I was also looking for the BMC AC01 and a Tout Terrain Metropolitan.
From what I see on the AC01 pictures, there are no bosses for a rear pannier rack...
I find the European bikes quite nice and sturdy but they are a bit pricey. I guess it's probably that they are made in Germany or Swiss instead of tiered to China.
Quoted: 25 Post(s)
Looking at the pictures, I was skeptical at this bike as beeing a real commuter I could not see any rack bosses. I wrote BMC and they explained how to install a Tubus EVO and now this AC01 is back for contender.
Quoted: 297 Post(s)
Liked 86 Times
I would definitely like your input on the Alpenchallenge AC01.
The AC01 has a somewhat different frame geometry than the AC02 (which has rack bosses): the drive train is shorter and the rear wheel is compressed tight into the seat-tube, requiring proprietary BMC/Curana fenders and limiting options for studded tires (only a 30mm will fit). I forgive the limitations and irritations of this setup because I love the nimble AC01 ride and the bike has held up under significant abuse.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Quoted: 25 Post(s)
I have read abour Pitlock and when I get a new bike, I will for sure invest in Pitlock for hubs, headset, saddle... I want to keep it mine as well.
Quoted: 25 Post(s)
The BMC AC01 Two is now a serious contender.
Nice!
Have you tried the AC02 ?
Do you ride studded tires, if yes, how does it handle in winter ?
I actually ride 26x2" which is 52mm and I worry about those 30mm...
You are very helpful. Thanks!
FWIW, I also looked at the Schindelhauer and it just happens that the first North American LBS is about to sell them in Montreal, a 40 minute drive.
Quoted: 297 Post(s)
Liked 86 Times
Nice!
Nice!
As for your BMC questions:
- AC02 is a little heavier (by 1.4 KG) and more dull-feeling than the AC01. On the other hand, it accommodates a larger 35MM tire, has bosses for racks/fenders and accommodates more fender options than the AC01. The 35MM tire clearance is also interesting, because that allows more options for studded and winter tires, such as the Marathon Winter 35mm 4-row studded tire, which is invulnerable.
- I do ride studded tires in winter. It's like riding a rolling meat-grinder, with extra rolling resistance, but it gets the job done safely in icy conditions.
Quoted: 25 Post(s)
- AC02 is a little heavier (by 1.4 kg) and more dull-feeling than the AC01. On the other hand, it accommodates a larger 35MM tire, has bosses for racks/fenders and accommodates more fender options than the AC01. The 35MM tire clearance is also interesting, because that allows more options for studded and winter tires, such as the Marathon Winter 35mm 4-row studded tire, which is invulnerable. [...]
I know next to nothing in bike geometry so I called the BMC's LBS (60 minute drive) to discuss about AC01 vs AC02 vs Marin Presidio 3. The guy told me much the same thing that what you express as beeing "joyfull" vs "dull". An AC01 would be better in quickly managing my way between car and busses in downtown Montreal whereas the AC02 would be more comfy on long haul. How one describes a long haul... I do not plan on touring.
Since the bikes are special ordered and the LBS sells more AMP (electric) version, the guy himself has not tried the both of them in a short period. His comments are solely based on the geometrys as he reads them on paper.
Now again, I would rely on your experience since you have rode so many nice commuters.
My immediate need is to commute 22 km (14 mi.), 44 km RT on a shi**ty road for which some portions are like the remnants of a civil war. A few trafic lights, 75% in agricultural fields. One way commute on Strava. I only ascent 36m over the whole trip. I'd like the gear ratios to be speed oriented as opposed to hill climbing.
Now, the carbon fork, the 1.4 kg lower weight and what you describe as fun ride of the AC01 would lean me that way.
The AC01 has 55T crank / 24T cog while the AC02 has an unspecified crank / 18T cog, which looks more highly geared, thus leaning me toward the AC02 unless I plan on paying for swapping some drivetrain gears if it's too low geared. How would you describe the gearing ratios ?
Since you have road tested both of them, I'd like your input on that...
Thanks again. If it existed, I would teleport you a wine bottle.
Quoted: 297 Post(s)
Liked 86 Times
A bike with 650b balloon tires would give you a much smoother ride. Priority 600 The Pinion has way more gear range than you need and is heavier than you want, but the ride is super-cush and you can keep pedaling though the pot-holes better than a thinner-tired bike.
Something in-between is the Budnitz Alpha from Burlington VT: Budnitz Alpha This bike runs 40mm tires and carbon fork, which would still a fair amount cushier than the BMC. The fit and finish of Bunitz is superb.
Some guys would ride a light single-speed with cush tires on a rough route as flat as that, with so few starts and stops. Spot makes a really nice belt drive SS gravel bike for up to 40mm tires: Spot SS I've seen this one in the store and it's gorgeous. There are some 650b SS belt drive bikes out their with 47mm WTB tires, that would work very nicely on rutty roads. Bombtrack SS
Allergic to wine, but good luck with your search.
Quoted: 25 Post(s)
I am really leaning toward the AC01 Two at the moment. Price/Features, it seems unbeatable.
What is more of a concern is that 12 months commuting demands fenders and I have read some user's reviews where they call them a bit flimsy (easy to dent) and they are expensive to replace. Any comments on the fenders ?
[...] Priority 600 [...]
[...] Budnitz Alpha This bike runs 40mm tires and carbon fork, which would still a fair amount cushier than the BMC. The fit and finish of Budnitz is superb.
[...] Spot SS I've seen this one in the store and it's gorgeous.
Schindelhauer Viktor 1900 C$ in an LBS. Damn, the promo video makes me badly want it
This shopping is both fun and stressful at the same time.........
Quoted: 297 Post(s)
Liked 86 Times
My rear fender rattled around like crazy from the start and it drove me nuts. I siliconed it permanently into place against the seat tube and riveted a flexible plastic mudguard to the bottom edge, which improves the splash resistance and prevents the thin aluminum edge from cracking. That was a few years ago, and since these mods, the fenders have held up just fine.
In summary, I think they are cool fenders, but I recommend some pre-emptive modifications to toughen them up for your daily grinds.
