Knee pain
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times
Knee pain
Is riding a different bike nearly everyday making my knees hurt ?
Can going from a Standard framed bike to a crank forward bike and back cause knee pain ?
Anyone else experience this problem ?
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
I'd guess the low seat height on typical cruisers could hurt your knees if pedaling hard (mashing) for any length of time. For one thing, the legs don't get full extension, which isn't a bad thing for slow casual pedaling. But as soon as you add power to it for a while . . .
In my case, my knee left knee was giving me real trouble a few months ago on my bikes with regular seat heights. Of course, it didn't help that my left knee has a sports injury from my youth.
Right now my 54 y.o. knees feel good. What seems to have fixed it is raising my seats another 1" or so to get my legs properly extended and mash the pedals less by either picking a lower gear ratio, or accelerate more slowly (easily) until I can get the bike pedals into "spin" range. Also, riding every other day helps my knees recover after a ride better.
Not sure how much this applies to cruisers, as even my cantilever frame cruiser had the seat set high.
Quoted: 890 Post(s)
Liked 849 Times
Agreed that seat height is paramount for individuals with any type of knee problem (one knee injured playing basketball as a collegian). I've never had a "crank forward" bike, but imagine it's not the best pedaling position except for leisurely rides.
Quoted: 267 Post(s)
Liked 3,067 Times
I’ve played with the seat height . With my short legs , I’m on my tiptoes when sitting on the saddle stopped with my Electras .
I’ve changed out the rear cog on my Matte Bark C1 for a 24 tooth . The front chainring is a 44 . I spinout around 10 mph , but it’s so much easier peddling up a hill now .
like you guy say , it’s a cruiser bike , I’m not in a hurry when I’m riding . With the lower gear ratio I do a lot more spinning which will hopefully be better on the knees .
I was just wondering if the changing the angle I’m pedaling when I go from a conventional framed bike and a crank forward bike has an effect on my knees . If I stick with the crank forward I don’t usually have a problem with my knees .
I’m still going talk with my doctor next month .
My feet are not flat by any stretch on my cruiser. If they were then I couldnt get a good extension and thats tough on the knees even with the 34 tooth megarange.
If youre getting proper extension the change in position shouldnt matter as much. My .02
Replicating as near as possible the seat height and crank arm length between different bikes is the only way I can keep my knee from hurting more than normal. I finally had a total knee replacement a year ago.
Quoted: 267 Post(s)
Liked 3,067 Times
I’ve changed out my seatpost clamps for the quick release type so it’ll be easier to adjust the height . I’ve lowered the seats to where I can sit on the saddles and touch the ground at least with my toes .
I had to cut the seatpost on my Rockhopper 3/4” to lower it . The seatpost was bottomed out when I bought it and it was too high .
Took four of them out for test rides afterward for 7 miles total and the knees felt better than they did after a 6.5 mile ride on my Roll two days ago .
I think had the saddles too high on all of them .
On the crank forward bikes I should be able to touch the ground seated . Before I was pushing off and then getting up on the saddle .
I don’t remember having this problem before I got to reading stuff on bike fitment . I need Togo back to what feels good to me .
Hopefully , I’ve got this thing figured out .
5-10 degree knee bend at the bottom of the pedal stroke has always worked for me. The length of the cranks spec’d by the manufacturers to match the frame size are usually good enough. If you had to cut a seat post then you may have to go with shorter cranks to avoid too much knee bend at the top of your pedal stroke.
I had to change to shorter cranks on my MTB and road bikes after all the knee surgeries.
Hope this helps.
Hope this helps.
Quoted: 267 Post(s)
Liked 3,067 Times
actually, after cutting the seatpost, the Rockhopper with its super low gearing seemed the be the easiest on the knees .
Quoted: 267 Post(s)
Liked 3,067 Times
Just a short update .
I’ve been riding my Roll the last couple of days and the knees are getting better .
today I check my seat height while riding by putting my heel on the pedal and checking my leg position at the pedal’s lowest point . My leg was straight with my heel fully planted on the pedal . That’s where I read it’s supposed to be be ,
Think I’ve got figured out now .
Quoted: 267 Post(s)
Liked 3,067 Times
Likes For OldCruiser:
Quoted: 267 Post(s)
Liked 3,067 Times
Since the weather has dictated when I ride, I haven’t been able to ride every day .
I’ve been riding either my crank forward single speed cruiser with the 24 tooth cog on the rear or my seven speed Electra Fat Tire bike with the crank forward .
Yesterday I took out my Rockhopper with conventional crank position and my knees started bothering me again . Not bad , but I could tell a difference.
Today , I went back to the seven speed Fat Tire Cruiser and this evening my knees are back to hurting again .
I think it’s from changing back and forth between crank forward and conventional cranking .
I have an appointment with my doctor tomorrow. I’m going to ask what she thinks about it .
as for now , I think I need to stick with one or the other .
I'm the anecdote.
Liked 1,176 Times
Work has interfered with my riding. I hadn't ridden in a week until this morning. My left knee didn't like it at all. Spraining my left thigh above my knee at work on Thursday didn't help things either.
Quoted: 267 Post(s)
Liked 3,067 Times
Don't know how old you are but , in my case if I don’t ride at least every other day , it’s almost like starting over .
Another thing to consider is braking on the crank forward bikes. I fo...und it to cause considerable strain on my damaged knees and more of a reason to upgrade to the D7 with good hand brakes than the gearing....but I wanted the gears as well/
Quoted: 267 Post(s)
Liked 3,067 Times
I rarely use the coaster brake on my C1’s . I’ve installed front caliper brakes on both of them . I use the coaster as an emergency brake if I need to stop in a hurry , I’ll lock both wheels down . Extends the life of the rear hub .
I'm the anecdote.
Liked 1,176 Times
I need to ride at least 3 times per week to be able to ride well. My workload has increased due to end of year equipment sales. A banner November and December this year, that's for sure!
Quoted: 267 Post(s)
Liked 3,067 Times
I'll be 55 in a couple months. My user name happens to be my birth year with the numbers flipped.
Not so now days . It’s been six weeks since my little crash and I’m still feeling the effects of it .
BTW , I talked to my doctor today about switching between bike designs and once I explained to her the difference, she agreed switching from crank forward to standard design could have an effect on my knees . Using different muscles .
I’ve had a lot of knee surgeries. Spin an easy gear and keep your seat adjusted correctly.
Likes For Nighttrain:
Bikes: There is always room for one more.
Quoted: 190 Post(s)
Liked 399 Times
Holy sh*t Nighttrain!! Get your surgeon to install a zipper or velcro flap or something that gives him easier access.
Don
Don
Likes For GeezyRider:
