#4001
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 308 Post(s)
Liked 669 Times
Columbia 10 speed
This week's project appears to be an early 70s Columbia:
Apparently there were a bunch of 10-speed models named after different suburbs of Boston - Lexington, Lenox, Andover, etc. The model name was on the top tube, but the decal is gone on this one.
This looks to me like it was intended to be a U-08 knockoff. It has basically the same Simplex derailleur set as a contemporary U-08 I was working on a couple weeks ago, and the look is similar as long as you don't notice details like the crimped-in dropouts. There is a serial number list available online that pegs this as a 1965 frame, but I just don't think so. The rear derailleur has a fuzzy number that looks like a 71.
Basically a piece of junk, but a solid piece of junk with a history.
#4002
Quoted: 331 Post(s)
Liked 331 Times
Slippage?
@hazetguy Does that Sun unit still work?
Today I worked on re-creating a bottom bracket tool I used in the 70's. It locks into the fixed cup and it threads against itself so It can't slip and works on both left and right handed cups. A very simple design that just works. The working looks a bit unrefined but will remove fixed cups. Depending on which side of the tool you tighten it moves both right and left thread designs. The nuts are race car lug nuts with a bit of lug stud welded into one end with an extension that is welded into a 1/2 inch drive hard socket. I need to bit more cleaning of the welds and then paint but I have a new tool In haven't seen in a long time. Smiles, MH
#4003
Quoted: 93 Post(s)
Liked 151 Times
I have been working on a '97 Lemond Tourmalet that is in excellent original condition. I decided to leave the original handlebar tape and tires to show just how original and low mileage the bike is. Only items replaced so far are the nylon spacer which screws in to the non-drive side of the bottom bracket, the spoke protector, brake pads and all cables/housing. I cleaned, degreased and repacked all bearings with new grease. As a 61cm it was the largest size frame available that year but the Tourmalet is near the bottom of the line with a steel frame and a 3 X 7 Shimano RSX drivetrain. It rides very well for a nearly 25 year old steel frame road bike. I really like the dark blue metallic paint and am tempted to keep the bike but alas I already have too many!
Likes For ARider2:
#4004
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
#4005
Quoted: 1283 Post(s)
Liked 1,835 Times
The wrench is just a standard 36 mm wrench that fits on the fixed cup. It is about 18" long so it will have plenty of leverage, unlike the Parks and other spanners. It cost $20 but with 15% off and a rebate coupon it was more like $12. I could not resist at that price!
The tool I made is two race car lug nuts welded to a hollow extension and then welded inside two 1/2" drive impact sockets. One side has a stud welded into one of the lug nuts. The other lug nut is hollow and they jam against each other on either side of a fixed cup. Depending on which end of the tool you tighten it works for both left and right handed threads. I will post a few pics when I get to my other computer that allows pictures to be down-loaded. Smiles, MH
Likes For Mad Honk:
#4006
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Johno59,
#4008
Quoted: 93 Post(s)
Liked 151 Times
Good eye SurferRosa. Front rim is Mavic XP10 (original spec) and rear is Mavic XP30 which was likely changed early in the life of the bike along with the stem. The handlebar tape and tires appear to be the originals and the bike came with the original pedals as well but I put on a temporary replacement set on.
#4009
Liked 1,835 Times
Johno, and JHiggins,
Got some pics down loaded into computer so here goes:
The tool is two pieces that fit together clamping the cup between them. The length on each piece needs to be long enough to extend past the outer shell of the bottom bracket. Each piece and a BB cup pictured.
This is how the pieces fit together to clamp the cup. The tool actually clamps the cup by engaging the cup by the center area inside the races of the cup.
This picture shows the fit of the tool inside the cup. The stud has a clearance of about 2mm (the same as my Var fixed cup tool).
This is how everything goes together. Each piece clamps on the cup when screwed together. Then the tool can be tightened with a 1/2" drive socket as shown, or if extra leverage is needed a long breaker bar can be used. I have a 2 foot bar here in the shop for plenty of extra leverage.
Hope this makes the tool a little easier to understand. It is more of a junk-yard tool that just works and fits almost everything. I suspect I will get calls from my local co-op to come break apart some of the junk they get in and try to dismantle to save parts for the junk bins. Smiles, MH
Likes For Mad Honk:
#4010
I think that was typical back in the early days of spec-ng sealed bearings on bike components. I've rebuilt lots of sealed bearing hubs from the 70s-80s that only had an outboard seal.
#4012
Just finished my ST1000, still waiting for a 24t ring and front bags to finish it off.
Semper fi
Semper fi
#4013
Pedal On
Bikes: I ride 'em!
Quoted: 5 Post(s)
Liked 18 Times
Varsity
Nice 'Dale!
Having the day off today, I swapped a few things around and came up with this:
This Varsity was a roadside find roughly a year ago. It's become my favorite bike. Fits me like a glove.
#4014
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
#4015
Likes For sloar:
#4016
Edumacator
Quoted: 2385 Post(s)
Liked 2,930 Times
Thanks. The paint is in great shape, so polishing really brought it out.
#4018
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
yes, thank you! i suspected they might be. i have a set of chromo's. i just keep looking for some alloy ones like that. the kind esge used to make that the chromo's replicate
#4019
Bikes: TRIMMED DOWN THE HERD
Quoted: 1088 Post(s)
Liked 926 Times
Continuing the cutting down of my herd, I decided to bring this back to life and sell it after it's been hanging down to frame and fork for a few years. Much as I hate letting it go, I probably won't ride it anyway since the Trek 560 and Bottecchia are better riders. Slapping on a mix of 105 and Exage stuff I have in the bins.
rebuild by 2cam16, on Flickr
#4020
bOsscO
Bikes: 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 292 Post(s)
Liked 353 Times
Although the frame looks small there seems to be a lot of clearance between the frame and wheels.
#4021
Liked 926 Times
Thanks! Yeah Western State Imports pretty much mixed and matched the names of their brands. It's actually a longer name,Diamondback Centurrion Master TG. The Centurion is on the tt. Centurion also has a Master in the Ironman bike. lol
#4022
Liked 1,835 Times
I have been putting off getting to the most damaged of my bikes that were involved in a house fire (arson that was never solved). So today I have started on the Team Fuji and hoping to get it to a hot bath sometime tomorrow. I am suspecting this frame is full chrome underneath the paint. There is chrome in the water bosses that is visible, and if not I will know that it will have to go to PRO Kote Indy for a new powder coat. I have taken a few pics to document the process and hopefully give a bit of perspective of what can be restored. At some point I am going to put the finished item in the valuation thread. So here are to beginning photos.
the fire damage doesn't show well but the paint is destroyed and the tires were burned off the rear rim
front wheel is almost intact the bikes were hung on a steel rack and the worst damage was to the area near the top of the rack. close look to the bars show how the tape literally melted on the bars
the rear didn't fare very well
frame paint still has decals but will have to come off
Fuji frame decal indicating tubing type
And so begins another restoration project. Smiles, MH
Likes For Mad Honk:
Likes For VtwinVince:
#4025
Quoted: 1103 Post(s)
Liked 1,308 Times
Made these three bits:
to go here:
like this:
to make this marriage:
The arms have a threaded projection that goes almost all the way through the Y-piece, so the bolts still have four full threads engaged - without the washers not enough of the shoulder of the bolt head was bearing, the corners would either round or were going to dig in.
to go here:
like this:
