11-30 vs 11-34 cassette
Old 07-15-20, 10:01 PM
Joearch
Bikes: Bianchi Infinito CV Disc Ultegra
Quoted: 49 Post(s)
Liked 60 Times in 32 Posts
I ordered a a Bianchi Infinito CV Ultegra Disc and it comes with 11-30 cassette. My current bike is a 11-34. I have mostly been doing relatively flat rides and am in the 11-17 range. I was thinking The Infinito might get me into climbing some. Not sure and wonder what to do. LBS who is a Bianchi dealer said they can do the switch to 11-34 which is changing cassette, chain and rear derailleur for $199. Apparently a fair number of folks make that switch. I am 64, getting back into riding the last 4 months doing 20-35 mile rides 4-5 days a week. Suggestions?
thx
Joearch is offline
Old 07-15-20, 10:54 PM
Leinster
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times in 207 Posts
1) Presumably you're already on a compact crank or smaller? Have you thought of switching to a 46-30, which would give you the same 1/1 low gear as a 50-34/11-34?
2) Are there any climbs around you where you need a 34? If you're in the 11-17 range most of the time, it doesn't sound like you need anything bigger than a 30.
Leinster is offline
Old 07-15-20, 11:27 PM
Joearch
Quoted: 49 Post(s)
Bike comes with a 50-34 crank. I live in Los Angeles so there are a lot of hill/mountain opportunities. In the time I have started up riding again I have not done much climbing. Was wondering if this bike would get me into rides that have more climbing. Was one of the reasons for getting disc's. Honestly so for even mild climbs have been tough for me. So maybe have a wider range in the small gears is more functional for me. I can start that way and change later if I get stronger and start doing some climbing.
Joearch is offline
Old 07-16-20, 12:23 AM
downtube42
downtube42's Avatar
Quoted: 896 Post(s)
Liked 2,063 Times in 1,081 Posts
What's the cost to change later, if you so decide? Probably not much more.
Nobody can tell you if 34-30 is sufficient for you. Your power to weight ratio, the grades you want to climb, and your riding style all factor in.
With that said, I'd go with the bike as it comes and make a change if there's a problem. At that time, you can consider the different options for lowering gearing.
downtube42 is offline
Likes For downtube42:
Old 07-16-20, 04:38 AM
MattTheHat
MattTheHat's Avatar
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,034 Times in 1,428 Posts
If it were me, I’d immediately go 11-34 and not even think twice.
MattTheHat is offline
Old 07-16-20, 05:14 AM
bruce19
bruce19's Avatar
Quoted: 1743 Post(s)
Liked 1,281 Times in 740 Posts
I'll agree with Downtube42. No one else can tell you what works for you. I'm 74 and ride with a compact and 11-28. So what? That has nothing to do with you. If you haven't been climbing, you don't have climbing fitness. And, I'm guessing, you don't have climbing technique. I'd buy whatever bike works for you as is. Then I'd start climbing. After awhile you will know if you need different gears. My guess is as you get more fit, your gearing needs may change again. Go with the bike that "speaks" to you and make changes as needed.
bruce19 is offline
Old 07-16-20, 05:51 AM
ultrarider7
Bikes: 1964 Schwinn Varsity, 1985 Trek 410, 1985 Peugeot P 8, 2021 Pinarello Dogma F12, 2022 Cannondale Topstone Alloy
Quoted: 106 Post(s)
Liked 1,102 Times in 327 Posts
Bruce stole my thunder. I own a Bianchi Infinito CV with the 11-30 cassette. There are times I would really like the 34. I would get what you think will be the best out of the box, you can always change down the road. BTW, I've ridden mine about 3,000 miles since last fall and I am 68 years old. It's a great bike!
ultrarider7 is offline
Likes For ultrarider7:
Old 07-16-20, 05:54 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
Just to ask.. but isn't there also an 11-32 and would this require the RD change?
Sy Reene is offline
Old 07-16-20, 06:13 AM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 988 Post(s)
Liked 584 Times in 439 Posts
I ordered a a Bianchi Infinito CV Ultegra Disc and it comes with 11-30 cassette. My current bike is a 11-34. I have mostly been doing relatively flat rides and am in the 11-17 range. I was thinking The Infinito might get me into climbing some. Not sure and wonder what to do. LBS who is a Bianchi dealer said they can do the switch to 11-34 which is changing cassette, chain and rear derailer for $199. Apparently a foar numner of folks make that switch. I am 64, getting back into riding the last 4 months doing 20-35 mile rides 4-5 days a week. Suggestions?
thx
I'd go with an ''easier'' gearing combination if I were you, especially if you climb a lot. 34/50 & 11-30 is a good combination, but it will make you sweat (and swear)!
eduskator is offline
Likes For eduskator:
Old 07-16-20, 06:40 AM
Rides4Beer
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times in 414 Posts
I'm with Matt, go straight for the 11-34. I do a lot of climbing here, and I'm very fit, and still want 1-1 on the road, better than that on gravel.
Rides4Beer is offline
Likes For Rides4Beer:
Old 07-16-20, 07:00 AM
Joearch
Quoted: 49 Post(s)
Great input. I am not sure which way to go. Not doing much climbing yet but 34 might get me there sooner. Need to ask the LBS that would do the work if the swap of the cassette, chain and RD would all be the same OEM parts as I would want to keep it stock other than gear sizes.
Joearch is offline
Likes For Joearch:
Old 07-16-20, 07:53 AM
Leinster
Quoted: 344 Post(s)
You have the 34 now, on your current bike. I would say take it up some hills this weekend. Work out a manageable 1-2 hour loop within, say, 20-30 miles of home with about 1,500-2,000ft of climbing, and see how you do. If you need the 34 on your current bike, you'll probably need it on the Infinito. If you don't need it now, you definitely won't after. No need to take it up the hardest climb, just something that you find a little bit intimidating.
Leinster is offline
Old 07-16-20, 08:38 AM
CAT7RDR
Quoted: 822 Post(s)
Liked 1,960 Times in 943 Posts
Unless you are 150 lbs and already a solid climber, in the SoCal area, it is always a benefit to have a 34:34 possibility when you hit extended grades of 8+% for several miles. $200 is a bargain to make the switch.
CAT7RDR is offline
Likes For CAT7RDR:
Old 07-16-20, 09:05 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
thx
Try it out. If you dont like it, spend the $200. No one can tell what gears suit you, but you.
Racing Dan is offline
Old 07-16-20, 09:06 AM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10424 Post(s)
Liked 11,896 Times in 6,094 Posts
I stopped paying attention to new bike tech and what other people were riding about 12 years ago, after a 2-year binge in which I bought one new bike, build another, and rebuilt a third. I kept riding, some years more, some years less. So, reading this thread, where everyone's talking about running a 34 x 34 as a necessity is a revelation!
I feel like Rip Van Winkle, falling asleep in a world where my 12-27 cassette and 25mm tires were a source of shame, an admission that I was out of shape. And everyone pumped their tires up to the max on the sidewall.
Now, 25s are considered skinny, and everyone's running MUCH lower pressures, and an 11-30 cassette is now not only acceptable, it's considered not enough! I'm LOVING this new world! I just bought a new Canyon Endurace with a 52/36 and 11-34 in back, with disc brakes, running 28s and it's FANTASTIC! No more grinding up hills at 50-60 rpm!
genejockey is offline
Old 07-16-20, 09:19 AM
Fox Farm
Fox Farm's Avatar
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 126 Post(s)
Liked 55 Times in 34 Posts
It depends on how steep are the climbs that you plan to be doing. I am 62 and live in a pretty hilly area with some big 12% to 15% climbs, but certainly not all are like this. I use a compact 50/34 crank and an 11/29. Just put on an 11/32 and it is just right for me. Most of the time I only use the 29 in rear but the 32 is there for a bail out gear or to keep my crank speed up. One suggestion is to get yourself back into cycling shape for the next 3 months with the 11/30 and as you develop some power for hills, see how the 30 does. If it is really not enough, change cassettes and chains. Most rear detailures that will work with a 30 will also work with a 34, medium cage. Likely you are going with Shimano and their rear mechs are not that expensive if you must change.
Fox Farm is offline
Old 07-16-20, 10:26 AM
Joearch
Quoted: 49 Post(s)
Bike looks great...beautiful location. Mine is on a UPS truck on its way to the LBS. I may just wait and see hoe the 11-30 feels. Thx
Joearch is offline
Likes For Joearch:
Old 07-16-20, 10:28 AM
Joearch
Quoted: 49 Post(s)
Thx for the suggestion. I will try to find a location with some moderate climbing and see how that feels.
Joearch is offline
Old 07-16-20, 11:13 AM
genejockey
genejockey's Avatar
Yeah, that's a good idea!
Where I live, I can choose rides that are mostly flat, or flattish with AT MOST short 5 minute climbs, or I can choose ones with a few 10-15 minute climbs, or I can go for some climbs that take at least half an hour. Right now, I'm doing the middle option, and feeling stronger with each passing week, so I think it's the time of year to start throwing in the longer climbs. I know if I try to go from the flat rides to the big climbs without doing the medium climbs first, I suffer!!!
Old 07-16-20, 11:14 AM
Joearch
Quoted: 49 Post(s)
Sage advice. BTW Prague is one of my favorite places in the world.
Joearch is offline
Old 07-16-20, 11:20 AM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
Definitely go 11-34 or higher. There are some hills here where 32 front 36 rear is barely enough.
Elvo is offline
Likes For Elvo:
Old 07-16-20, 01:09 PM
Atlas Shrugged
Quoted: 1248 Post(s)
Liked 1,323 Times in 674 Posts
Go 11-34 no question. What would be the downside?
Atlas Shrugged is offline
Likes For Atlas Shrugged:
Old 07-16-20, 01:11 PM
mattscq
Quoted: 83 Post(s)
Liked 33 Times in 24 Posts
I think if a 11-34 is going to encourage you to bike up steeper grades, then what's $200 on a very nice new bike? That upgrade price seems pretty fair and you could probably sell those parts if you wanted to offset some of the costs.
For a long time I used to stay in the lower range of the cassette as well, grinding it out with a 52 up front and 15 or so in the back. I'm a pretty new to cycling as a sport, but the more I do it, I find that I appreciate the larger cogs as I'm spinning more and more. I personally run on the 10-30 my bike shipped with and there are more than a few occasions when I wish I had a slightly broader range like a 32 or 34.
mattscq is offline
Likes For mattscq:
Old 07-16-20, 01:19 PM
tankist
Quoted: 83 Post(s)
Liked 157 Times in 55 Posts
I also have the Infinito with Chorus 11 speed. I changed myself cassette, RD and chain for 11-32 to better climb hills where I live. No regrets and 11-34 would be even better if it were available.
tankist is offline
Old 07-16-20, 01:26 PM
surak
surak's Avatar
Quoted: 873 Post(s)
Liked 726 Times in 436 Posts
Back when I did group rides, having the 34t was like a having a superpower when passing other riders just as fit as me on those grades over 10%.
surak is offline
