Using chainrings designed for triple, with a double
Having read an earlier thread here ( 410453-double-triple-outer-chainring-differences)
I have a similar question. Taking the advice in that thread I *think* I’d be OK with the following, but wanted to ask here for a consensus opinion.
i have a homemade bike (not mine) equipped with a worn 9speed Shimano Deore Double chainset (44/32j. I’m not 100% sure that is the original setup, it may have one time come from a triple, or been transplanted to this bike. Whatever, it works.
When I’m shopping for replacement rings, I find seemingly compatible rings (correct BCD=104mm, also 44/32 teeth, even also Deore (or Alivio) ) but they explicitly say “This Outer Chainring can only be used with Shimano Deore FC-M591 9spd Triple Chainsets with a 44-32-22T set up.“ I enquired why that constraint is given, and the retailer responded “"Because it's a specific offset fitting for use with the FC-M591 crankset. Hence it will not fit anything else other than this”
Can anyone offer their expert view on this. My own view is that I’m not changing the bottom bracket, the cranks or the 4arm spider mount. Assuming all 9speed chainrings are the same width, these should mount correctly on the existing BCD mountings, and therefore why wouldn’t these fit and work in practice.
FYI I’m in the UK. I’m too new to post URLs yet, but am considering Deore M530 or M510 rings. there are also cheaper Alivio ones in the same category which seem as though they’d work.
thanks in advance, Richard
Quoted: 4197 Post(s)
Liked 3,849 Times
AndrewRStewart
AndrewRStewart
Quoted: 6187 Post(s)
Liked 4,805 Times
If you mix and match parts then I'd say you are taking more of the assumption of risk on yourself for how well it performs, is safe and lasts. If you need to save that many pennies, I'm completely okay with it. Just consider if buying a complete crankset (chainset) and maybe even a new BB is out of the question for your budget.
Likes For Iride01:
Quoted: 4802 Post(s)
Liked 3,922 Times
I mix and match rings all the time. Now, I do not run indexed shifting and I find different rings might mean slightly different feel to the shifts but they all work - that is if they are the correct width for the chain you are using. I might set the FR inside limit screw a little closer for a triple middle ring used as a double inner to prevent the chain falling off the ring as it attempts to shift to the inner ring that is not there. (A chain watcher could also be used to do the same thing.)
Likes For 79pmooney:
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times
This crankset (FC-M591) came in 2 versions; 22/32/44 tooth combination and 26/36/48 tooth combination. Shimano spent lots of time and money (marketing $?) designing chainrings to optimize front shifting, However, you can mix and match the chainrings but the shifting wont be as crisp as using the matching set. I do and my bike has not exploded and I have not died, but others would have you believe otherwise. If the BCD and number of arms are the same, then there is little risk that the ring wont fit just fine on the spider. And in my opinion (partially thru experience) the talk of ring thickness and offset being different within a single manufacturers lineup and same BCD/# of arms is insignificant (if it even is different to begin) and just to get you to buy parts you don't need,
