Spoke Washers and bladed spokes, who's tried it? Nemesis/DA 7600
Luke
I've been a lurker for longer than I'd care to admit (just got account though), so I apologise if I'm not doing this right, its my first post.
A bit of backstory, I'm only a teenager... I'm now a qualified mechanic but due to the whole age thing/issue, I've only built a handful of wheels so far, nothing too flash but enough of them to have my own details of how I like my wheels to be. I'm a perfectionist so I need everything to be dialed all the time; this definitely helped with the first build. Keeping this in mind, I'm wanting this particular wheelset I'm building to be 100% perfect. I haven't received my spokes yet but I have the hubs and rims. This set is for the track bike.
It's gonna be a bombproof, somewhat ****** training wheelset for the velodrome we've got here in Auckland, NZ and perhaps even some racing in Cambridge.
Rims: NOS Ambrosio Nemesis tubs 32h
Hubs: Dura Ace 7600 high flange hubs
DT aerolite spokes with brass polyax nipples and spoke washers
Here's where my issue is if you've made is this far,
I'm convinced on using spoke washers (like those on narrow flanged, steel hubshells, or with 1.8mm spoke) at the head of the spoke by the hub for the best fit possible, but since DT Aerolites are supposedly 2.3mm across the bladed portion (CX Rays 2.2mm) and the inner diameter of spoke washers (DT ones) is 2.2mm, I wasn't sure they would fit??? Assuming the brass of the washers is malleable enough, would I be able to just force it on or would this deform the washer rendering it useless? Has anyone tried this?
I guess the question is, had anyone used Aerolties or CX Rays with spoke head washers?
And another Q, I've been told that 90kgF is good for the Nemesis rims but other threads/forums (VSalon of the top of my head, but can't link yet; need 10 posts) have said about 100-110kgF IIRC which sounds more realistic but does 32h have something to do with this? Any experience with this?
And to the mods, sorry, I know there probably is a wheelbuilding forum but I couldn't find it. If you would be so kind as to move it to there or even SS/FG if you think that'd be best that'd be awesome.
Cheers,
Luke
Cheers,
Luke
Senior member
Quoted: 942 Post(s)
Liked 656 Times
I have built a lot of track wheels with Dura Ace high flange hubs and CX Ray spokes. The spoke head washers are completely unnecessary for this application, but I can tell you that the brass spoke head washers that I have will fit easily on the elbow of 13 gauge spokes, so they would certainly fit on a spoke with a 2.3mm wide bladed section. Sorry, I don't remember the brand of the washers.
The only time I use washers is for thin hub flanges or spokes with long elbows such as some of the old stock DT Swiss spokes I have laying around. If you see a gap between the inside of the elbow and the flange when the spoke is inserted and turned into position, there may be a benefit to installing washers, but I have never had that issue with those builds.
Friendship is Magic
Bikes: old ones
Quoted: 26382 Post(s)
Liked 10,362 Times
Be careful when you read the tensions on your bladed spokes, because it's not hard to get it wrong because of orientation of tensiometer to blade. Again, you probably know this.
Luke
Thanks for the replies from everyone so far
Good Point dsbrantjr, if something is difficult, you're doing it wrong, right. The washers (if they were too tight) would probably deform and not give me the results i'm looking for.
Thanks a lot, man. Great to know that with CX Rays I shouldn't need washers, since the Aerolites I'm planning on using, if they ever arrive, have shorter elbows that CX rays meaning the fit would be even tighter.
Thanks for being nice. You're probably right. Sounds like washers won't be necessary either. They do look hella purdy though.
Yes can agree on both parts.
90kgF x 32spokes is 900N x 32 = 28,800 N of force in one wheel
115kgF x 24 spokes is 27600 N
Sounds like this would be about right I guess. With tensioning I was hoping to get away with about 100 kegs, hoping that the double eyelets could take it, but this wouldn't exactly make a stiffer wheel anyways, in fact less stiff IIRC and I can't get a hold of Ambrosio to ask them (have they gone under?)
Thanks tons, guys.
Thanks tons, guys.
Really Old Senior Member
2.2mm or 2.3mm, both numbers are rounded to the nearest 0.1mm.
0.1mm is only .004". They may be slightly more/less than that in reality.
IF brass washers, the steel spoke is noticeably harder.
Luke
Thanks, Bill good info re rounding. Are you saying that in practice, the CX Rays and Aerolties have the ~same dimensions? Cheers
Quoted: 4195 Post(s)
Liked 3,837 Times
The part about " I'm now a qualified mechanic" and "I'm a perfectionist so I need everything to be dialed all the time" is what I picked up on. I'd like to hear back from the OP after a few decades in the trenches about these statements.
Perfection is a worthy goal, but as we are humans assembling products made by humans, a goal that is somewhat vapor. Pros learn the fine line between good enough and "perfection". They learn this faster when they run their own business. I wish the OP a long and productive career in this industry. Andy
AndrewRStewart
AndrewRStewart
Old dogs still see new tricks.
Senior member
Quoted: 942 Post(s)
Liked 656 Times
I have calibrated my tension meters to both spokes in my calibration jig and they read identical across the board.
I can bust out the micrometer later and do comparison measurements.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
With hub flange hols getting rather wide (2.5, or 2.6 mm on Dura Ace track hubs), I'd go with spokes that are wider at their elbow, at least if durability is a concern.
I'd also go with 36 spokes for training - breakage of one spoke lets you continue the ride, without any rim brake rub, not to mention tyre rubbing the frame.
Will washers help (if they can be fitted)? Maybe - but not nearly as much as using spokes that are wider at their elbows will - at least in terms of spoke durability.
I've only built 35 or 40 wheels and never had a use for spoke washers. The wheels have always held up for tens of thousands of miles.
Luke
The perfectionist part was more that if spoke washers may improve the reliability of this wheelset, I would definitely be wanting to use them.
Thanks man
Luke
In my experience, the Aerolites and CX Ray are close enough to be interchangeable. I do lots of wheel repairs, and replacing a broken Aerolite with a CX Ray makes for a virtually undetectable repair.
I think the consensus is that spoke washers aren't really needed, right?
I may still use them since Gremlin mentioned the spoke hole diameter, and washers are needed on 1.8mm spoke in holes meant for 2mm spokes, so to me i would seem logical that I may as well use washers designed to be used with 2mm spokes that are being used in hole meant for/compatible with 13 gauge or larger spokes? Thoughts?
Thanks again
Luke
Mostly harmless ™
Liked 216 Times
Would you suggest something like an alpine in this case if I were to go down this route? Thinking that I'm pretty set on bladed spokes for this one, though. Cheers
Were there specific hubs you used for most of these builds? Flange thickness or far more likely, build quality may be partially to thank? I'm hoping I've got a little bit of both of those things but I think it was Dan who said he has built with my hubs before without washers so it looks like it may be on me for this one
I don't know that alpine are bladed.
I've built wheels with Dura Ace 7710 and 7600. One with 36, the other using 32 spokes (couldn't source 36 spoked version at the time if memory serves me). Spokes used with both were DT Swiss swagged spokes in 2 mm version (2.0 - 1.8 - 2.0 - model "Competition"). They have held up well (so far so good).
Luke
Luke
For training, as a wise friend said: "the more difficult it is, the more recreational it is" (to translate from Serbian). I wouldn't be too concerned with aero spokes on training wheels.
I use super heavy training wheels on my road bike too. Love switching to a faster set of alloys for race day.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
You don't need the spoke head washers.
=8-|
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
