1984 Centurion Turbo...just brought it home
Likes For RobbieTunes:
Quoted: 3182 Post(s)
Liked 2,460 Times
Those dark components are awesome! The brakes in particular. Even the dork disc is sweet. I'd leave that on. Details, baby. That's what the headset looks like.
Here's what mine looked like as found. Also a pic of the frame in the sun. I'm waiting on some cable to arrive for the build up.
Likes For seypat:
Liked 2,460 Times
Many of the bits were bronze-colored, as were the hubs on most I've seen. I think the dork disk was bronze, too. I see the catalog page shows black, as well as the OP's hubs being black. I've never seen one with black bits before. Those hubs are super smooth, and worth an overhaul if you ride it OEM.
Check out the font on his DT decal. First I've seen that one on a Turbo.
I may be wrong, but if I recall, the seat post was 26.8, but I'm old, addled, and could well be remembering something totally different.
Likes For seypat:
Liked 2,460 Times
Now that I have looked at the rest of the bike, I found something to sleuth. Look at the picture of the rear DO/RD/etc. Look at the way the chainstay is cut at a 45ish angle where it meets the DO. Mine is cut at a 90. Now go look at @verktyg's beautiful Echelon in the Appraisals forum. Same 45ish angle. Could be a coincidence. Might be a connection. The pic is of my dropout.
https://www.bikeforums.net/classic-v...bim-konno.html
Likes For seypat:
Quoted: 4719 Post(s)
Liked 3,034 Times
Now that I have looked at the rest of the bike, I found something to sleuth. Look at the picture of the rear DO/RD/etc. Look at the way the chainstay is cut at a 45ish angle where it meets the DO. Mine is cut at a 90. Now go look at @verktyg's beautiful Echelon in the Appraisals forum. Same 45ish angle. Could be a coincidence. Might be a connection. The pic is of my dropout...
Likes For T-Mar:
Liked 3,034 Times
No doubt, you were paying extra for the Italian names associated with the Centurion Cinelli Equipe. though the question of the better component selection is arguable. Certainly, the Superbe Pro derailleurs of the Turbo out-performed the Campagnolo Nuovo Record set-up on the Cinelli Equipe but the other components on the Turbo weren't up to level the derailleurs, which were door bait. If I was parting out the components on both bicycles, I strongly suspect that I would get more for the Equipe's components.
Liked 2,460 Times
The Comp TA and Turbo were sourced from both Tano and M-a-t-s-u-s-h-i-t-a. The latter is best known for their Panasonic brand and they also employed the acute angle cut on the chain stays of some of their better models (see pic). Given that they are a known source for some Turbo, this would be seem to be the more likely source. However, the serial number would tell us if it is a M-a-t-s-u-s-h-i-t-a frame, without a doubt.
verktyg
Quoted: 1036 Post(s)
Liked 1,235 Times
Bronze Anodized Gran Compe Brakes
Why they didn't just go with black anodized components? Only the Japanese could answer those aesthetics questions. (Think "Fair Lady Blue Bird" the model name for the Datsun Z mini muscle cars in Japan)
The Gran Compe NGC400 brakes were also sold as Suntour Cyclone branded. NGC stood for New Grand Compe and 400 indicated Short Reach - 40mm to 50mm. I have several sets of these calipers that are unbranded. They're very well made.
Personally, I think people get too carried away with Tange #1 . Tange #1 through #5 all used the same fork steerer, fork blades, seat stays and chain stays. So, the only difference was in the main triangle and even then #1 through #3 used the same seat tube, so for the commonly seen #1 and #2 framesets, the only difference were the top and down down tubes.
The double butted seat tubes used in both # 1 & # 2 required smaller diameter seatposts that those used with single butted .8mm x .5mm or .9mm x .6mm seat tubes.
However, WSI did not spec standard tubesets for their Tange #1 frames. Centurion Ironman, Comp TA and Turbo owners regularly report 27.0 - 27.2mm seat posts, which would be far too large for the standard double butted seat tube used with Tange #1 . The post sizes suggest a custom, single butted version of the seat tube or possibly the standard Tange #4 seat tube, which was single butted 0.9mm/0.7mm.
I had to cut the seatpost out of my 1987 IM when I got it. The bike had been used for triathlons, ridden hard and put away wet so the seat tube was severely corroded.
STUPID DESIGN... using a deeply fluted seatpost on a triathlon bike!
When I started reaming out the seat tube to clean up the corrosion I had to remove a lot of clean metal to get to what I thought was the correct size 27.2mm seatpost to fit. I didn't realize at the time that the seat tube was double butted and had a wall thickness of .9mm at the top.
BTW, I also had a nice almost NOS 1986 IM frame that I sold off. The seat tube cleaned up nicely with a little bit of honing and a 27.2mm seatpost fit in smoothly. The exception to the rule...
The IM bikes were definitely not in the same league as the Turbos but they offered a whole lotta bang for the buck.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Bikes: 1966 Paramount | 1971 Raleigh International | ca. 1970 Bernard Carre | 1989 Waterford Paramount | 2012 Boulder Brevet | 2019 Specialized Diverge
Quoted: 129 Post(s)
Liked 76 Times
I've owned two 1984 Turbos, the first one was the first serious road bike I purchased, and was one of the only bikes I bought new. The second came to me in a bike-for-bike trade where I definitely felt like I came out the winner. That was maybe seven or eight years ago and I discovered time had not been kind to me: my memories of the first bike, very fast and light, translated to something a bit more squirrely on the second bike... wasn't the bike, though. It was me! (Turns out I wasn't 145 pounds any longer.)
Likes For AZORCH:
Likes For leftthread:
Quoted: 41 Post(s)
Liked 51 Times
T-Mar, you're right. Never saw any catalog listings for these but they were apparently made special for the Centurion Turbo.
Standard Tange # 1 had .8mm x .5mm x .8mm top and down tubes with a .9mm x .6mm x .9mm seat tube. The 3 main tubes in Tange # 2 were all .9mm x .6mm x .9mm wall thickness.
verktyg
verktyg
Liked 3,034 Times
That would be consistent with what other members have reported and also be consistent with a Tange #4 seat tube. It makes more sense to use a stock, existing seat tube than manufacture a custom seat tube. However, it is curious as to why WSI would do this, as the Tange #4 seat tube was slightly heavier than the double butted Tange #2 seat tube spec'd with Tange #1 . Normally, a heavier tube would be employed to stiffen the frame and the standard approach would be a heavier gauge down tube.
Likes For 2cam16:
verktyg
Liked 1,235 Times
Corroded Seat Tube
I don't ride in the rain anymore if I can help it but during the NorCal rainy season bikes pick up a lot of crud, leaves, etc. from wet pavements. I don't like to get my nice bikes dirty
I like the over the top Miami Vice pink and yellow and ride it occasionally just to irritate stogy C&Vers!
@T-Mar I agree, the way to stiffen up the bottom end of a frame has traditionally been to use a heavier wall thickness down tube.
Could never figure out why the Japanese made double butted seat tubes but your suggestion about not having to make single butted seat tubes makes sense from a "Japanese" economic point of view.
One thing to bear in mind, there were never a large number of derailleur bikes sold in the Japanese home market.
Most of the bikes produced in Japan were 50 Lb. single speed urban transportation clunkers. Bikes were considered household items and purchased by the notoriously frugal Japanese housewives (for their husbands to pedal while they sat side saddle on the rear rack)!
Luxury model Japanese "de Ville" bike with lot'sa chrome.
With the exception of maybe Fuji, most of the Japanese bikes imported into the US before the mid 70's were built to the specs of importers, many of whom had little experience with performance light weight bikes.
Those importers went to Japanese bike makers and requested bikes that looked "just like this". There was a fast buck to be made during the US bike boom! A lot of those bikes weighed a ton, rode like tanks and handled like wheelbarrows.
As a whole Japanese people are smaller in stature than most "Westerners". Very few bikes produced for their home market have frames larger than 21" (54cm). Who there could ride a 58cm+ bike and know how it handled??
The cosmetics on Japanese bikes from the boom era on were generally better than comparably priced European models plus the easy shifting Suntour derailleurs compared to the "fussy" French derailleurs made them easier to sell.
By the mid 70's the cosmetics and looks of the Japanese made bikes improved even more. For example, Centurions started coming with long point lugs and fluted seat stay like those found on top European "racing" bikes.
But... the ride and handling in general didn't improve until importers like WSI sought out advice from experienced riders concerning frame tubing, geometry and handling.
One thing that I've never understood is why Ishiwata and Tange used heavy wall thicknesses on their fork blades for light gauge tube sets???
About 1977 I bought a set of Ishiwata 015 tubes to build a TT bike for a petite woman. At that time the thin sections of the 015 main tubes were .3mm thick. You could squeeze them between you thumb and finger (at least I could). The fork blades were 1.0mm thick, the same as used on all of their other 4130 tube sets from 017 to 022.
Japanese housewife syndrome???
Columbus SL blades were .9mm and some Reynolds fork blades were 1.0mm/.8mm and even as thin as 1.0mm/.5mm thick.
So, perhaps the same genius that specified the deeply fluted Sugino SP-KC seatposts for the IM Triathlon bike, specified the heavier walled seat tubes?
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 41 Post(s)
Liked 51 Times
It's driving me crazy that the frame is way to small for my 6', long legged frame. It's all cleaned up, polished and waxed, and all I can do is look at it. Aughhhh!
So, at this point, I might have to put it up for a Local Sale. I wouldn't want to ship it and take any chances on it getting damaged as I've had happen in the past. So, if anyone is interested and feels like making a drive to Long Island, please let me know.
Quoted: 1918 Post(s)
Liked 1,940 Times
Too bad. I'd like an 84 Turbo one inch smaller than my 24" but I'm in Los Angeles. If yours is a 23, maybe you'd like to just swap frames?
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Sweet score.. now I'm wondering about putting the silver accents and decals on mine with how good yours looks.
Likes For RaleighSport:
