Any thought with rear brake only for track bike?
Just wonder if anyone run a rear brake only for track bike? I saw some track bike came with one drilled hole for rear brake. Would anyone know if that would work well?
Thanks a million...
Thanks a million...
Philly bike nerd
Bikes: 2003 Fuji Track Bike,Pink Univega, Mixed part BMX, Early 70's Columbia Tandem, Orange and Cream Fixed gear Pursuit bike (Puig), random bikes made from spare parts
Thanks a million...
Thanks a million...
it really doesnt make much sense. Why put TWO brakes on one wheel, and no brakes on the other?
Hello.
especially when it's the wheel that gives you the weaker stopping power.
track bikes usually dont have brake holes drilled in the frame. if the frame has horizontal track dropouts and is drilled for brake holes, then it (frame) was meant for either a fix or single speed bike.
It's a track frame, it came with rear member drilled.
It's look like it is beefty enough to handle the brake force.
I wonder if anyone has done the same....
Go Fast.. Go Fixed!
Bikes: Marinoni Squadra Fixed Conversion, Eatern Woods Research "Original Woods" MTB, Eastern Woods Research -Modified Trials (20" wheels), and a home made Chopper.
https://www.craigslist.org/sby/bik/86385165.html
this Masi what your refering to?
Makes no sense to me either. Bike has supposedly sold anyway.
Hello.
if it was drilled in the rear and not the front, then obviously the frame and fork are off of different bikes. i honestly can't think of any reason to drill the rear but not the front.
(Grouchy)
yeah it's the Masi frame... I scored it for a friend who's moving from SF to CityCollege NY. It will be his first fixed gear....So he need some form of safety without spend too much $$..
By the way.. it was the best deal ever... I wish it was my size..
無くなった
Bikes: I built the Bianchi track bike back up today.
I think maybe that the fork crown on a lot of track bikes doesn't have enough metal or clearance to put on a brake, but the bridge can easily be swapped out or drilled depending on how thick it is. There probably wouldn't be as much tourque against the brake, and you'd most likely use it as more of an extra drag on long downhills...
The bridge on this one definitely thick like the regular road bike...I think they probably the same frame as road bike. Any Masi enthusiats out there?
Fear the banana
Bikes: 1950s EG Bates track & 1960s Frejus track
That hole is so you can add a reflector lol
If you have a back brake you should just be riding singlespeed. Your legs should be able to slow you down/stop just fine.
Ive talked to a few people that said they would be scared with only having a front brake. I don't see myself flying over the bars. (well unless I was dumb enough to put all my weight in the front and hit the brake)lol
The first Cannondale track frames had a drilled rear, but not front. They suggested changing forks from a round bladed, close clearance track specific fork to something more convention, ie road, for road use. There are also the clamp on fixings for a rear brake for Keirin frames, you can't ride brakless in Japan legally. They don't look pretty, but I think they are a bit stronger than the clamp on front adaptors.
tabula rasa
What I like about this forum is instead of riding and getting empirical verification (or listening to those who do/have) most people would rather do thought experiments.
Anyone who has ridden a fixed gear with ONLY a front brake knows it's more than enough.
Anything else is rhetoric.
hateful little monkey
I've got nothing against brakes of any sort. I loves 'em.
Originally Posted by jim-bob
You can also find a dozen people willing to tell you that hand brakes are totally unnecessary.
No doubt. The EMPIRICAL choices are FRONT BRAKE or BRAKELESS.
aka mattio
let's also remember that lots of people run two hand brakes because they don't feel like providing stoppin power with their legs--be it due to age, injury, or the view that using yr pedal power as a brake cancels out all of the work-out-related benefits of fixie riding (spin, toned muscles, etc etc)
N/A
Originally Posted by queerpunk
...or the view that using yr pedal power as a brake cancels out all of the work-out-related benefits of fixie riding (spin, toned muscles, etc etc)
I don't see how riding brakeless, skidding, or skipping negates the development of muscles or technique.
/edit: It obviously puts some extra pressure on your knees and legs.
Resident Old Fart
Bikes: Douglas Precision Ti
Having been taken down more than once in the last thirty years by riders on fixed gears using only a front brake I avoid riding with them or, at least, make sure they are in front of me.
Wag more, bark less
Wag more, bark less
midnight biker
aside from extra wieght, which if you arent racing then it doesnt really matter, or aesthetic reasons running an extra break on the back makes sense, especially if its for a newbie. im getting my stuff together for my first build and im definately putting front and rear brakes on the bike. id rather be safe than anything else.
Originally Posted by Olebiker
Sure, as long as you are applying the brake in a straight line, on dry pavement, and are riding by yourself.
I don't know who you've been riding with, bro.
Tell you what: hook up a fixie with a front brake only and try it out.
Then come back and report your findings.
just rhetoric otherwise
Resident Old Fart
The "front brake only" thing sounds good on paper but, in the real world, the only reason people started using front brakes only on fixed gear bikes is because they were using their old track bikes fitted with a road fork. The track bikes weren't drilled for a rear brake.
Wag more, bark less
Wag more, bark less
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
im reinstalling the back brake as soon as i get my new levers in this friday... i like having 2 levers for aesthetic balance... and if i've got 2 levers, might as well have 2 brake calipers.
i really like the hoods for climbing and having 2 brakes to scrub speed downhills... but i guess our new york city friends wouldn't know much about that. where do i turn in my hip card?
