Can this Huret Derailleur Bolt be Removed?
I have a Simplex rear derailleur without jockey wheels. I would like to use the ones off this Huret derailleur. However, I cannot get the bolt removed with a quality screwdriver, force, and blue language. The bottom came right out but the top bolt is integral with the pivot. Any advice?
Quoted: 1311 Post(s)
Liked 1,919 Times
Remove the tension on the return spring, and look carefully behind the spring and body. You should be able to get a 13mm cone wrench on the nut securing the cage assembly to the body. Hold that in place and then loosen the nut securing the body (there should be a 10mm nut between the rails.) The alternate method of attaching the cage would be a thin 13mm lock nut securing the cage assembly to a parallel pivot arm. When the cage is off, loosen the nut holding the cage together, and then the screw can be removed. Take it one step at a time and you will be able to remove the upper pulley. Those jockey wheels are lubricated ball bearing and difficult to find. I would put the original pulley back on and keep the derailleur intact.
Jockeys are easily found for a just a few dollars for the Shimano variety. It would be a shame for you to send this derailleur off the the scrap yard for having been parted out. HTH, MH
Thank you. I will give that a try. Thank you. Understand that I have some Shimano jockey wheels and bolts right in front of me. Neither one works on Huret or Simplex. The inner diameter of the wheels is different, and of course, so is the threading of the bolts.
Liked 1,919 Times
@Jicafold,
I use Chaser tech pulleys for rebuilds. They are sealed bearing pulleys that can come with spacer shims that can adapt to 5mm or 6mm. The inner diameter of the Chaser tech is 7mm so they fit just about all derailleurs. I have posted pictures and the link to them is n the Rebuilding a Campy rear derailleur. Hope this helps you, The Chaser tech comes in different tooth count as well, 10t is normal size. Price is about $16 per pair. (for comparison Bulls Eye pulleys are about $50 when you can find them).
Smiles, MH
BTW the inner diameter of the Huret is different for the upper and lower pulleys.
Smiles, MH
If you use Chaser Tech pulleys be careful with the color. Red will make you go much much faster immediately. Green will turn you into a retro-grouch and you will immediately slow down and start thinking of long tours in the woods. Ahem.
"It's a fine line between absolute genius and sheer stupidity"
Likes For etherhuffer:
Quoted: 523 Post(s)
Liked 467 Times
Quoted: 523 Post(s)
Liked 467 Times
It was missing the label. I wish I had that or I would keep it as is. Thank you. Maybe I could make a label on a printer and clear coat it. I don't know. Which is a better derailleur?
