Newb to GPS's. I just don't know what to get.
Quoted: 2432 Post(s)
Liked 641 Times
Never had any of these new fangled GPS thingies before. I've always used regular $30 cyclo computers. But now I have a super duper carbon disc bike so may as well go all the way. I need help deciding what to get.
I don't want to spend a ton of money. I don't really need GPS though it might come in handy someday. I doubt I'll ever buy a power meter. I don't need to read texts while I'm riding. When I'm riding I want to get away from civilization. I just want one of these GPS's because they have big screens with a lot of data I can see at once without pushing buttons. I do want elevation.
I've narrowed it down to the Bryton 530 and the Lezyne Mega XL. The Bryton is @ $150 on Amazon and the Lezyne is about fifty bucks more. I do like how you can turn it sideways and it seems to have even longer battery life.
Which one would you choose or do you have a better suggestion? I don't think I'm interested in any Garmins.
Liked 641 Times
And another newb question. Do they use wheel sensors? I ask because I see the "loaded" Lezyne bundle for $299 comes with a speed and cadence sensor.
Quoted: 3242 Post(s)
Liked 2,090 Times
Wheel sensors are really only needed if you ride in areas with a lot of tree cover or tall buildings, where the GPS signal (which is weak to begin with) can get lost. As well if you do a lot of group riding, the speed update from the speed sensor doesn’t lag the way a GPS would, So, easier to judge current speed.
Generally and for road rides, the GPS is accurate enough,
Liked 641 Times
I live way out in the country, lots of trees and sometimes my cell signal isn't too strong. I just don't trust a satellite signal here. Someone on ebay is telling the Bryton 530T's for $189 and the T comes with a speed/cadence sensor, HR and front end bar mount. Think I'll go for that one.
I have a Lezyne - it was my first GPS unit and a gift from Wife. The speed sensor will improve the accuracy of the speed. And difficult to do cadence without one.
Lezyne has live tracking via their website for persons of your choosing - via e-mail link - so they can track your rides live. Good when I take off to NC for a cycling trip. I am not aware if the other have a similar offering
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Wheel sensors know instantly when you are stopped, and are a bit more accurate when moving. They aren't required, but I like mine.
The GPS is from satellites all over the sky. But heavy tree cover can block it or slow down the responsiveness. Tall buildings bounce the signal, so my position is off a little when I'm downtown. It still works, even though it looks like I'm riding through the center of buildings at times.
That Bryton looks like a good deal. It's got all the statistics you'd want.
The Bryton has a minimal "breadcrumb" route following capability. It will at least guide you along a route, and warn if you get off track. More expensive GPS computers have full maps, with street names showing.
How to load a track, and what it looks like:
https://www.youtube.com/watch?v=9uyEtPKKP34#t=72s
I have the Wahoo Element Bolt, I think if you're looking at those others it may be worth a look.
And I believe the wheel sensor will also be necessary if you want to ride and track on a trainer (put the sensor on the rear wheel).
All that said, it is a lot more information than you'll ever need unless you are training for the TdF.
Quoted: 7352 Post(s)
Liked 2,479 Times
Being way out in the country might put you far from a cellular access point but you're no farther from satellites than anyone else. In fact, I find GPS works better in rural areas than urban areas.
If you want to save money, you may want to consider what I and many others do which is to use a smartphone. It's not perfect, but nothing is. I just didn't want to spend the money on a GPS bike computer and have yet another thing to charge and take care of and keep track of. You need two things to make it work well. One is an external battery to keep the phone well fed. A good one is only $20. Two is a good mount. Don't mess around here, because your phone is valuable. I made the mistake of trying cheap mounts and almost lost my phone. Quad Lock is high quality and reliable. I use the ridewithgps app, and there are others. Strava is probably the most popular.
Quoted: 4260 Post(s)
Liked 1,364 Times
Cellphones don't need cell-service to work as GPS units.
The GPS receivers in cellphones are pretty good. The bicycle GPS receivers might be a little bit better. But cellphones work well as GPS units.
GPS can have issues with lots of tree cover and canyons (even artificial ones in cities).
I started with a cellphone as my tool, but soon went to my Bolt. There are 3 problems with cellphones, battery life, visibility in the sun, and the need to keep it from going to sleep, which is also dependent on the first 2. And a fourth thing for Apple phones is that they don't support ANT+, the standard for fitness devices communicating, without a dongle, and the dongle is only available for older phones without yet another adapter. Bluetooth doesn't work as well. I tried using a phone for about 6 months and was frequently disappointed with the performance. I've used my Bolt for as long and just don't give it any thought, it just works. And it is always on a bike so no mounting/dismounting, although this is minor.
Liked 2,479 Times
@zacster is right, though those are not obstacles for me. If I want the screen and controls to stay on, I go to the phone's settings and turn the auto-off feature to "never." Then when I arrive, I have to remember to turn it back down. Another problem is that using the on-screen controls is difficult, at best.
Still, this is the setup I prefer. It's not for everyone, but nothing is.
Liked 641 Times
Thanks for the replies. I ended up buying the Bryton. $188 with a HRM and speed/cadence sensor was hard to pass up. It comes with that bar mount but looking down and seeing that thing over my front wheel might be too weird for me. If I got a stem mount do you think it would be too difficult to look down at? Something like this:
This one extends a little farther forward than other similar ones I've seen.
RWGPS has a setting that keeps the screen on while the app is running. As soon as you close the app once the ride is over, the screen also switches off. It's available when you start a ride, in the three dots on the top right hand corner (Keep Screen On) but once you set it, it remains set for all your rides.
Having said all that, I am leaning towards getting a dedicated gps unit for my bike. The charging point of my phone has started to act up now and accepts only certain cables.
Liked 2,090 Times
The models in your post position the GPS at about where the rubber band Garmin units sit, over the stem.
I prefer the out front as I’m not looking down as far to see data. It might place the unit in a spot more prone to damage, but seems OK on my mt. bike.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
First there is the speed. The speed pick up is a bit erratic and doesn't work if I'm traveling less than about 3 mph. On mountain bikes, I'm often climbing that slowly or even less. The computer will auto-pause constantly. I don't have a wheel sensor because they are stupidly expensive. $40 per wheel times 6 bikes works out to a lot of investment. Yes, I could move them from wheel to wheel but that's a hassle that I just don't want or need.
Then there is the run time. It's 8 hours...on the dot! Well, not quite on the "dot". At 7:59:45 of run time, it shuts off. Period. And it's not really a "run-time". It is a powered up time. If I ride to work and leave it on, it will be shut down for the ride home (8 hours plus one hour lunch is an hour past it's "bedtime"). If I happen to be on a ride that goes longer than 8 hours...tours, for example...it shuts down and I have no idea of speed nor how far I've gone nor, more importantly, how much further I have to go. And, because it is a "powered up time", breaks, stops, sightseeing, etc. are included in the time I have available. It's frustrating.
Additionally, you have to charge it every night. If you are out in the back country where there aren't any plugs, you are going to be SOL if you need it for navigation. I haven't tried loading up a course yet...I probably won't because I don't usually need courses...but I imagine that I would be quickly lost if it decided that it was past its bedtime.
It also has a quirk of when trying to find a signal. If I leave it on in the building, it sits there and tries to access the satellite constantly but it does it by "climbing". The one time I left it on at work, I found that I had climbed 1500 feet without moving an inch. That drains the battery.
I have recently found that I could charge it while recording but that means that it isn't on the handlebar showing me speed or distance because it can't be in the handlebar mount and be charged at the same time. It also resets when you charge it so even though I can charge it from an external battery, I lose any data I recorded before I started the charge. Again, that makes it so that I don't know how far I've gone nor how far I have to go...at least not easily.
I have done a work around for using it on commutes where I record the ride when I get to work, shut down the computer and then start it again for the ride home. But that means that I record two rides per day which I'd rather not do. And, frankly, having multiple traces of the same route every day is rather boring.
Bottom line: I'm glad I didn't pay full retail on this stupid thing...I wouldn't even consider full retail. It's an interesting toy but I'm not going to use it again for back country tours or even road tours in civilized places. I'm going back to my Sigma wired computer that records my data...granted, sans the mapping and altitude...and keeps working for years on the single little battery inside the computer. If I want to trace my route, my smart phone works just as well and has more features.
Stuart Black
Stuart Black
Liked 1,364 Times
They aren't a replacement for a basic cycle computer because the battery life is too short.
Most of the Garmin don't work this way (you can plug in an external battery without it resetting).
Liked 2,479 Times
I had a Garmin Edge 200. It was also quirky. The only thing I liked about it was that I didn't have to charge it every day. Maybe the higher models are reliabler.
Liked 1,364 Times
The simpler units (like the 200/25) might not be the best examples how these sorts of devices can be useful. cyccommute's comments aren't that useful because he had an unrealistic expectation of how these devices work.
Liked 4,222 Times
I know exactly how these devices work. I'm a reasonably smart guy and even know how they get their information. I'm also aware of their limitations, especially considering that I have one.
That's not how they are marketed. Nothing in Garmin's marketing says "you should use another computer because this one has limited battery life". Granted these are aimed at people who probably don't go wandering around for days on end without ready access to power. Nor are they aimed at people who might actually be riding longer than 8 hours.
If I put my phone in airplane mode, it isn't sitting there draining the battery because it isn't trying to find a signal constantly. A GPS (or any bicycle computer for that matter) that has an auto-pause function should not be drawing power while in auto-pause. It's "paused" which means that it should be doing anything. Apparently, for the Garmin unit, that's not what "paused" means since it is constantly trying to find the satellites when out of sight of them. That's should be a fairly simple software program to make the unit go to sleep for prolonged periods of no movement. Much less sophisticated bicycle computers have managed to do that while drawing very little power for a very long time.
As far as I can tell only one of the Garmin units for bicycles has that ability...the 1030. But the 1030 is even more stupidly expensive than the Edge.
Stuart Black
Stuart Black
Liked 4,222 Times
Honestly, I'm not sure that I get that much more for $170 (not what I paid) over $30 to $60 for a bicycle computer.
The unit should be able to record ride data...which it does...but it should have better power management. $170 may not be much in the GPS world but that's a lot of cash to lay out for what I consider to be a poorly designed product. My phone will do exactly the same thing for longer and I can do more than make phone calls on it. I don't see the reason for spending the extra case for the bike GPS unit unless it does more than the phone or at least as much as the phone.
Stuart Black
Stuart Black
Liked 1,364 Times
What would make that happen?
GPS takes power. It's fairly well-known that phones consume more power with running GPS all the time.
Basic cycle computers don't do anything like the same amount of work.
The phone has a much larger battery.
That's not true. It's still "draining the battery" but at a slower rate.
No. The "auto pause" just means it isn't running the timer for computing the (moving average). That's all that "auto pause" does. It's still receiving and processing GPS data.
With the GPS off, how can a GPS unit tell it's moving?
Phones can work.
The things that the Garmin units provide over phones is much smaller size, easier mounting, better battery life (keeping in mind the size), and screens that are easier to read in bright sunlight and can be left on all the time. Some people will find these things worth the price and some won't.
The ancient 800 has that ability and all the units that follow it.
Quoted: 2604 Post(s)
Liked 1,933 Times
