Are Presta valve caps uncool or what?
#126
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Is this what I think it is? Or not, I have not seen one.
Maxxis Presta Valve Stems and Core Removal Tool - Black - Ultimate Cycle Store
#127
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Look at aeronautics. Shape and surface texture are far more important than actual size.
Notice that the threading on a valve closely resembles the fins of an automobile radiator? What is the purpose of an automobile's radiator fins? To catch air.
Bikes with no valve caps are suffering extreme aero penalties, and therefore experiencing significant speed losses.
Again. Any serious cyclist worth his salt (should) understands the performance benefits of a light weight and efficiently shaped valve cap. There are a lot of folks out there with no real understanding of the actual physics involved. It's not their fault. They are neither engineers nor physicists. But don't allow yourself to be fooled by the naive and unsophisticated.
Right. I think the problem here is that those most prone to denying valve cap science do so in other areas as well, like pie plate diameter and kickstand shape... preventing them from ever getting to the speeds required for aerodynamics to be much of a factor.
These are nice, but only appropriate if you run carbon fiber rims.
#128
Quoted: 913 Post(s)
Liked 515 Times
Has no one mentioned that a presta valve has two lock nuts? One on each end? Do they cancel each other out when bombing a descent or does one need an opposite side aero reflector. Sooo much science to learn...
#129
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
When you run deep carbon wheels, most valve extenders are not threaded so no valve caps.
Personally, I don't run them since they serve no purpose. In 20,000 miles, i've never had a problem leaving them off.
#130
Quoted: 7652 Post(s)
Liked 3,473 Times
I'm telling you, get some long-stemmed-tubes and the right caps ....... I'm not saying TdF podium ... but ... Gyro?
#131
On Your Left
Liked 2,433 Times
Personally, they serve no purpose so why bother.
As to long stem tubes, I find using Zipp tubes with their extenders are no more expensive, they are not too long and they don't rattle.
#133
Quoted: 189 Post(s)
The ultimate caps!
How do you like THESE apples?
<1g ea, aero, poorly 3d printed...
#134
Quoted: 5888 Post(s)
Liked 3,471 Times
Bike Forums just ain't what it used to be if we can't push this topic up over 10 pages. We haven't begun to scratch the surface when it comes to presta valve caps.
#135
Cycleway town
The valve and rim manufacturers need to step up here. We know (from the innertube people) that the locknuts are important but we also all know they sit very poorly on the rime surface (like they are not so important) and scratch that pristine rim surface if tightened enough to stay on through all the vibration a rim gets.
So, get with it! Offer us some properly shaped plastic washers that will fit flush with both the complex curved surface of the rim and the lockwasher. Yes, you will have to provide quite a few variations because rims vary so much, but ... it is you who are telling us this is important. And isn't it your obligation to provide us the means to install these critical parts without damaging the finish of our $1000 wheels? (These washers probably need to have wrench flats so they can be held in proper alignment with the rim. Perhaps a small wrench could be included.)
With these washers, properly installed, we will finally be able to have wheels done right. No gaps under the edges of the lock nuts and no scarred anodizing.
Ben
Ben
#136
Cycleway town
This business of the valve hole letting water in has got to be stopped, too. I didn't buy a 24g carbon fibre bottle cage to carry half a pint of rainwater in my rims.
#137
Liked 941 Times
Needs more bling. Colors? Jewels?
That would mean instant BF bingo.
Great points, both. Almost all of the cyclists I know make these complaints often. (and it's not just the serious cyclists) There's likely a huge market ($$$$) just begging to be tapped here.
#138
Quoted: 4560 Post(s)
Liked 2,802 Times
Just for giggles, or because I was bored, I emailed a manufacturer of presta valve's and asked them their policy on caps and lock nuts. "Yes. We recommend to use cap. To avoid dust. And recommend to use locknut too. " So all you sloppy unkempt pin bending impaling death machine riding folks are going against manufacturer's recommendations. Good luck with your lawsuit
#139
Liked 2,802 Times
Locknuts don't really work too well with deep-wall rims. They don't sit flush with any rim actually, it's like there's a part missing.
Like a moulded plastic seat, similar in shape to some quick-release compression seats. Or they could at least texture/shape the compression surface of the washer, so that it bites into the alloy. Whatever, this is clearly an area that's seen very little in the way of development.
Hey, I knew there was a reason why I kept those old concave washers from my worn out linear pull brake pads!
Now I just need to superglue some weights on the opposite side of the rim to counterbalance the extra weight from those washers. I wonder if Wahoo makes a doodad and app to precisely calculate the weight needed three times before the doodad breaks and I switch to a Garmin rim counterbalance weight doodad.
#140
Cycleway town
Not a bad effort there. The profile of both the rim and lock nut a touch more advanced than the average effort. But then, so are dinosaur egg nests.
Ben
Ben
I think there's too much attention being paid to the whole locking thing. You're pulling on rubber, and really, it's only gotta hold the seat of the valve to the rim. We're not talking Stilsons here. The G-force isn't gonna send the valve through the tyre without a locking ring. So we can make the locking ring half the thickness, allowing it to be covered.
Now with the water resistance also in mind, by the time it was daylight this morning, i'd come up with this: What we have here is a corrugated silicone boot. It stretches over any valve type, gripping the valve stem tightly, and forms a tight waterproof seal against even the most challenging deep-wall rims...
Patents pending, or whatever.
#141
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
To solve this, as well as the locknut seating issue, it seems apparent that rim makes should thread their rim holes, and presta stems should be threaded all the way to the bottom. Yes, might take a few seconds longer to screw your tube all the way into the rim via the valve stem, but worth it for the peace of mind.
#142
Liked 3,473 Times
I think something as convenient and universal somehow has to be combined with something as specific and complex to manufacture as Shafter's effort from post #137 .... and then offered in a variety of colors.
#143
Bikes: Brompton, Time, Bianchi, Jan Janssen, Peugeot
Quoted: 598 Post(s)
Liked 5 Times
Do not people buy designer valve caps? I usually go for Ralph Lauren or Armani. Never Hilfiger, though, far too brash.
#145
Cycleway town
Insufficiently aero .... and too Schraederish. How will it look on longer stems? Well, I guess serious cyclists will machine their stems to leave just enough showing above the rim for a CO2 cartridge inflator--what serious cyclist would use a pump in the 21st century?
#146
Liked 941 Times
My only critique is the ugly flat black finish... that's been over played for years now. My preference would be a hi-vis/reflective finish, so I could safely remove my wheel reflectors.
*I'd still like to see the design submitted to an authority on cycle aerodynamics, like professor Squid, for definitive analysis.
#147
Quoted: 800 Post(s)
Liked 218 Times
Are Presta valve stem caps uncool or what
All this high tech discussion about valve stem caps reminded me of this product, colorful flashing valve stem lights:
When I bought them, I did think that the utility of such side lighting outweighed the arodynamic drag, and they looked cool.
Insufficiently aero.... and too Schraederish. How will it look on longer stems? Well, I guess serious cyclists will machine their stems to leave just enough showing above therim for a CO2 cartridge inflator--what serious cyclist would use a pump in the 21st century?
I think something as convenient and universal somehow has to be combined with something as specific and complex to manufacture as Shafter's effort from post#137 .... and then offered in a variety of colors.
One set of valve stem lights had the cute name, Tireflies.The problem I have seen with valve lights is that there is no way to easily turn them off during the day to conserve the batteries
#148
Quoted: 1364 Post(s)
Liked 1,677 Times
#149
Registered User
(Look for them at finer cyclists' shops near you!)
#150
Bikes: Salsa Vaya
Quoted: 172 Post(s)
Good point. The Serious Cyclist crowd should investigate the aerodynamics of paint. I expect that high performance aircraft don't use Plain Ordinary Bicycle Paint and that there are good reasons for that. Perhaps Professor Squid can comment.
