Wheel revamp
Wheel revamp
In my bike restoration project, I want to share the wheel revamp. The wheels looked like this:
And after loads of elbow grease, it looks like.
Amazing what metal polish can do. Not fully satisfied though, I should have fine sanded some parts of the rim (still has some marks/dents in it).
I guess it would be a better revamp, if I where to replace the spokes and then be able to clean the entire rim and hub even better. However, I never build a tire, and that looks quite complicated.
Meanwhile, while I'm at it, should I replace the (1 cm wide) rim tape? Any suggestions?
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Quoted: 1372 Post(s)
Liked 1,749 Times
New rim tape? Yes, absolutely! This rim tape, used and old, was still pliable when I assembled the wheels. Two years later, the tape had hardened to become brittle and started cracking up inside, eventually puncturing an inner tube. This is what that old rim tape came out looking like...
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 977 Post(s)
Liked 626 Times
Are pics 1 & 2 different wheels, or did you polish so much the hub is now much narrower? If the latter, I'm impressed!
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,461 Times
Looks like the rear and the front.
Yes, leave that to the pros.
But a wheel, on the other hand, is pretty simple to rebuild with the aid of Sheldon's wheel building page.
I use oil-soaked steel wool (0000 grit) to clean and polish the spokes.
Surround the spoke with a small ball and rub along the length of the spoke. Then, move to the next one.
No rubber harvest for me ;-)
Good idea! I changed my method for polishing the rear rim. First wet (WD-40) sanding with 400 then 600, 800 and stopped at 1000 grit. Then using metal polish to get the shine. Works faster then before, but perhaps sanding further with finer grit would be even better.
Quoted: 1627 Post(s)
Liked 630 Times
@SurferRosa I'm always ready to hear some expert advice on tire building. It's an area where I admit I have very little experience.
Likes For Lascauxcaveman:
Liked 1,749 Times
I use aluminum foil to clean spokes. If the wheel is disassembled, the foil also works to clean spoke hole eyelets. And, no fear of leaving any steel wool fibers to oxidize. Just crumple the foil, shiny side out, then rub the spoke. This works on steel, plated steel and chrome plating.
