How often do you flat?
Newbie MTB rider here.... today I was riding with a buddy who has many years of experience and on one of our breaks, he mentioned that he'd never once had a flat....
I'm thinking I've got a pack with a tube, bacon strips, pump, tire levers, etc.... and he's carrying nothing because years of experience has dictated that he never flats out...
So... how often do you flat? Are you always carrying the necessary spares?
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
When I MTBed I always carried the gear because I didn't want to push a bike for miles. But pinch flats are a reality if your really pushing yourself. At least they were for me on regular tires and tubes.
Quoted: 3032 Post(s)
Liked 1,198 Times
Never. Tubeless here also.
However the chance is always there that a flat could happen, so I carry a tube and CO2 cartridge.
With tubeless flats have almost become a thing of the past.
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,537 Times
The only flats I have had running tubeless over the past 10 years have been two sidewall tears.
With tubes, it really came down to how low I ran the pressure. Punctures were very rare, almost all flats were pinch flats.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Once a year or so. I dont carry tools on local rides anymore.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,125 Times
None since i started running tubeless (well over 12 years ago)
DH bike runs wire bead tires and tubes and i have flatted on that in thgat time frame though
Quoted: 889 Post(s)
Liked 840 Times
Don't have many, but the last time, after a couple of flat-free years riding at least three times a week off road, they came in "threes", two for me, one for my wife (fortunately, two were "goat heads" and discovered the next day at home and one was only a half mile from our SUV). Almost never got one when I used sealant, but twice I sliced the tire and it was a mess to repair on the trail since the sealant needed to be cleaned out, the tire booted and tube added. Yes, I carry what's needed. We get far out of civilization on many rides.
Quoted: 254 Post(s)
Liked 182 Times
Depends a lot on what kind of impacts your tires take and how low your tire pressure is. With low pressure, traction is better, but it takes less of a hit to pinch flat. If you're having a lot of flats, push the pressure up a bit. Or switch to a larger tire if you have space for it.
Habitual User
Quoted: 5035 Post(s)
Liked 8,240 Times
I would rather deal with the trouble of carrying a few repair items that never get used than the trouble of having to push my bike very far (and my bike doesn't weight a lot).
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I haven't flatted since I went tubeless, but I've ridden a lot places that I wouldn't want to have to walk out of. A simple repair kit just isn't that much trouble to carry.
Likes For Rolla:
Disco Infiltrator
Quoted: 3131 Post(s)
Liked 2,111 Times
I have gotten flats since going tubeless. Because my sealant dried out.
My flat kit is darts, more sealant, and a valve tool.
Genesis 49:16-17
Genesis 49:16-17
So... in a bit of a follow up....not many real punctures happen on a MTB trail.....sounds like the real issues are sidewall tears... hopefully recoverable with a tube installation.
A number of you carry stuff "in case" you are far enough out on the trail to make a walk back ugly...so... do you carry chain repair links and tools?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I've been riding mtb since '86. Flatted 2 times between then and '07 when I went tubeless. Not once since then on the dirt, once on the road. That single road tubeless flat ended my time using it, it was 8 years ago. Tubes on the road ever since.
Disco Infiltrator
Liked 2,111 Times
I also carry the ten essentials, or a reasonable subset of them if I’m close to a road or within cell coverage
Edit: and a mini pump
Very Senior Member
Quoted: 413 Post(s)
Liked 343 Times
Advanced Slacker
Liked 2,537 Times
Quoted: 1952 Post(s)
Liked 2,190 Times
Actually I busted a chain once and didn’t have a chain break, or quick link, but it was only 4 miles and a good portion was downhill. I carry them now. When we went to Arizona I picked up some goat heads on one ride. I did have an extra tube and patch kit. A multi tool, and multi spoke wrench is nice for when things happen, like when our son busted a spoke on a ride. Worst part of that was how great I felt I was riding until we realized his rim was hitting the brake pad.
But the reality is, I don’t flat much. But carrying tools are just in case because flats, or breakdowns, can ruin a ride, but when it a hike it is that much worse.
John
Habitual User
Liked 8,240 Times
I flatted a MTB tubeless tire yesterday. It burped on sharp drop off, and there wasn't enough juice left in the tire to seal it up again. I put a tube in it and finished my ride. Unfortunately, my attempts to go back to tubeless with that tire completely failed (stretched bead), so another tire has been ordered.
Member in Training
My son runs tubeless and I use tube's, call me old fashion. One time he broke a spoke and it pierced his rim tape and leaked all the air. Lucky we had a spare tube, levers and frame mount hand pump to get it repaired and finish our ride.
Quoted: 581 Post(s)
Liked 921 Times
I did a long tour a few years ago and flatted almost every day, sometimes multiple times per day, including 1km from the bike shop where I installed a new 'flat resistant' tire.
I completed a tour this summer with zero (0) flats, which brings my total for the year up to zero (0)
Quoted: 2236 Post(s)
Liked 1,314 Times
Running tubes, the only flats recently have been a spate when blackberry thorns were particularly prevalant. I put some sealant in the tubes and haven't flatted since. If I lived in thorn country I'd run tubeless.
I always calculate the results of failure when selecting repair gear. What I take depends on how far I want to push/carry my bike.
A precautionary tale about tubeless (and tubes too I suppose): Met two older fellows on the trail with new e mtb bikes. One had burped the front tire and lost the seal. They only had a mini pump that would not re seat the bead, had lost the sealant, and were scratching their head about what to do. It was a long push out for that heavy bike. Finally, one of them dug around in an accessory kit and found a tube and thru axle wrench. I left them just as they realized they had to pull the tubeless valve stem in the rim to use the tube... That burp was going to result in them taking their bike back to the shop for somone to re set up their tubeless system.
What ever system you use don't assume it's bulletproof and figure out ahead of time how you will fix a failure.
Liked 1,198 Times
B.) No big deal to pull the tubeless valve stem. Can be removed by hand. And why would they have to take their bike to the shop for someone to set it up tubeless? Can be done very easily at home. I've set up all of my tubeless both mountain bike and fat bike with a hand pump and orange seal.
Liked 1,314 Times
A.) If you were tubeless blackberry thorns wouldn't be a concern. The sealant would take care of that.
B. From the way they were struggling to figure things out in the field I assume they will not magically be able to remount tubeless back home.
