Replacing a threadless fork?
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
Should any 1 1/8 threadless fork work with any bike that has that kind of fork?
AND, will all the little plastic ring parts that are on the top & bottom of the stearing tube be fine to use on the new fork without purchasing anything else?
Quoted: 1074 Post(s)
Liked 295 Times
Well, no.
All threadless forks aren't interchangeable.
1 1/8" is a quite reliable standard. But first the fork needs to have the right steerer tube length - or longer - to be possible to fit it to the frame.
Then the fork legs needs to be right too. The axle-to-crown distance needs to be about right, and the rake - forward extension - needs to be about right too.
Then the fork needs to be compatible with the brake type you intend to run.
Dropouts have to match the axle type in the hub you want to use.
Width by fork crown needs to allow the type of tires you want to use.
But yeah, all forks with 1 1/8" steerers should be able to use the same headset.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
Well, no.
By little plastic ringers are your refering to the spacers? those should all fit.
fodio
Mountain Biking
5
02-18-14 10:27 AM
fodio
Bicycle Mechanics
3
02-17-14 06:27 AM
Barrettscv
Classic & Vintage
23
11-06-13 09:02 AM
