Quick release on front wheel
Quoted: 722 Post(s)
Liked 353 Times
Is this an ok thing to do?
i have a sweet old school 28 spoked American Classic front wheel begging to be used.
Yep, in fact that is SOP for my FG road riding.
If you have to install a fresh tire measure to make sure and fit the widest supple tire that clears the fork to get a more compliant ride, the same applies to the rear as wear requires.
-Bandera
-Bandera
Quoted: 4806 Post(s)
Liked 3,932 Times
I've been riding fix gear with a front QR since I started riding fixed in 1976.
I don't ride the widest possible tires on any of my fix gears unless I am going off road. Did a century Sunday on 25c tires. (Now that is pretty close to max on that bike as it was designed around a 25c rear tire slid forward to almost touching the seat tube and Sunday I put the 23 tooth on for the biggest hill. About 2 mm either side. Would have been even closer with my 24 tooth cog.)
My winter/rain/city fix gear is set up with 28c Paselas. It has room for bigger (I could probably run 35s on that bike) but I never felt I wanted a bigger tire on pavement with no snow or ice. I really don't like big or squishy tires on my fix gears. On gravel, I will ride narrow tires I simply won't on a geared bike. This is in large part because I have felt from the beginning of my fix gear riding the fix gears will power through problems and come out the other side. (Not always and I try not to be stupid, but many times I have continued on with no more that a temporary heart stoppage from road pothole, rut, debris encounters that I was sure was taking me down. The control of a fix gear at moderate speeds is a lot like a manual transmission in a car and is a huge benefit on gravel, snow and ice. I used to commute on roads I simply could not ride on a geared bike in my Massachusetts/Michigan carless days. In winter, 33c or smaller cyclocross sewups.)
Ben
Ben
Quoted: 2952 Post(s)
Liked 3,106 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Unless you're racing on a track, there's no problem using a quick release on the rear wheel, either. Just be sure to use a traditional, enclosed-cam quick release rather than those new-fangled open-cam designs. Those open-cam ones don't clamp firmly enough to hold the wheel in a horizontal dropout slot.
