Viscount Aerospace GP
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I happened into this Viscount today. I bought it mostly because of the crank (made by TA?) but I would like to know a little more about it if possible.
It appears to be a middle of the road bike with some original parts swapped out. I don't think the weinmann 590 sidepull brakes are original. The seat post is also, way too small... can anyone tell me what it should be? No death fork. The shimano titlist derailleurs are basic but nice looking (IMO).
The decals are nearly gone and some one painted over the headbadge... I am guessing they were touching up the red, is that original?
Anyhow, I'd like to learn a little more about the brand and see pictures of others possibly.
What grabbed my interest:
Crummy Vinyl Brooks and pinched seat tube:
Quoted: 3811 Post(s)
Liked 6,713 Times
The crankset has the same 50.4 bcd as TA and Stronglight 49D, but unfortunately those Viscount spindles didn't have any taper, so those cranks don't fit on anything else unless you do some judicious filing. Otherwise, Viscounts/Lamberts were outfitted with lots of parts labeled and produced by Viscount/Lambert: centerpull brakes and brake levers, sealed-bearing hubs, pedals, stem, and bars. Seatpost is a 26.8mm and would have originally been some sort of straight-pin alloy.
Neal
Neal
No one cares
yup. I have that exact bike at home. I tried polishing that crank up and it came out pretty well. My bike might even be the same size as yours. Yours is in better shape though.
I prefer emails to private messages - holiday76@gmail.com
Jack Taylor Super Tourer Tandem (FOR SALE), Jack Taylor Tour of Britain, Px-10, Carlton Flyer, Fuji The Finest, Salsa Fargo, Santa Cruz Tallboy, Carver All-Road .
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Look around my Flickr account to see the rest of the Viscount and Lambert content.
https://www.flickr.com/photos/21098570@N05/page2/
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Neal
Neal
Some of the cranks used a tapered spindle although I'm not sure if it was JIS, ISO or something else. I think Viscount figured out the non-tapered version was a mistake and cut-in a tapered version at some point. You'll have to check to know since I don't think there is any visible difference on the exterior.
I might be interested in the frame if you decide to get rid of it. What size is it?
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
The frame is actually larger than I thought, it measures 63cm C-C with a 59cm top tube. I do doubt that I will keep it, but I am not sure either way yet. I will keep in mind that you asked about it and let you know if and when that time comes.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
What do you need a TA extractor for? Not the Viscount crank; that fits the standard 22 mm one. I read somewhere it's actually a 7/8", i.e. 22.2 mm, thread; but the Shimano/Sugino/SR/Campy extractor works. Wait until you see the spindle, then it'll come home to you!
I run mine on a tapered spindle, having filed a taper into the crank as Neal mentioned. I didn't measure anything, just took a file and went at it. Works fine! My crank is an earlier model than yours; the chain rings are shaped like TA rings, with regular shaped cutouts rather than those big circles.
And yes, I believe the red is original.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
As you said, the red is original but it looks like someone added an additional layer of red to mine right over the headbadge. I tried to delicately cut away the red paint from the badge but there wasn't much worth saving underneath. I used nail polish remover and now there is just a shiny foil crest.
is just a real cool dude
Quoted: 32 Post(s)
Liked 34 Times
Also you just can't toss any old bb into those things since there no thread inside the shell. Wacky stuff. Cool find I was eyeball g one exactly like that a big swap meet a few weeks ago.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I think I am going to try to make new decals on my own for this one. I seem to have all the resources I need... clear adhesive, Epson commercial proofers and Adobe illustrator. I think if I leave the foil shields, I can print the badge on clear material and stick it over top. It's worth trying.
At first blush I wasn't very impressed. I am starting to see the charm in it... still wouldn't call that impressed. I have only ridden it two miles so far... I want to say it's sort of noodly feeling but I guess that is premature. It's interesting though that it seems to be a little different feeling.
multimodal commuter
Liked 574 Times
Keep us posted!
So you're going to replicate/repair the original decals, right? I'll be interested to see how that comes out. I considered doing exactly that with my Lambert, but not only were the decals were pretty far gone, just the foil remaining, but they were pretty ugly to begin with. I decided I could do better....
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Dumb question, how can I know for sure if the spindle isn't tapered? I took the left crank arm off and was able to fit a Shimano tourney crank arm onto the viscount spindle. Likewise, the Viscount crank appeared to fit a japanese spindle I had in the basement. It's probably obvious but I am not spindle savvy. I'm guessing that the fit is close, but not quite right? Maybe I am asking the wrong question?
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Keep us posted!
multimodal commuter
Liked 574 Times
I haven't decided whether I'll eventually do the headbadge and seat tube badge using the same technique to apply color to the foil things (which are original) or if I'll hand paint them. I also want to put a decal on the crank arms.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I had already drawn up decals for a 1950 Norman Invader in CorelDraw (the approved C&V graphics program) for a bike I ended up not getting, so I rearranged the letters and drew a couple more letters and printed the black lines on waterslide paper, backwards. I colored that in by hand and applied the decals to the frame backwards. A little white glue helps.
That black sticker on the Viscount cranks leaves a lot to be desired. I thought about either removing it or making something new. My only hesitation is that I feel like a temporary owner and feel responsible to leave it alone if possible.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I should take a picture next to the other spindle that I have... I can now see a difference. Picture coming in a few minutes...
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Ok, here is a JIS Shimano cartridge compared to the Viscount spindle. The shimano taper seems to be longer.
Here is the Shimano Tourney crank on the JIS spindle. It nearly touches the BB.
Here is the viscount crank on the same JIS spindle. Is clearly sits further out on the spindle and illustrates the difference.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
I've got the cartridge bearings removed. Any tips on how to press new ones in without damaging them?
Liked 6,713 Times
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
The Viscount spindle looks tapered in the photos; it isn't. Measure the width of the flats at the ends and their deepest point. Those Viscount spindles are prone to breaking at the C-clip - combined with their lack of taper, they aren't worth the trouble to bother with.
Find a framebuilder with Italian thread taps and thread the BB, then swap the arms for TA, Stronglight, Sugino, VO, Electra, or whatever 50.4 BCD arms suit your fancy.
-Kurt
-Kurt
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
The Viscount spindle looks tapered in the photos; it isn't. Those Viscount spindles are prone to breaking at the C-clip - combined with their lack of taper, they aren't worth the trouble to bother with.
-Kurt
-Kurt
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Where is my mind? That sounds like a good idea.... now I just need to replace my broken vise. I've got a great big C-clamp that would probably work along with some wood.
Liked 4,396 Times
FYI, that's a Suntour Perfect freewheel body with a single cog. I figured that would facilitate the conversion of this thing back to a geared bike if and when someone with the parts got a hold of it.
-Kurt
