Help on matching parts to a frame...........
Here's the run down. I have a 2007 jamis nova frame. I found a great deal on some take off parts that came from a 2011 or 2012 Salsa fargo 3. I need to know which if any of these parts would work for my frame.
Shift Levers Microshift bar-end
Front Derailleur Shimano Deore
Rear Derailleur Shimano Deore 9 spd
Crankset FSA Alpha Drive Trekking
Bottom Bracket FSA PowerSpline
Here is a link to both bikes. Remember the parts above are the ones I am looking at putting one the jamis nova frame.
https://www.bikepedia.com/QuickBike/C...9#.UcOP-OeR9vA
Any and all comments/advice is welcome, and thank you all in advance for the invaluable knowledge your about to provide me. Please let me know if you need any further info.
Quoted: 453 Post(s)
Liked 104 Times
The Bikepedia link gives no specific sizing info, so
Only if you still intend to run drop bars
Yes, depending on the seattube diameter, spacer are avaliable to fit
Yes
See BB
You need to measure the bb vs frame, although being road, both should be 68mm.
Get yourself a vernier caliper as this will be very useful in measuring parts to confirm fit.
Yes
See BB
I do plan on running drop bars, and eventually would like to move from the bar end shifters to shimano brifters.
As for the seat tube diameters that info should be available from the bikes' respective archives right?
As for the bb if both are the external bb's shouldn't it simply be a matter of using the proper spacers?
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
Both bikes use the same bottom bracket dimensions and thread. The take-off parts should go right on to your Jamis.
Jeff Wills
Jeff Wills
Thanks for the replies and the info on the bb was very useful. Sadly the guy I was going to buy the parts from this morning informed me that he sold them to a co-worker instead. Can't blame him I mean much safer and simpler dealing with a co-worker vs a random person from craigslist.
Okay so I know its been a while..........like forever really, but I have finally made some serious progress building this bike. At the present the bike has the following components:
2007 jamis nova frame(used) -$100
Cane Creek s-13 headset (new old stock)-$30
Tektro Mini-v Brakes(new) - $20
Oval Concepts mtb bar(take-off) - $10
Oval Concepts stem(take-off) - $5
Shimano Alivio 3x9 Shifters(take-off) - $20
Avid fr-5 brake levers(new) - $20
Carbon Wrapped seatpost(used) - $15
Ergon large Grips(returns) - $10
Shimano deore rd(used) - $10
Mavic Aksyium wheelset w/vittoria zaffiro tires and 9speed cassette (almost new) - $75
Specialized bg revival saddle(take-off) - $5
I am still missing a crankset/bb and a front derailleur. I plan on posting pics of it soon.
The final question I have for the build is about the fd. I need a fd that is for 3x9 setup but I don't know if it needs to be a top or bottom swing? If it helps the cable pull is a bottom pull and the tube diameter is 28.6.
AND as always thanks for all the help that got me this far, and also for the future help!!
Quoted: 2026 Post(s)
Liked 1,096 Times
One problem I see in your parts list is the use of Tektro Mini-V brakes with the Avid FR5 levers. Those levers are "long pull" and designed for use with full size "V-brakes". The Mini-V's are designed for road (shorter cable pull) levers. The levers will work but will require higher than normal hand pressure for a given stopping effort.
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
The swing direction isn't that important, personally I'd go with a bottom swing unless the clamp interferes with the bottle cage bolts. What is important is that you use a MTB FD because your front shifter is indexed and that it matches your chainring sizes and chainstay angle.
Given the picture of the downtube is there any reason why a top swing fd wouldn't work in because of the cage bolts?
Bezalel my friend, you are amazing!! This is exactly what I need to buy my fd.
