ISO and for trade thread part 5
#301
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
If this is what you are looking for, you have correctly identified them as an R-clip even though they are shaped, and used, exactly like a P-clip... They are $6 for 4 at VO. Sadly, I don't have an extra.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#302
Quoted: 76 Post(s)
Liked 19 Times
I have a pair of Shimano M535 pedals and a pair of Shimano PD-A525 clipless . They both seem to work, but I don't have the shoes to test that for sure.
If someone wants them all I ask is cover shipping and I'll send them out. Send me a PM.
The A525 pedals look like they'll clean up okay and the M535 are well used.
#303
ISO Seat post for 87 Schwinn super Sport
My current seat post is not long enough. At 16 cm in length, I can only get about 9 cm sticking out the seat tube safely. thats not enough for a proper bike fit. The Schwinn Catalogue shows that its a 26.6 mm diameter seat post. does anyone have ideas how I can find a suitable one for my needs?
The black line indicates what I believe to be the minimum insertion line.
the length is 16 cm. The seat post looks longer because the measuring tape is lower.
#304
Quoted: 912 Post(s)
Liked 515 Times
#305
The washer looks broken. Also, the frame has minor damage where the washer comes in contact with right side of the clamp at the top of the seat tube.
#306
there is the slot!
there is the tang and damaged washer.
I only just now realized that there is a small tang on the longer side of the clamp bolt that is designed to fit in the slot on the L side of the seat tube clamp! (Duh!) I think I installed the clamp the wrong way and slightly damaged the top of the seat tube clamp on the L side.
#307
Quoted: 4511 Post(s)
Liked 6,378 Times
there is the slot!
#308
merziak,
I think the grease on those threads is 31 years old! I will definitely clean those threads. I will look into the anti-seize compound, don't think I have any of that in the garage. Thanks, I appreciate your input.
#309
Quoted: 3810 Post(s)
Liked 6,690 Times
Kind of a long shot, but I'm looking for the hardware for this style SR seat post:
Un-sticking a seat post.
I have plenty to trade; let me know what you're looking for.
#310
I've looked on amazon and found a Kalloy 26.6 mm seat post that would fit my needs. Some reviews state that they had to sand them in order get them to fit in the seat tube. I couldn't find any Nitto seat posts that were 26.6 mm. Will keep looking.
#311
Quoted: 930 Post(s)
Liked 1,291 Times
ISO: I'm looking for a drop bolt for a '70s nutted rear Campy brake. It doesn't need to be Campy...it just needs to work. Something like this:
#312
aka: Dr. Cannondale
Quoted: 2154 Post(s)
Liked 3,403 Times
Kalloy makes a good, solid, reliable and looooooonnnnggg seat post. Not particularly thrilling in design, but competent.
#313
Quoted: 912 Post(s)
Liked 515 Times
#314
Hello All,
Thanks for that feedback! It's kinda funny that all the Kalloy seat posts available in US from Amazon or ebay are like 350mm in length! For some reason, sellers in Eastern Europe have some that are 240 mm or 300 mm. I prefer to buy from US sellers.
#315
ISO Rear Wheel Alignment Screws
According to T-MAR, BF 2013, Adjustment screws for rear drop outs are helpful in aligning the rear wheel and improved shifting capabilities, especially with older friction shifters. One BF member mentioned that you can buy 3 mm screws at the hardware store! If so, is it necessary to use springs and little acorn nuts on the ends of the screw or just use a M3 x .5 screw? Also, if I have installed a newer Shimano 5500 derailleur, are the adjustment screws still helpful?
#316
Quoted: 912 Post(s)
Liked 515 Times
#317
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
#318
FBOATSB and JohnDThompson, Thanks for weighing in. Armed with this knowledge, I can decide whether or not it is worth it to spend $10+ dollars on some NOS Adjustment Screws for the rear drop outs.
#319
Quoted: 1199 Post(s)
Liked 1,354 Times
Found
Thanks nesteel
Thanks nesteel
#320
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
ISO a trade for a longer black Cinelli stem
NO LONGER AVAILABLE.
Here’s what I have to trade for 120mm or longer. Similar condition, I can slam-it for the bike it is going on.
Scratches are confined to the insertion portion, but a nearly full circle one, approx one inch below the bend.
26.4 bar clamp, 22.2 insertion.
edit: 10 cm extension on this one, angle of photo is not clear
#321
Quoted: 3811 Post(s)
Liked 3,336 Times
ISO - AFA frame pump part
Have AFA (Poutrait-Morin) frame pump model 318 for which is needed a replacement piston cup. This is part number 22PE. Does anyone know a source for Poutrait-Morin small parts? Thank you.
#322
Peugeot PSV10 or somethin
I have a lot of pretty unremarkable vintage stuff. currently ISO gum Campy brake hoods NR (i think) for a 73 Raleigh Professional. They're the kind with the older sun logo and the word "campagnolo" in script across it.
Also would like a nice looking, tall and short (60mm) 1" quill stem with 26mm bar clamp. Prefer black but woudln't say no to a silver Nitto.
I have a Profile quill stem 120mm x 26mm clamp, random 25.8 seatpost, 30.9 from a Rockhopper, full Shimano light action group (i think) Suntour Lepree shifters and front deraileur, diacompe G brakes, Titec Malone bar, generic carbon clipless pedals, shimano 105 8 speed RD without pulleys, 9 speed (i think?) Campy Veloce RD....
#323
oh also have some Dura Ace 7700 bar ends (9/8s) and some pink nylon toe straps. The nicer kind with metal buckle things. Not trying to sell here just trade or would give away most stuff.
#324
Quoted: 912 Post(s)
Liked 515 Times
Rubber washer 22 mm - ZEFAL
#325
Liked 3,336 Times
Thank you for this suggestion.In this model of pump there is no fastener to affix the cup to the shaft.The end of the shaft has a plastic barb which is crimped in place.The cup snaps over this plastic barb.I could try a rubber cup but suspect it might be too flexible to remain in place during use.The plastic one which comes with the pump is fairly brittle so as to snap into its seat.The brittleness is the need for a replacement as it has crumbled with age.-----
