"Carbon would have bounced back"
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Shimano C24 wheels. These are the hybrid carbon/aluminum wheel. The alloy skeleton is thinner than a standard aluminum wheel and crabon is laminated on top of that. It isn't full crabon.
So I hit a pot hole and it needed to be trued. I brought it to an experienced mechanic whom I trust. He did the best he could but it is still out of round. A section of the rim about two inches long is dented in toward the hub by less than 1 mm. 16 spokes are too far apart to pull the section of rim.
"Carbon would have bounced back" was what he said.
What say you? Would it have bounced back?
-Tim-
-Tim-
Quoted: 4792 Post(s)
Liked 3,918 Times
I never understood mixing CF and aluminum for rims. Logically, either all aluminum or all CF would be stronger on impact. CF is a high modulus, very strong material that cannot handle a large yield. Aluminum is low modulus. You have to deflect aluminum a lot for it to be doing any work to support the load or impact. So, with a mix of the two, by the time the aluminum is doing anything, the CF has already failed. Yes, the rim is still in one piece and you are still riding safely, but the rim is no longer round or the original strength.
(Now aluminum braking surfaces are another matter. I can see that, but the aluminum there should not be considered structural, merely a sacrificial braking surface.)
Ben
Ben
Bad example
Quoted: 820 Post(s)
Liked 185 Times
On the other hand, a rim with a decent number of spokes might not have bent at all. I still build my wheels for 36 spokes, being a curmudgeon.
Liked 3,918 Times
Ben
Quoted: 1975 Post(s)
Liked 232 Times
Ben
Ben
Liked 232 Times
If the tire pinches (with or without a flat) the pothole edge is hitting the rim directly with virtually no padding from the thin, hard rubber and sidewall, but there will be no road rash. Usually hitting like this will cause the characteristic "snake bite" two holes but not always even with tubes and rarely with sewups. Never ridden tubeless so I cannot say what happens there. In my sewup days, I dented more than a few rims and don't recall ever seeing road rash. Usually did not flat. (Finished a race once on two dented rims (RR tracks) and twice road home on sewup rims with 2" dents. Did flat once in a race on RR tracks with no rim damage, so there is no "always".)
Ben
Ben
- Soli Deo Gloria -
Liked 736 Times
Trying to figure out if I spend the money to re-lace the wheel, buy a new wheel or spend the extra for carbon.
Thanks.
Good posts from all.
-Tim-
If they were Chinese carbon rims, they would have assploded and you would be in the grave right now.
Quoted: 3225 Post(s)
Liked 2,056 Times
You might never know with a carbon rim if it suffered enough non-visible damage that compromised the wheel integrity. So an advantage with aluminum in that case, at least you can see it's toast.. Kind of like a carbon bike that was crashed, would you buy it used if you knew ?.
I'd be replacing the wheel with a DA replacement.
Quoted: 7346 Post(s)
Liked 2,453 Times
Yes, I think pay the money for a new rim or wheel and let this one go. @79pmooney gives good (to me) reasons for not getting another hybrid rim, though if you still have one or more, keep riding it or them.
Quoted: 18354 Post(s)
Liked 4,502 Times
However, remember that the hub hangs on the spokes.
The actual spokes don't support the rim on the bottom, although they do help keep the rim round through tension.
But, a gazillion spokes might not protect the rim at a point impact because they aren't actually holding the rim outward.
The tire may have kept the rim from being marred, but the rim did take the force of the impact with the road.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
in a word - yes. Alloy bends when it hits obstacles. There's really no fixing it. I do a lot of rim swaps for that reason. Doesn't happen with carbon. Really one of the big features in my world when in many cases the carbon and alloy rims are near same weight. I deal with a lot of racers and racers hit things - especially in cross. Carbon does way better.
That said when you exceed carbon it just breaks. Rest assured that the same impact would have destroyed an alloy wheel as well.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Liked 4,502 Times
I assume many people have seen the "Road Bike Party" clips. There are a bunch of them.
And, as I understand it, there were a few "outtakes", but the wheels really held up well. A few more spokes than some road wheels, but Carbon Fiber nonetheless.
Liked 232 Times
https://www.youtube.com/watch?v=7ZmJtYaUTa0
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
https://www.cyclingnews.com/news/whee...ico-ambitions/
https://road.cc/content/news/218799-...-broken-wheels
- Soli Deo Gloria -
Liked 736 Times
The same thing did not happen to me. Both clinchers stayed inflated and on the rim during the impact and until I rolled to a stop. About 15 seconds after I stopped I heard the pffffffffffft of the rear tube failing. About 5 seconds later I heard the front let go too. The rims never touched pavement directly.
-Tim-
- Soli Deo Gloria -
Liked 736 Times
Tim-
Liked 406 Times
Were not both of these due to tubulars coming off the wheel and the carbon rolling directly on the pavement? I'm sincerely asking, not trying to challenge.
-Tim-
-Tim-
https://www.velonews.com/2017/06/new...tirreno_439821
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I've cracked four carbon rims on holes: A Zipp 303, a Zipp 404, a Hed Stinger 6, and a Neuvation 50mm. All tubulars. Flatted the new tire on the neuvation, but all the other tires were fine.
So, in my experience, no. Carbon doesn't bounce back. It just cracks loudly and makes for an expensive replacement.
