Friction shifting with 11 speed Campagnolo
Old 04-29-19, 11:37 AM
kansukee
Quoted: 122 Post(s)
Liked 51 Times in 27 Posts
I posted this in the road forum and someone suggested I should post here as well...this is my ‘85 Fuso running Athena with Dia-Compe Ene Ciclo 11 dt shifters. Next step will be to install a set of NOS Athena aero brake levers with QR and replace the bars stem with Cinelli XA stem and Criterium bars.
kansukee is offline
Likes For kansukee:
Old 04-29-19, 11:57 AM
shoota
shoota's Avatar
Quoted: 1872 Post(s)
Liked 692 Times in 468 Posts
Man I set up friction 11s once and it was terrible. The cogs are so close together that each shift required a post-shift finessing to get it silent. It sucked.
2019 Salsa Warbird
shoota is offline
Old 04-29-19, 12:07 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
I was wondering about the fine tuning. I have 9-speed DA friction shifting on my TT bike and that works fine, but was wondering what would happen if I went 10 or 11.
caloso is offline
Old 04-29-19, 12:18 PM
CliffordK
CliffordK's Avatar
Quoted: 18347 Post(s)
Liked 4,497 Times in 3,344 Posts
I've done some experimenting with 11s & (augmented) friction shifting. Shifting seems to work reasonably well, but I've had a bit of an issue with getting enough lever throw.
The vintage Suntour Bar End shifters came up short with my config.
The vintage Shimano bar end shifters had adequate throw, but had too much spring on the high gear end, and not enough spring tension on the low gear end. Both ways, it didn't hold the lever in place.
For brake levers, Campagnolo makes a carbon lever equivalent to their 9/10s brifters.
CliffordK is offline
Old 04-29-19, 12:24 PM
kansukee
Quoted: 122 Post(s)
It’s been surprisingly good so far (56) miles, no issues with having to overshift and trim. I just move the lever a bit till I feel the gears change and that’s it. These have a larger barrel on the right lever if it makes any difference.
kansukee is offline
Old 04-29-19, 12:51 PM
repechage
Quoted: 3463 Post(s)
Liked 2,826 Times in 1,994 Posts
The ene cyclo lever with the oversized cable sheave should help quite a bit.
repechage is offline
Likes For repechage:
Old 04-29-19, 01:16 PM
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3854 Post(s)
Liked 6,448 Times in 3,188 Posts
Is that the way this works, with the larger shifter barrel?
SurferRosa is offline
Old 04-29-19, 02:47 PM
Spaghetti Legs
Bikes: Numerous
Quoted: 1676 Post(s)
Liked 3,084 Times in 911 Posts
That's a gorgeous bike! I've never seen those shifters before' I like the look. I have a 3T status stem on one of my bikes and like it but the gray finish and weird plastic cap turn me off. The XA stem will complement the bike nicely. Icing on the cake would be a silver Athena crank.
Spaghetti Legs is offline
Old 04-29-19, 02:58 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
gaps are very narrow with 11 in the width of 8.. I stuck with 6 and maybe 7 with out issues..
yea bigger lever capstan diameter pulls more length sun tour bar end
shifting Campag Euclid over 6 speed width is what I match as full swing of the lever..
Touring triple ,
fietsbob is offline
Reynolds
Passista
Reynolds's Avatar
Quoted: 866 Post(s)
Liked 720 Times in 395 Posts
That's a really nice frame.
Reynolds is offline
Old 04-29-19, 03:07 PM
kansukee
Quoted: 122 Post(s)
Touring triple ,
All I know so far is that with Athena 11 it shifts perfectly fine. No need to trim, nothing like that. Maybe earlier RDs were pickier about this though...
kansukee is offline
Old 04-29-19, 03:10 PM
kansukee
Quoted: 122 Post(s)
I hear you about the silver crank. They have become very hard to find in UT and all I have seen are either 50/34 or with 175mm crank arms...😕
kansukee is offline
Likes For kansukee:
Old 04-29-19, 03:19 PM
fietsbob
Bikes: 8
Friction shifting
I;ts all hand feel
I had a 3 cubed , 3 shift lever bike in 1957,
3 speed IGH, 3 cog cluster + a triple crank, 27 speed..
fietsbob is offline
Old 04-29-19, 03:23 PM
shoota
shoota's Avatar
Good looking bike!
2019 Salsa Warbird
shoota is offline
Eric S.
Eric S.'s Avatar
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times in 36 Posts
Yeah, I tried it with 9sp for awhile and it didn't work for me for the same reason.
Eric S. is offline
Old 04-29-19, 03:35 PM
Revracer
Revracer's Avatar
Bikes: 1973 Schwinn World Voyageur | Francesco Moser SL | 1984 Ross Utopian | St. Etienne 531 | 1981 Peugeot PK10 | 2015 Cannondale SuperSix | 2012 Felt F65X
Quoted: 54 Post(s)
Liked 51 Times in 18 Posts
I tried something similar last year with 10 speed 11-36 Sunrace freewheel with Suntour barcons and a Suntour VX RD. The clicks in the barcons are 1-3 clicks per gear change (3 in the higher gears) but it doesn't require re-centering.
Revracer is offline
Old 04-29-19, 05:42 PM
Kuromori
Quoted: 237 Post(s)
Liked 83 Times in 64 Posts
I suspect it has to do with how clunky shifting from the cassette/chain combo is and personal tolerance for clicks is. A very slick shifting chain/cassette combo shifts quietly and shifts easily, then wants to shift out of gear easily at the shift gate, and overall doesn't give very positive feedback. Some people also don't notice the ticking every wheel revolution when the chain moves off center slightly at the shift gate and touches the next cog and don't feel it's worth trimming if they even notice. Even on index systems you see a lot of people that need a half turn of the barrel adjuster but they don't notice the ticking.
Curious what the lever throw in the biggest cog is though.
Kuromori is offline
Old 04-29-19, 06:07 PM
kansukee
Quoted: 122 Post(s)
Just finished a 28 miler group ride, so far I’m impressed by how smooth this thing is. I haven’t experienced any issues whatsoever, maybe I am doing something wrong? 😄
kansukee is offline
Old 04-29-19, 07:11 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Quoted: 2152 Post(s)
Liked 3,401 Times in 1,203 Posts
Ought to work just fine. I've used 6207 friction shifters with 10 speed for years, including several times at Eroica.
11 speed can't be any more difficult.
Just takes a gentle hand and a little finesse...
rccardr is offline
Old 05-01-19, 09:19 AM
Dr.Lou
Dr.Lou's Avatar
Quoted: 47 Post(s)
Liked 97 Times in 61 Posts
Haha
I need post shift finessing with 5/6 speed cassettes. Been that way since I was a kid
Dr.Lou is offline
Old 05-01-19, 09:23 AM
shoota
shoota's Avatar
Originally Posted by Dr.Lou
Haha
Ha! Drives me nuts. I'm not old school enough to like friction shifting. It's hard to use di2 and then use friction lol
2019 Salsa Warbird
shoota is offline
Old 05-01-19, 03:52 PM
robertorolfo
robertorolfo's Avatar
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times in 113 Posts
Would you consider Centaur to have the silver color? I've seen a few of them for sale online, and they look surprisingly good in person (the finish is great).
robertorolfo is offline
Old 05-30-19, 09:04 AM
kansukee
Quoted: 122 Post(s)
Well, I built a Cinelli SC frameset with silver Potenza so now I do have that silver crankset from the old bike. Just need to get around to changing it. By the way, is anyone interested in a gently used Ultrashift Athena group with carbon 53/39 UT crankset in 172.5mm with carbon levers and silver derailleurs? I don't think the group has 600 miles on it...
kansukee is offline
Old 05-30-19, 09:29 AM
robertorolfo
Quoted: 943 Post(s)
Might be. Am I allowed to ask for the price here?
Old 05-30-19, 09:57 AM
ryansu
ryansu's Avatar
Quoted: 796 Post(s)
Liked 522 Times in 367 Posts
IF it works for you keep doing it- sounds like its going well, keep riding and smiling and you can tell people It goes to 11 lovely bike btw
ryansu is offline
