12mm through axle tapered disc fork, not many choices
Quoted: 1163 Post(s)
Liked 442 Times
I’m building a couple of titanium disc bikes up. I have the frames (2 Wittson Illuminati’s) and one Columbus Futura fork. My frames require tapered 1.125”/1.5” steer tube and I prefer 12mm through axle to match the rear 12mm through axle.
I bought the Columbus Futura for about $300 and am preparing to lay out the cash for the next one.
But I thought I should check in with others to get a few ideas on what else is out there. I would think now that most new road bikes are coming standard with discs, tapered forks and through axles - that there would be much more availability of affordable options in forks. They all appear to be made in China. There are ones under $100 (Hylix?) all over the place then there a few I see in addition to the Columbus Futura such a one Tom Ritchey, a Whisky #7, and offerings from ENVE. All of these seem to be premium offerings retailing for $350 on up.
So, if you will... could you steer me (pun intended) to some decent disc fork options?
Liked 442 Times
Thanks. I don’t quite understand “trail”. I notice that the Columbus Futura comes in either a 45 rake or a 43 rake. I’m not sure which would be better for me.
Quoted: 630 Post(s)
Liked 369 Times
https://www.ebay.com/itm/Trek-Checkp...wAAOSwQ~Jc2ukS
And FYI the matching bontrager TA is $40, Trek DT Swiss TA is $50, RA Project TA is $38
Liked 442 Times
Keep the the links coming...
Dedaccai is another option that comes to mind.
Why do you need a 1.125-1.5 taper? You could also put in a 1.125-1.25 as well with a different headset. That might open up some options.
Liked 442 Times
My frame has a tapered head tube that takes the 1-1/8”, 1-1/2” size steerer. I would prefer to use the proper parts with the recommended Cane Creek headset.
Quoted: 1975 Post(s)
Liked 232 Times
Match what is supplied with the original fork or ask them for a recommendation. Trail is a combination of rake and head tube angle
