Self-adjusting BB7 rear brake
Old 07-17-19, 07:54 PM
400E
Bikes: Surly Disc Trucker
Quoted: 23 Post(s)
Liked 19 Times in 14 Posts
Hello,
I have Avid BB7 disc brakes on my Surly Disc Trucker. About a year ago I replaced the stock rear pads with genuine Avid sintered metal pads. I'm generally satisfied with them.
A couple weeks ago I realigned the caliper and everything seemed fine. For some reason after this, every few rides I notice that the brake lever travel is less than at the last ride -- in other words, the pads are closer to the rotor than I had initially adjusted them to be, and the pads are now rubbing on the rotor when I spin the wheel. If I back off the adjusting knobs a few clicks (inside twice as many as the outboard one), everything's fine again until next ride.
I can't figure out how this happens. Has anyone seen this?
thanks
Steve
400E is offline
Old 07-17-19, 08:03 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
I've used BB7s since 2003 and haven't experienced what you describe. Wheel securely in dropouts? Brake caliper securely in place after you adjusted it? Brake lever cable adjustment - if any - secure? Pads not worn down? Tried realigning again? Housing/cable in good shape?
JanMM is offline
Old 07-18-19, 07:27 PM
400E
Quoted: 23 Post(s)
Thanks -- great things to check out. Today for whatever reason the symptom didn't show up -- brake lever travel exactly as I left it yesterday. I will check out these ideas this weekend.
400E is offline
Old 07-20-19, 01:06 AM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times in 18 Posts
Cable isn't slipping in the anchor, or breaking is it?
Check close to the head of the cable and inspect length of cable. Especially if it hasn't been replaced in a while.
operator is offline
Old 07-20-19, 08:04 AM
400E
Quoted: 23 Post(s)
Does not seem to be slipping. Cable looks fine, anchor bolt tight. No barrel adjuster.
Re-centered wheel in the dropouts, made sure all bolts are tight. I readjusted (i.e. loosened) the 2 adjusting knobs again today and will see how it goes.
400E is offline
Old 08-01-19, 08:01 PM
400E
Quoted: 23 Post(s)
Well, the sintered metal pads seem to lose their friction (i.e. seemed contaminated) so took them out over the weekend, cleaned them with auto brake cleaner spray, and put them back and realigned the caliper. Fine for the first couple rides and now again had somehow gotten tight enough that the pads were rubbing tonight for my ride. I backed off the adjusters again.
This remains a puzzle to me. The only thing I can figure is that the pads themselves are the culprit. I did not have this problem with the original organic pads that came with the bike. I am wondering if somehow I got a bad set of Avid sintered metal pads somehow, that swell up with use? Not sure if this makes sense, but I really can't see another way for this to happen. The cable and housing is fine.
400E is offline
Old 08-01-19, 08:40 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Sounds puzzling, indeed.
JanMM is offline
Old 08-05-19, 07:31 PM
400E
Quoted: 23 Post(s)
Over the weekend I ended up getting a brand new set of Avid organic pads -- I wanted organic anyway and thought a new set of pads might do the trick. Did fine yesterday but today the brakes gradually tightened up on my ride to the point that I had to pull over and loosen the two adjusters. At that point, the wheel was basically locked up by the pads.
I will need to pull the pads again and make sure they are properly seated, but I was pretty sure they got seated well when I installed them. They clicked into place in a satisfying way (though I do find putting in BB7 pads to be a bit fiddly, as the British say -- I have trouble keeping the pad/spring sandwich together while getting the whole assembly into the caliper).
Really annoying and strange.
400E is offline
Old 08-06-19, 01:56 AM
headasunder
Quoted: 75 Post(s)
Put a pen mark on the adjusting wheels to see if they are moving?,you may have to dis assemble them to see what's going on
headasunder is offline
Old 08-06-19, 04:48 AM
tFUnK
Quoted: 425 Post(s)
Liked 454 Times in 313 Posts
Friction somewhere in the system causing the pads to not return to open position? From the lever down to the caliper? Maybe try new cables/housing, making sure that housing ends don't have jagged parts impeding cable movement.
tFUnK is offline
Old 08-06-19, 05:30 AM
400E
Quoted: 23 Post(s)
Good thoughts. I have wondered about the adjusting wheels turning on their own somehow.
The brake lever seems to spring back normally, but the free play before the brake engages gets less (as if I had turned the adjusting wheels clockwise).
400E is offline
Old 08-06-19, 07:19 PM
400E
Quoted: 23 Post(s)
Give that poster a cigar!
I put a Sharpie mark on the top of both adjusting wheels prior to my standard 10 mile ride tonight. Sure enough, the small outboard wheel is now 90 degrees clockwise from where it was at the start of the ride! Inboard wheel looks to be in the same spot.
Yes, now will have to disassemble this weekend.
Thanks for the tip!
400E is offline
Rest_assured
Bicycle Mechanics
9
08-12-18 06:55 PM
alias5000
Bicycle Mechanics
10
11-26-17 01:03 AM
NZDoug
Bicycle Mechanics
26
02-27-13 12:30 AM
daven1986
Bicycle Mechanics
12
07-13-10 06:32 AM
