Vintage 27" tire width?
Old 07-18-19, 08:30 AM
riverdrifter
riverdrifter's Avatar
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 170 Post(s)
Liked 272 Times in 105 Posts
I'm still confused about tire and wheel widths.
The 1984 Trek 620 came equipped with 27" wheels and 1 1/4" wide tires. 1.25 inches converts to 31.75 mm.
So if you set that vintage wheel next to a modern 700c road wheel with a 32mm tire mounted, would they be pretty close to the same width?
Thanks!
riverdrifter is offline
Old 07-18-19, 08:31 AM
ksryder
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times in 329 Posts
Yes.
ksryder is offline
Likes For ksryder:
Old 07-18-19, 09:30 AM
riverdrifter
Quoted: 170 Post(s)
Originally Posted by ksryder
Yes.
Thanks!
Old 07-18-19, 10:16 AM
noglider
noglider's Avatar
Quoted: 7287 Post(s)
Liked 2,362 Times in 1,381 Posts
Yes, some tire sizes are indicated using fractions of inches, some with decimal fractions of inches, and some in millimeters.
noglider is offline
Likes For noglider:
Old 07-18-19, 02:10 PM
John E
feros ferio
John E's Avatar
Quoted: 1384 Post(s)
Liked 1,294 Times in 819 Posts
Note that not all tires run true to their label or callout sizes. Continentals I have owned run small (700Cx28 being closer to 25 or 26mm), whereas Specialized have run full or even a bit larger (same 700Cx28, more like 29 or even 30mm wide). Mounted tire width is also affected by rim width, but, yes, 700Cx25 should be about as wide as 27 x 1", 700Cx28 should correspond to 27 x 1-1/8", and 700Cx32 should come in around as wide as 27x1-1/4".
John E is offline
Likes For John E:
Old 07-18-19, 04:52 PM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2597 Post(s)
Liked 1,678 Times in 926 Posts
Roughly.
And 27 x 1 3/4 is *about* 35mm.
Close enough for government work.
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Likes For The Golden Boy:
Old 07-18-19, 05:10 PM
Vintage Schwinn
Quoted: 342 Post(s)
Liked 388 Times in 254 Posts
John E. brings up an important point, as you also may want to investigate as to which tire brands run more true to size and which do not(--run smaller width--)
Michelin Protek (32 x 630) 27" x 1 1/4 tire is probably among the wider ones, as most cheat.....
(This is a great tire, however it's weight in grams is among the heavier tires in that size..................)
Vintage Schwinn is online now
Likes For Vintage Schwinn:
Old 07-18-19, 06:25 PM
Pompiere
Pompiere's Avatar
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 521 Post(s)
Liked 943 Times in 495 Posts
I have some Kenda knobby 27x1 3/8" that are barely 32 mm wide, even on a wide rim. Nashbar branded tires (from the pre-bankruptcy company), always were smaller than the stated size. 27x1 1/4 was 28 mm. 700x 35 mm was 32 mm. All the Pasela tires I have bought in 27 inch sizes were true to size.
Pompiere is offline
Likes For Pompiere:
Old 07-19-19, 04:40 AM
T-Mar
Quoted: 4719 Post(s)
Liked 3,034 Times in 1,874 Posts
And tyres, like waistlines, tend to grow as they get older. Basically, the cords in the casing relax a bit and stretch.
T-Mar is offline
Old 07-19-19, 07:56 AM
noglider
noglider's Avatar
Originally Posted by The Golden Boy
Roughly.
No, you're thinking of 1-3/8
noglider is offline
Old 07-19-19, 03:40 PM
The Golden Boy
Yup! Sorry!
Numbers and me don't get along to goodly.
Obeast
General Cycling Discussion
6
04-14-18 07:09 PM
Seven6zero
Road Cycling
1
02-19-17 12:52 PM
jeremy1981
Bicycle Mechanics
9
09-26-11 08:19 AM
flayz
Singlespeed & Fixed Gear
23
06-10-11 09:45 PM
nowitsshowtime
Bicycle Mechanics
1
05-03-11 08:21 PM
