New Cannondale Synapse vs. Another Endurance Bike?
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1953 Post(s)
Liked 1,475 Times
I have been looking for a new CF endurance road bike for a while, but have not found one that meets my requirements, until earlier tonight, when I found a new Cannondale Synapse 2 RLE (Ultegra Di2 12-speed) on sale for $3,500 + $300 shipping, so I ordered it. It won't ship for another few days, so I can cancel the order early next week, if my fellow BF enthusiasts can find me a better (or at least different) bike for a similar price that meets my requirements. I am all ears!
Requirements
1. Light weight carbon fiber frame and fork, i.e., < 1.5 kg or 3.3 lbs.
2. Endurance geometry, i.e., > 1.5 stack:reach ratio; preferably: 580 mm [stack], 380 mm [reach], 545 mm [effective top tube].
3. Short wheelbase. I don't need wide tire clearance or all-road capabilities; I have a gravel bike (Santa Cruz Stigmata 3) for that.
4. Round, non-proprietary seat post.
5. Disc brakes; not trying to restart the debate, but I already have two road bikes with 105 rim brakes.
6. Non-integrated cockpit; semi-integrated cockpit routing hoses and wires through handlebar and headset is OK, but routing through stem makes adding or subtracting headset spacers an all-day chore.
7. No moving suspension, which eliminates Trek Domane and Specialized Roubaix.
I had considered but ultimately decided against these other bikes.
A. Bianchi Infinito CV. Who does not want a Bianchi!? But it has a proprietary seat post with a fragile saddle rail clamp. I was prepared to overlook that (only because it is a Bianchi) but I could not even order a spare seat post. $$$
B. Basso Astra. Perfect geometry for me. But again, a proprietary seat post, and I cannot order the clamps for CF saddle rails. Also has a fully-integrated cockpit. $$$$
C. Giant Defy Advanced 0. I was prepared to overlook the proprietary seat post since Giant has the best supply chain in the business, but I miss the sale on the prior model, and new model reduced stack by 10 mm. $$$
D. Canyon Endurace CF SLX. I don't trust the adjustable width integrated handlebar where each end is only held by two small bolts. Even if I get over my fear of the ends snapping off, Endurace in size M is rarely in stock. $$
E. Pearson Forge. Why do so many bikes require a proprietary seat post!? And a fully-integrated cockpit!? $$$$
F. Look 765 Optimum. Finally, a relatively light endurance bike with a round seat post. But head tube angle < 71*; potential issue when slow climbing. $$$
Thank you for reading this post and for your suggestions.
Requirements
Quoted: 4428 Post(s)
Liked 4,880 Times
What’s wrong with the Cannondale? Seems like a good deal at that price.
Likes For PeteHski:
Quoted: 6203 Post(s)
Liked 4,816 Times
Anything about the fits on the Caad4 or Trek FX2 that bothered you? I'm thinking the Synapse will be similar to your FX2 for fit.
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
I have a Cannondale Synapse and love it. Mine has 105 on it but I did swap out the wheelset for a carbon wheelset and replaced the seatpost, seat, stem, and bars. I'm also planning on replacing the groupset with Di2 this year hopefully. I'd pick it over any of the options you listed (I don't want a Bianchi).
A Synapse with Ultegra Di2 for $3,800 shipped sounds like a great deal to me.
Liked 1,475 Times
The Trek FX2 is my first bike after a quarter century hiatus from cycling. I bought it using the standover method at my LBS, so it may be one size too big (56 instead of 54 like all my other bikes), but no biggie since it is my ride with family hybrid bike.
Liked 4,816 Times
I think you'll like the Synapse. But do get some input on what size you might like if it's not too late. Per Cannondale's sizing for that model, a 54cm should be for 67" - 71" tall riders. A 56cm for 69" - 76" tall riders. I'd be in the overlap size for my height of 71".
I might go with the smaller size more likely as I like sporty handling over stable feeling luxury sedan like riding. Though if you are truly going to be doing long distance multi day trips, you might want the larger for the extra perceived stability. Although I don't think this is a bike with eyelets for racks and paniers you might want for long multi day trips.
Likes For Iride01:
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
What year is yours? I love my 2016, my first road bike, and I have also replaced the same components as you did. I had to replace the derailleur cables once, and found that the internal routing was not bad, so would keep it manual shifting, in case I forget to charge the battery on my new one. But you must be the only member in this forum who does not like Bianchis!?
It's not that I dislike Bianchi's, I just don't want one. They are nice bikes and when I lived on the Peninsula the shop that I went to where I knew the co-owner/mechanic carried them so I've checked them out up close. There are just so many great options for bikes that they would be way down on my list.
Liked 1,475 Times
I plan to do the same after a few test rides; I only went for the 2 RLE to get Ultegra Di2. Did you resell your Smart Sense components? What is a good source for that cover?
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
Besides the cover I've bought Frame Grommets and Fender Mount Hardware from them.
Likes For KJ43:
Quoted: 3245 Post(s)
Liked 2,093 Times
Liked 1,475 Times
That seems a tad wasteful when the Smart Sense radar seems to be the horizontal functional equivalent of a Varia RVR315. After I remove mine, I will look into making it work as such.
You have put the seed of an idea in my head. It involves planning a route over 6 legs, hotels for the nights, and a support cargo van that would fit 2 persons (one driver and one passenger), 6 bikes, one work stand, light luggage, and everyone drives one leg.
Likes For KJ43:
Liked 1,475 Times
Likes For SoSmellyAir:
Liked 2,093 Times
Likes For Steve B.:
Liked 4,880 Times
Edit: Fulcrum alloy wheels on a £6k road bike!
Liked 1,475 Times
In the USA, the 2RLE has an MSRP of $5,550, and it's on sale everywhere for $4,440, but somehow I managed to order the last one in my size from this chain across the country at $3,500 + $300 shipping, leaving me some money for a wheel upgrade.
Liked 1,475 Times
KJ43: If you plan to upgrade to 105 Di2, the 2LE is on sale for $2,925, less than the current $3,325 MSRP of the 3L. It may make more sense for you to buy a 2LE, swap parts with your 3L, then sell the latter, than buying a whole new 105 Di2 groupset.
Liked 4,880 Times
I’m not surprised it is on sale. Alloy wheels and bars at that MSRP is nuts! But $3,500 seems more reasonable.
Likes For BTinNYC:
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
Likes For KJ43:
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Fwiw the more I ride it the more I like it. I changed the stem from 110 to 100 and for some reason the wandering on slow steep climbs has gone away.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Likes For Shadco:
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 220 Post(s)
Liked 864 Times
Requirements
Requirements
Likes For Sierra_rider:
Liked 1,475 Times
KJ43: Do you know the total height of the headset spacers that your bike came with? I tried to look it up in the User Manual Supplement but could not find it. My 2016 Synapse carbon had a very generous stack of headset spacers for a total height of 55 mm, including the typical SI 25 mm tall funnel-shaped headset top bearing cap / cover.
Dead but dreaming
Quoted: 171 Post(s)
Liked 326 Times
Likes For KJ43:
Liked 1,475 Times
My new Cannondale Synapse arrived today. Preliminary observations:
1. The grey is darker than on Cannondale and retailer websites. Maybe my living room does not get enough light?
2. Frame is Made in Taiwan. Yay! The rose gold frameset I saw on eBay is Made in Indonesia: 2022 New Cannondale Synapse Carbon Endurance Bicycle Disc Frame Set Rose gold | eBay
3. Frame does not have a bottom bracket cover!? One is not listed on the Replacement Parts page of the Owner Manual Supplement.
4. Di2 wire to RD is too short and does not extend out of seat post. Cannot connect RD to Di2 battery; no test ride. Argh! Have to visit LBS tomorrow.
5. Bar tape wrapping job is noticeably worse than the factory bar tape wrap on my 2016.
The new Synapse likewise comes with 55 mm of spacers: (a) SI 25 mm tall funnel-shaped headset bearing top cap; (b) 15 mm spacer; (c) 3 x 5 mm spacers.
