Trek multitrack 29er conversion and STX fd clearance
Quoted: 129 Post(s)
meet my 29er conversion, early 90s multitrack
Tons of fun!
rear tire is kenda honey badger 2.05, actual width is 47-48mm (but it may stretch out...)
fit is very tight, and in middle or big ring the shift cable attachment point rubs the knobs when I corner.
FD is Shimano STX. As you see, the cable attachment arm is bent backwards. I don't know if that is normal, or perhaps I should bend it forwards to give the tire more clearance.
Or if that is normal on the STX, I may put this tire on the front and find a 29x1.9 for the back
Tons of fun!
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12757 Post(s)
Liked 7,672 Times
Suntour BL has much better clearance. The BL works great with Sram Attack front shifter, which has 10 positions, dunno how it would work with 3 or 4 position shifters.
is just a real cool dude
Quoted: 30 Post(s)
Liked 30 Times
Hybrids are like a empty canvas of the bicycle word. Not to mention you can pick them pretty darn cheap. I turned a mid 90s Cannondale H400 hybrid into my do all gravel bike. Toss some dropbars onto it and you've got a completely different bike.
I find the new gravel bike design is really a 'racey' hybrid. Look at where it's meant to go? And what are many hybrids ideal on?
(I also think gravel bikes are enduro versions of cyclocross.)
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 529 Post(s)
Liked 999 Times
I have one. A 1992 Performance Parabola touring bike with 135mm hybrid wheels, and hybrid derailleurs. Even the drop bars say "hybrid". But it has dual pivot side pull brakes, 170 mm cranks, bar-end shifters, and front & rear threaded rack mounts. It is a bit heavy, but it rides nice, at least unloaded. I would like to try it on a gravel road.
Quoted: 147 Post(s)
Liked 8 Times
By all means, go for it! What is old is new again. The first gravel road bike was designed by Grant Petersen of Rivendell fame, who at the time worked as a brilliant, idiosyncratic designer for Bridgestone - appeared in the form of the XO-1:
At the time, no one knew what this bike could do because it defied all the conventional wisdom about a road bike and was a market flop.
Today its a classic and a highly sought after collectible.
Quoted: 55 Post(s)
Liked 32 Times
Find the geometry chart for the mid-90's upper level Trek Multitracks and then compare it to the Surly Cross Check and the Soma Double Cross. The Treks probably have a little more trail but other than that, they are almost identical, right down to the BB drop.
1995 Trek 730
1995 Trek 730
Compare the geometry you pointed out to modern gravel bikes like the GT Grade, Raleigh Tarmac, Felt V, Giant Revolt, etc... Gravel bikes. Longer chainstay, greater BB drop, more upright (stack/reach).
Quoted: 55 Post(s)
Liked 32 Times
The Cross-Check isn't a gravel bike. "There is no such thing as one bike that can do it all, but the Cross-Check does" is directly from the Surly website describing the Cross-Check. It can be set up to do what a gravel bike does, but it's more a touring bike.
Very cool, glad to see another! I also recently started slowly building up my '95 Trek 750. Making a touring/gravel ride out of it, I always loved their geometry.
Just from looking at a picture of my bike on my phone, it does look like the back-bent FD arm is normal.
Quoted: 75 Post(s)
My "Mutt" is a 1993 Trek 720 and I've used it for lots of mixed surface riding. I've got Schwalbe Smart Sams in 700 x 40mm on A719 rims which gives me just enough clearance with trail type fenders. Great bike for gravel and reasonably solid double and single track. I wish I could find a higher end frame of the same era, but it appears the 700 and 720 were by far the most popular in this area. I rarely see a 730 and not in my size (21") so far.
Keep an eye out, I've seen a few 730s pop up on the local Craigslist. I got started biking by fixing up a 730 and using it for mountain biking and commuting. Gave it to my mom since the frame was far too small.
Quoted: 129 Post(s)
My poor man's niner Multitrack - now with kenda honey badger 2.05 moved to front, as you can see, clearance is tight
back tire is a vee 1.9", plenty of clearance
yeah, bike needs a bath after I rode it in the mud
Bikes: Trek Multitrack 750 1992; Easy Racers Tour Easy recumbent 1999
Tons of fun!
Tons of fun!
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I'm curious as to why the OP said this was a conversion -- the bike came stock with 700c wheels, which is the same thing as a 29er. That's like saying New York, New York.
OP was 3 years ago so he might not answer you. My experience with the Trek 750 is that I think 47 or 48mm will be the max.
Quoted: 1218 Post(s)
Liked 298 Times
I heard the Maxxis Rambler is coming in a 700x45. so there is that option also. will you notices a 3mm difference?
I could only find 700x40, even at Maxxis website. The 700x40 is enough, I think, but It's too expensive in Brazil. We have very unfair taxes to import bike tires. Thanks!
Liked 298 Times
bananafruitcake
Bicycle Mechanics
14
05-30-15 08:07 AM
gramphighgate
2
05-17-15 06:53 PM
