Fabric saddle widths?
Jet Jockey
I've long subscribed to the "sit bones + 2cm" guideline for saddle width. However, I was shopping Fabric saddles, and their recommendations are somewhat wider. They recommend their 134mm wide saddles only for riders with sit bones between 85-100mm, which statistically speaking is almost no one. If I recall, 100mm is the bottom 5% of the male distribution. My 110mm put me squarely in the middle of their 142mm size chart.
I guess guidelines are changing? And if so, how do 130-ish saddles sell to anyone? I'm probably going to buy the narrow Fabric anyway...heck with their size charts. I'm a rebel like that.
Good night...and good luck
Not sure. I measure ~113mm and ride (142mm width) Scoop Shallow and a Line Wide per Fabric's recommendation. Both fit me well are are super comfy. I've tried narrower saddles, not so great. Try both see which size you prefer and return the other?
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Sorry, can't help you on the width, but have you determined which of their shapes to go with? I have only tried the flat and the shallow, and it was a night and day difference for me. So, it may not be the width that is the deciding factor for your anatomy. The shallow is perfect for me, the most comfortable saddle I've used in years, whereas the flat was one of the worst...
Jet Jockey
For a while the Line was only available in the narrow width. Considering that almost zero percent of the population meets the recommended size, I wonder who they sold them to?
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
Me, they sold them to me! I normally use a middle width saddle but the 142 offered by Fabric was perfect for some reason. The shape didn’t work unfortunately I’m more a flat saddle guy. So heck if you want a carbon rail line shallow pro hit me up, used two weeks!
Jet Jockey
You should actually just return it. Fabric has a 60 day trial guarantee.
Quoted: 6195 Post(s)
Liked 4,810 Times
Well if all manufactures made things exactly the same way, we wouldn't need different manufacturers. So instead of using a general rule that helps you when no other information is available, why not use the manufacturers specification of how to size it when you have that information.
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
Here's one maker's explicit directions toward determining what width to look for.. if buying their saddle.
