700.....x23 vs x25
Bikes: Raleigh Mojave 4.0, Univega Via Carisma
700.....x23 vs x25
Preferences anyone?
I'm currently running Conti Gatorskins 700x23 which are near the end of their life and someone on craigslist has a set of 700x25 they'll sell me for $50 (saving ~$15). Anyone notice a big difference between the two?
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,307 Times
Depends on your weight. In general there are some studies that show lower rolling resistance with 25's given the right inflation for the rider. You should notice a more comfortable ride as you will be able to ride at a lower pressure with the larger volume tire.
My take? There isn't much of a difference. If you're over 200 then get the 25's if they have them. As a dealer I find that all this talk of 25's has caught suppliers out and there simply aren't any in stock anywhere...so....sure...get them. Especially if they save you money.
i guess...what downside are you worried about? Someone might tease you about your "fat" tires?
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Bikes: Rossetti Vertigo
Quoted: 229 Post(s)
Liked 119 Times
I weigh 175lbs. I went with the 23's just because I couldn't find Rubino Pro Slicks in 25's. Plus, the 23's are much easier to get on and off the bike. Even with the brake released, the old 25's would get stuck between the brake pads. Not a big deal, but it was a PITA sometimes when trying to get the rear wheel back on and the tire keeps getting stuck between the brake pads. But to answer your question, I don't notice much difference between the two sizes while riding.
Embracing my inner Fred
Bikes: Early 90s Specialized Epic Pro carbon/DA
To me, 25 vs. 23 is a huge difference in ride with the GP4000 tires. I'm 210, but the 25s just ride so much nicer and give a lot more confidence in cornering. The 23s were a much rougher ride. Of course, I was running the 23s at about 115, and I run the 25s right at 100.
OM boy
Bikes: a bunch
Quoted: 534 Post(s)
Liked 655 Times
more diff. between tire brands and models... lotsa studies, all show the 25 being equal to or faster than smaller profile for regular road ridin.
only caveat - some bikes just won;t take a 25mm rear - I know, seems unlikely...but
my Marin argenta (alu) is so tight at the chainstays that a 25mm conti will not work (so most any 25 prolly won;t either), when I get out of the saddle I could feel the rub at the stays - and the paint got rubbed off... all with a very true, reasonably stiff wheel under a 165 lb'r. I have to use 23s on that bike.
happens to be the bike I use for weekly hillclimb rides - so out of the saddle and pushin a lot...
I eat carbide.
Liked 1,307 Times
There is more than just a 2mm difference - you have a increase in air volume for that additional "2mm" of nominal width. As for tread/no tread- red herring. Tread does nothing on bicycle tires in this size range. The contact patch is so small and the forces to high that treads are simply ineffective. They are there because of tradition and looks and to make consumers who wonder about treads feel like they are going to have more traction.
Someone always posts the equations, but in general to get a bicycle to hydroplane it would have to be traveling at something like 300-500mph.
With 25's at lower air pressure the tire conforms well to the terrain and "scrubs" less speed caused by having to ride higher pressures in smaller tires (Same force in a smaller contact patch).
Rider weight affects all of this the most. In testing it appears that as we have all gotten fatter we are better served with 25's.
25's on a 145 pound cyclist riding on fairly smooth roads is less effective than riding 23's....unless you want to start talking about aerodynamics.....*oh geez*
I eat carbide.
Liked 1,307 Times
Yup. I have a set of 25's Michelin Pro Race 2's that are so flippin big that I have yet to really be able to ride them on anything other than my cross bike. So much so that I locked my road bike up solid during one of our "epic" spring road races over gravel as the muddy/sand/gravel mix just built up between the tire and frame so much that it stopped everything. Cleaning it up it looked like the brake bridge had just been sandblasted back to bare metal.
Over the hill
Quoted: 1002 Post(s)
Liked 1,219 Times
Anyway, I switched to 25s last year and can't tell the difference (running the same psi) although it's nice to know I could lower the pressure on rougher roads with less risk of pinch flats.
It's like riding a bicycle
I notice a difference, I ride the gp4000s in 23 and went to 25 on my CAAD. The difference comes from the lower psi. I went from running 110 to 95. I weigh in at 175.
Quoted: 18883 Post(s)
Liked 10,646 Times
Bikes: Many
Quoted: 7 Post(s)
The tire pressure and treading will have more impact. I take it the CL ad is for new ones? I wouldn't buy used tires or even new ones that have been sitting for years. Spend the 15$ and get the ones you prefer, don't base just on size.
Bikes: 01 Specialized Rockhopper A1 and 07 Felt Z80 05 Canondale Prophet
I'm 230 and I just started running Ultra Gatorskins in the 25 size a few months ago.. I've put about 1000 miles on them and I love them. I don't ever plan on going back to a 23, ever. I run 100 psi and they roll so much nicer than the smaller tire.
The Gatorskin 25 is a huge tire though, judging by other 25's, I'd say it's larger and so do my measurements. I don't remember the specifics, but I measure a buddy's Armadillo, and the Forte Strada-K's, the 25 was larger than the 28 Forte and the 25 Armadillo..
I think I feel better in the corners because I am just not getting jostled by the road so much..
That's my $.02, YMMV..
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
I switched from Vittoria Rubino Pro Slick 23's to 25's about 400 miles (~2 weeks) ago . I'm 6'-3" 195# and for me there is an improved ride quality and more stable feel. I like 'em.
Quoted: 630 Post(s)
Liked 369 Times
You can get them for $27 shipped here after code VELONEWS10
https://www.probikekit.com/us/tyres-t...road-tyre.html
Switched from 23mm to 25mm this year (GP 4000). Made a huge difference in ride comfort for me especially this time of year when all of our chipseal roads get a fresh coat of gravel. Less vibration and more stability. 157# and running 96# rear and 86# front.
Bikes: cannondale crit 3.0, specialized allez, old giant mtb/hybrid
i ride a 23 bontrager race slick in front and a 25 serfas with tread on the sides in the back, but i only weigh 140 and i keep the pressure at 110 give or take, I would ride my tubulars if I could but Chicago roads eat them for breakfest, I like the slick front cause i feel I have better traction and control when I turn. And the tread in the back so I dont skid out when I break at high speeds. But I have heard that 25 or even higher with a less then recomended psi do have less rolling resistance, Theoretically on flat ground 23's or 21's with high pressure have a lower RR, but in reality a road is not perfectly flat or even remotely flat and the hard wheel vibrates and bounces off imperfections in the ground, disrupting speed. A bigger tire with the right PSI will absorb these bumps and keep you going straight.
Bikes: 2011 Specialized Roubaix Comp Compact
I run GP4000s 25c on my training rides and race GP4000s 23c. I feel that the 25c takes the high pitch buzz out of the ride. When I race the 23c are just a little more responsive, with that said I would not train long rides on the 23c unless I have no choice. On long rides, 50 or more miles, I have less muscle fatigue with the 25c. The high pitch vibrations that the 25c cuts down on seem to lesson muscle fatigue. When I am racing I am less worried about the fatigue than I am with going fast. This is my observation over the last 10 years or so anyway.
Should Be More Popular
Quoted: 22639 Post(s)
Liked 8,953 Times
